Filter dialog box
Use the Filter dialog box to modify a filter.
Filter Name: The name of the filter. You can type a new name.
Display Options bar: Click to optimize or print the list of filters.
Display all rows: Lists each filter criteria item.
Parameter: Lists the parameter specified for each filter criteria.
Is: Lists the corresponding operator for each filter criteria.
Value: Lists the value for each filter criteria.
Add: Adds a new filter criteria.
Delete: Removes the selected filter criteria.
Cut: Cuts the selected filter criteria so you can move it to another position in the filter.
Copy: Copies the selected filter criteria.
Paste: Pastes a filter criteria.
Arrows: Change the selected filter criteria's position in the filter definition.
Note
Tip
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
