Modify Template dialog box
Use the Modify Template dialog box to select the options used when importing and exporting data for use with Microsoft Project or other third-party applications.
If resource security is enabled, some restrictions apply when importing resource and resource assignments. For details, click the Resource link below.
The following tabs are available:
Related Topics
Introduction to Resource Security
General tab - Modify Template dialog box
WBS tab - Modify Template dialog box
Global tab - Modify Template dialog box (P6 EPPM Only)
Project tab - Modify Template dialog box (P6 EPPM Only)
Activity tab - Modify Template dialog box
Resource tab - Modify Template dialog box
Notebooks tab - Modify Template dialog box
Custom Field Mappings tab - Modify Template dialog box
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
