Open a project
When starting the module
  1. Log in to P6 Professional.
  2. To open an existing project, click Open Existing on the Welcome dialog box.
    To open the last project you worked with, click Open Last.
  3. From the Open Project dialog box, click the project or EPS node you want to open, or press the Ctrl key and select more than one project, then click Open.
  4. Use the Enterprise toolbar, Project toolbar, Enterprise menu, or Project menu to open the window you want to work with, such as Projects, Resources, or Activities.
From within the module
  1. Choose File, Open.
    You can also click on the Standard toolbar.
    To view more information about each project, click the Display Options bar and choose Columns, Customize. Then, add the appropriate columns to the dialog box.
  2. Select the project you want to open.
  3. In the Access Mode section, choose Exclusive, Shared, or Read Only to specify how you want to open the project.
    Depending on your security profile or the way in which other users have opened the project, some of these options may not be available.
  4. To view a list of users currently working in the selected project, click Users.
  5. Click Open.
Notes
Related Topics
Enterprise Toolbar
Project Toolbar
EPS node
Menu bar
Standard Toolbar
Exclusive
Shared
Read Only
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
