- Select an activity to analyze.
- Click
Backward Resource Driven Critical Path.Click
Increase Maximum Multiple Critical Path Count or
Decrease Maximum Multiple Critical Path Count to view more or fewer resource-driven critical paths to the selected activity.Click
Select Maximum Multiple Critical Path Count to specify the number of critical paths to show.Note: You can also view the activity-driven critical paths, with or without resource leveling. Click
Forward Activity Critical Path,
Backward Activity Critical Path, or
Activity Critical Path to view the activity driven critical paths.
Tip
- The critical paths shown only take into account resource assignments in open projects.
- When you view resource driven critical paths, P6 Professional changes the grouping of the view to group by critical path number. To return to your original grouping and sorting, click
Enable Group and Sort.
