Select Resource Curve To Copy From dialog box
Use the Select Resource Curve To Copy From dialog box to choose an existing resource curve on which to base your new curve.
Display Options bar: Click to change the display or preview how the dialog box will print.
Resource Curve Name: Lists all defined default and global resource curves. Select the curve whose percentages you want to copy for your new resource curve.
Select: Click to copy the selected curve's percentages to your new resource curve.
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
