Filters dialog box
Use the Filters dialog box to add, edit, apply, and remove filters for the current display. A filter is a set of instructions that determines which activities or projects display. You can apply a filter at any time to focus on specific areas of a project. For example, you might want to see only critical activities, activities that are underway, or completed activities.
Filters are categorized into four possible groups: Default, Global, Layout, and User-Defined Filters. Filters that are applied to a layout are saved with the layout. You can limit the number of filters in the global category by setting them as layout filters.
All Activities: Mark to display all activities.
Show activities that match
All selected filters: When more than one filter is selected, choose to indicate that activities must meet all selection criteria in each filter.
Any selected filter: When more than one filter is selected, choose to indicate that activities must meet only one selection criteria in each filter.
Filter: Lists filter names according to filter category. You can select a filter. To sort the display, click the Filter column label.
Select: Mark the appropriate checkbox to apply or remove a filter. To sort the display, click the Select column label.
When applying the selected filter(s)
Replace activities shown in current layout: Choose this option to display only the activities in the current layout that meet the selected filter criteria.
Highlight activities in current layout which match criteria: Choose this option to highlight the activities in the current layout that meet the selected filter criteria.
Apply: Applies the selected filters without closing this dialog box.
New: Creates a global filter.
Delete: Deletes the selected filter. You can only delete global and layout filters.
Copy: Copies the selected filter.
Paste: Pastes a copied filter to the global or layout category.
Modify: Allows you to edit the selected filter. You can only edit global and layout filters.
Tip
Make Global: Makes a layout filter a global Filter.
Copy as Layout: Makes a default or global filter available to the currently open layout
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
