Group and sort Resource Usage Spreadsheet columns in the Activities window
- In the left or middle panes of the Resource Usage Spreadsheet layout, click the Display Options bar, then choose Group and Sort By. Choose one of the predefined group and sort options, or, to customize grouping and sorting, choose Customize.
If you choose Customize
- In the Group By column, double-click the cell, then select the field by which you want to group.
- Click Sort, then select the field names you want to sort by for the grouping. Click OK.
- To change a group's display color and font, double-click the appropriate Font & Color field.
- To group and sort by additional fields, repeat steps 1 and 2.
Tip
- To remove a grouping field, select the field you want to remove, then click Delete.
