Adding the ELOCATION_MAP for MVDEMO
Primavera Analytics uses a base map called E_LOCATION. To add this base map to MVDEMO, complete the following steps:
  1. Access the MapViewer:
    http://<machine>.<domain>:9704/mapviewer
  2. Select the Admin link.
  3. Log in to MapViewer using the same administration user you use to log in to the WebLogic and Enterprise Manager console.
  4. Select Create Tile Layer.
  5. Select Oracle Maps and click Continue.
  6. In the Name field, verify the name is elocation_map.
  7. In the Data Source field, select mvdemo.
  8. Select Submit.
  9. Select Manage Tile Layers and verify ELOCATION_MAP with Data Source mvdemo is there.
Copyright © 1999, 2021
Last Published Monday, December 13, 2021
