Enabling Daily History Snapshots and Slowly Changing Dimensions
To enable slowly changing dimensions and daily history snapshots for a P6 project:
  1. Sign in to P6 EPPM.
    http://<host>:<port>/p6/action/login
  2. In P6, click Projects.
  3. On the Projects screen navigation bar, click EPS.
  4. On the EPS page:
    1. Select a project.
    2. From the icon Row Actions menu of the selected project, select Set Project Preferences.
  5. In the Project Preferences pane:
    1. Ensure the project is configured for Publication Services.
      1. Click the Analytics & Services tab.
      2. Select the Enable Publication option in the Publication section.
    2. Configure the project's History Level setting.
      2. From the History Level list, select Activity (Daily), Activity (Weekly) or Activity (Monthly).
        Note: You should still configure the History Interval setting, but it will only apply to Project and WBS-level history metrics.
    3. Click Save and Close.
Copyright © 1999, 2021
Last Published Monday, December 13, 2021
