Use the Project Thresholds window to create, view, edit, and monitor thresholds for the open project. You can monitor a threshold at the work breakdown structure (WBS) level or the activity level to identify issues. You can customize the columns that display in the threshold table, and you can group, sort, and filter thresholds.
To display the Project Thresholds window, do one of the following:
- Click
on the Project toolbar. - On the Project menu, choose Thresholds.
When working in the Project Thresholds window, you can:
- Use the Edit menu on the Menu bar or the Edit toolbar to add, delete, cut, copy, and paste thresholds.
- Use the Display Options bar, the View menu on the Menu bar, or the Layout toolbar to customize the threshold table.
- On the Edit toolbar, click
to monitor the selected threshold to identify issues. - Use Project Threshold Details or the threshold table to define general and detailed information for each threshold. To show or hide Threshold Details, click
on the Bottom Layout toolbar.
Tips
- You can monitor an individual threshold or all thresholds at once.
- After opening the Project Thresholds window, the window remains open until you close all open projects or you close the window; if you open or navigate to another window without closing the Project Thresholds window, click the Project Thresholds tab to return to the window at any time.
Related Concepts
- Thresholds
- Threshold parameter definitions
Related Tasks
You can perform all of the following tasks in the Project Thresholds window:
- Add a threshold
- Assign a tracking layout to a threshold
- Delete a threshold
- Delete a threshold issue
- Disable or enable a threshold
- Monitor a threshold
- View threshold issue details
