Configuring Background Maps for MVDEMO
After importing the necessary map layers, complete the following steps to associate the background maps with map layers created in the previous section.
  1. Log into OBI with an account that has BI Administrator role.
  2. Click Administration.
  3. Under Map Data Management, click Manage Map Data.
  4. In the Manage Map Data page:
    1. Select the Background Maps tab.
    2. Select Import Background Maps.
  5. In the Import Background Maps dialog box:
    1. In the Look in field, choose mvdemo.
    2. In the Available Maps field, choose ELOCATION_MAP.
    3. Select OK.
  6. Select the ELOCATION_MAP you added and select Edit Background Map.
  7. In the Edit Background Map dialog box:
    1. In the Name field, enter City Map.
    2. In the Interactive BI Layers section, click +.
    3. In the Add Layers pop-up, select ALL CITIES.
    4. Click OK.
    5. Adjust the zoom level as needed.
    6. Click OK.
  8. Repeat the above steps to add a country, state, and combination country/state/city maps.
    Notes:
    • When you create a country map, name it Country Map and add the ALL COUNTRIES BI layer.
    • When you create a state map, name it State Map and add the US STATES BI layer.
When you create a country/state/city map, name it Country State City Map and add the ALL COUNTRIES, US STATES, and ALL CITIES BI layers.
Copyright © 1999, 2021
Last Published Monday, December 13, 2021
