Sort dialog box
Use the Sort dialog box to control the order of items in a window or layout.
Field Name: Lists sorting data types, in order, for the current window or layout. To select or change a data type, double-click the data type you want to change.
Sort Order: The corresponding field's sort order: Ascending, Descending, or Hierarchical. Double-click this field to select a sort order.
Add: Adds a sorting data type.
Delete: Deletes the selected sorting data type.
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
