Tailor Attributes dialog box
Use the Tailor Attributes dialog box to specify which activities you want to include in your project plan according to attribute.
Display Options bar: Click to change the attributes display.
Attributes table: Lists attributes assigned to activities in your project plan. A checkmark indicates a selected attribute.
Select: Includes activities with the selected attribute.
Remove: Excludes activities with the selected attribute.
Details: Displays detailed project information about the selected attribute.
Activities: Displays the selected attribute's assigned activities.
Rationale: Allows you to enter a rationale for your attribute selections.
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
