Using Location Data
Both P6 EPPM and Primavera Unifier can store location information for projects. In addition, P6 EPPM can also store location information for activities and resources. Primavera Analytics can create intelligent analysis to evaluate measures using the geographical location data entered in P6 EPPM and Primavera Unifier. To accomplish this, you will need spatial boundary data and maps. Primavera Analytics comes with access to Oracle eLocation services. Oracle eLocation service is a cloud-based map data service that provides mapping, geocoding, and routing capabilities. For more information, see the Oracle Business Intelligence (OBI) documentation on mapping and spatial information.
Primavera Analytics now uses built-in Oracle Maps within OBI by default for creating spatial analyses included with Primavera Analytics sample catalog without any external schema or additional Map Viewer configuration. Alternatively, you can continue to use Map Viewer demo data (MVDEMO) for spatial analyses.
Note: If you choose to use Map Viewer demo data (MVDEMO), the location attributes you enter in P6 EPPM and Primavera Unifier must match the attributes in the MVDEMO data to ensure the map layers render correctly.
For example, if you configure your map to use the CITIES_ALL tile, you should query the MVDEMO database user schema and use the exact, case sensitive code that resides in the schema. This means if you have a city name, Philadelphia, in P6 EPPM, the name Philadelphia must also exist in the MVDEMO CITIES_ALL tile.
In This Section
Entering P6 EPPM Data for Mapping
Preparing Primavera Unifier Data for Mapping
Installing and Configuring MVDEMO Sample Spatial Data
Copyright © 1999, 2021
Last Published Monday, December 13, 2021
