Replace selected role(s) with dialog box
Use the Replace selected role(s) with dialog box to replace an existing role assignment.
Display Options bar: Click to change the roles display.
Role ID: Lists role IDs. To sort the display, click the Role ID column label.
Role Name: Lists each role's name. To sort the display, click the Role Name column label.
Select: Assigns the selected role.
Clear: Clears the role assignment.
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
