Financial Periods of Calendar dialog box (P6 Professional Only)
Use the Financial Periods dialog box to view or define financial periods for a financial period calendar. Users can store a project's period performance (past period actuals) for any predefined period contained in the financial period calendar assigned to the project.
The columns, fields, and buttons contained in the Financial Periods dialog box are described below.
Batch Create Financial Periods
Last Period End Date: Displays the latest period end date contained in the calendar. This field is read-only.
Batch Start Date: Select the date on which you want the financial period batch to start. The module will adjust the date in this field (if necessary) after you create the batch depending on your selections in the Financial Period section.
Batch End Date: Select the date on which you want the financial period batch to end. The module will adjust the date in this field (if necessary) after you create the batch depending on your selections in the Financial Period section.
Financial Period: Select to make each financial period in the batch Every n Weeks or Every n Months long (where n is the number of weeks or months); or, select Every Year to make each period one year long.
Period Ends On: If you selected Every n Weeks, choose the day of the week you want each financial period to end on. If you selected Every n Months, this field is disabled. (The end date for each monthly period is the last day of the month.) If you selected Every Year, select the month you want the financial period batch to end on.
Batch Create: Creates the financial periods based on your selections.
Display
Period Name: A unique identifier for the period. When you create a new financial period, the name defaults to the start date for the period. Click on the name to edit.
Start Date: The period start date. This field is not editable.
End Date: The period end date. This field is not editable.
Add: Click to open the Select Financial Period Timescale dialog box in which you can specify the start and end date of a new period. When the dialog opens, the default start date is the day after the previous period's end date; the default end date is seven days later.
Note: The start date and end date of a period cannot overlap the start date or end date of any existing period.
Tips
If your organization summarizes activity and resource data by financial period, to ensure that all project data in the database will be summarized (including closed projects), you must create financial periods that span the date range of all projects assigned to the calendar. For example, if the oldest project assigned to the calendar has a project start date of October 1st, 2001, your financial periods should begin on or before that date.
Notes
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
