Using the Financial Data Interface
Purpose: Use the financial data interface to extract invoice information for the current date or for a range of dates.
Periodic function: To perform the extract as part of a periodic process, you must first create a periodic function for the program FNR0008. You can then assign the periodic function to a periodic process, which you can run daily to capture all invoices for that system date. See Working with Periodic Functions (WPER) for an overview on working with periodic functions.
For more information: :
• Working with Periodic Functions (WPER)
• Working with Periodic Processes (WPPR)
Financial Sales Download Table (IXSLDL)
Note: Each of the fields listed below contains data only if indicated for the record type; otherwise, the field is blank.
Field |
Attributes |
Comments |
Record Types |
Company |
Numeric, 3 positions |
From Invoice Header table. |
all |
Invoice number |
Numeric, 7 positions |
all |
Invoice type |
Alphanumeric, 1 position |
From Invoice Header table: I = invoice C = credit |
all |
Record type |
01 = sale (one record for each Invoice Detail record) 02 = credit (one record for each Invoice Detail record) 03 = Shipping and handling 04 = Pay type (one record for each invoice payment method) 05 = additional charges |
all |
Sequence number |
Numeric, 4 positions |
Generated by the extract; restarts at 1 with each extract. |
all |
Customer number |
Numeric, 9 positions |
From Order Header table. |
all |
Order number |
Numeric, 8 positions |
all |
Entity |
From the division associated with the source code on the Order Header. |
all |
Internet order |
I = internet order; otherwise blank. Based on the setting of the Internet order (Future use sts 1) field in the Order Header table; if this field is set to I, then the order is considered an internet order. |
all |
Invoice date |
Numeric, 8 positions; YYYYMMDD format |
all |
Item |
Alphanumeric, 12 positions |
From Order Detail table. |
01 (sale) and 02 (credit) |
SKU |
Alphanumeric, 14 positions |
Three 4-position fields, separated by blank spaces. |
Long SKU style |
Alphanumeric, 20 positions |
From the L/S style (Long SKU style) SKU table. If no long SKU style is specified for the SKU, then this field is blank. |
Long SKU color |
Alphanumeric, 5 positions |
From the L/S color (Long SKU color) in the SKU table. If no long SKU color is specified for the SKU, then this field is set to 00000. Note: The L/S color in the SKU table is a numeric field. |
Long SKU size |
From the L/S size (Long SKU size) in the SKU table. If no long SKU size is specified for the SKU, then this field is set to 00000. Note: The L/S size in the SKU table is a numeric field. |
Long SKU width |
From the L/S width (Long SKU width) in the SKU table. If no long SKU width is specified for the SKU, then this field is set to 00000. Note: The L/S width in the SKU table is a numeric field. |
SKU second language description |
Alphanumeric, 40 positions |
From the Second language description if no second language description is specified for the SKU; otherwise, from the Second language description. If no second language description is specified for the SKU or the base item, then this field is blank. |
Retail style number |
From the Rtl style (Retail Style #) in the Item table. From the base item, if specified; otherwise, this field is blank. |
Quantity shipped |
The quantity shipped or returned, from the Ship qty (Shipped quantity) in the Invoice Detail table. Absolute value (i.e., both credits and invoices have positive quantities). |
Dollar amount |
Numeric, 13 positions with a 2-place decimal |
Depending on record type: • record types 01 and 02: extended merchandise dollar total calculated by multiplying the Ship qty (Shipped quantity) by the Price from the Invoice Detail table • record type 03: total of Freight, Handling (Handling charge), and Add'l freight (Additional freight charges) from the Invoice Header table • record type 04: total of Merchandise, Freight, Additional freight balance, Additional charges balance, Handling (Handling charge), and Tax from the Invoice Payment Method table • record type 05: total Add'l charges (Additional charges) from the Invoice Header table Note: Absolute value (i.e., both credits and invoices have positive amounts). |
all |
Tax amount |
• From the Tax in the Invoice Header table. The entire tax amount for the invoice is included in the first 01 or 02 record. Note: Absolute value (i.e., both credits and invoices have positive amounts). |
Additional charge code |
Alphanumeric, 2 positions |
From the Code in the Order Additional Charge table. |
05 (additional charges) |
Pay type |
Numeric, 2 positions |
From the Pay method in the Invoice Payment Method table. Not zero-filled (for example, pay type 9 is represented as 9, not 09). |
04 (pay type) |
Credit card number |
Alphanumeric, 16 positions |
From the Credit card # in the Invoice Payment Method table. Used only for credit card payment methods (payment category 2). Note: If you use credit card encryption, the credit card number will not be encrypted because the information in this table is extracted to an outside system. |
04 (pay type) |
Credit card expiration date |
Alphanumeric, 4 positions |
From the CC expiration date in the Invoice Payment Method table. Used only for credit card payment methods (payment category 2); otherwise, this field is set to 0000 for an 04 record. |
04 (pay type) |
Credit card authorization code |
Alphanumeric, 6 positions |
From the Auth # in the Invoice Payment Method table. Used only for credit card payment methods (payment category 2). Included on invoice records only. |
04 (pay type) |
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
