Print Request Interface Report
How to print: Select Submit at the Work with Catalog Request Interface Screen.
For more information: See the sample report in PDF format.
Contents:
• File type
• Entity
• Source
• For each type, entity, and source combination, the total number of catalog request interface records:
• available to be processed by the CATALOGREQ job (error-free)
• in error
• total records in the file at the time the job was run
• number of catalog requests created
• number of records whose Create catalog request? flags were unselected
• Totals for the file type
Print Catalog Request Interface Errors Report
Contents:
• File type
• Entity
• Sequence number for the catalog request record
• Name and address
• Source code
• Offer
To review the errors for each request listed, use the Change Catalog Request Screen.
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
