For layouts that include data displayed in column or table format, you can add one or more filters to further customize the type of information you want display.
- Choose View, Filter By, Customize.
In the Top Layout window, you can also click the Display Options bar (in the right pane), then choose Top Layout Options, Filters, or right-click in the table and choose Filters. - In the Parameter column, double-click the first row and select Any of the Following or All of the Following.
- In the Parameter column, double-click the first blank row, then select a field by which to filter.
- In the Is column, double-click the corresponding field and select the filter’s search condition or comparison operator.
- In the Value column, double-click the corresponding field and type or select the value you want to display for the specified field.
- To add another filter field, click Add, then repeat steps 2 through 6 for each field you want to include in the filter.
Tips
- To change the order of the filter criteria, select an item, then click
or
- To delete an item in the filter, select it, then click Delete.
