Setting Up Oracle R Enterprise (ORE)
After installing Oracle R Enterprise (ORE), set it up for advanced analytics as follows:
  1. Grant permissions.
    % sqlplus / AS SYSDBA
    SQL> GRANT RQADMIN to RQUSER;
  2. Go to P6 and create user with security permissions named rquser. The name of the P6 user needs to match the name used to install ORE.
  3. Run ETL to get the row level security working.
  4. Create table etl_aa, which contains the project_object_id for the projects that will be calculated.
    CREATE TABLE etl_aa(project_object_id number(19));
  5. Insert the project_object_id for the selected project (the data below is an example based on sample data).
    INSERT INTO etl_aa(project_object_id) values (4351);
    INSERT INTO etl_aa(project_object_id) values (4352);
    INSERT INTO etl_aa(project_object_id) values (4354);
    INSERT INTO etl_aa(project_object_id) values (3577);
    INSERT INTO etl_aa(project_object_id) values (4049);
    INSERT INTO etl_aa(project_object_id) values (4301);
    commit;
  6. Login as a SYSTEM user grant privileges to RQUSER to access STARUSER.
    grant select on staruser.w_project_d to rquser;
    grant select on staruser.etl_aa to rquser;
  7. Install R library glm2. It used in the script.
    bash> ORE
    > library(ORE)
    > ore.connect(user="RQUSER", password="oracle", service_name="pdborcl", all=TRUE)
    > install.packages("glm2")
  8. Create an R object (script under RQUSER).
    bash> ORE
    > library(ORE)
    > ore.scriptCreate(predict_projects ......................... <the full command is the attached file >
  9. Login as staruser and run the script:
    SELECT * FROM table(rqEval(NULL, NULL, 'predict_projects'));
  10. The prediction results will be stored in RQUSER.ETL_AA_RESULTS.
  11. Bring RQUSER.ETL_AA_RESULTS to STARUSER:
    1. Create a database link from STARUSER to RQUSER:
      CREATE DATABASE LINK DBLINKR
      CONNECT TO RQUSER IDENTIFIED BY oracle
      USING 'pdborcl';
  12. Bring over the entire ETL_AA_RESULTS table:
    create table etl_aa_results as
    select * from etl_aa_results@dblinkr;
Related Topics
Prerequisites for Advanced Analytics Example
Setting Up R
Copyright © 1999, 2021
Last Published Monday, December 13, 2021
