This report lists each work order detail line in error and the reason why the error occurred. You can use this report to fix each work order detail line that was in error and then recreate the work order.
How to print: Select Print Errors on the Create Work Order Details Screen.
Sample report: A sample of this report will be provided at a later date.
Contents:
• Work order number
• Warehouse number and description
• Kit name and description
• Kit quantity
• Sequence number
• Component item and SKU
• Component description
• Kit quantity
• Total quantity
• Location
• Error reason
Purpose: The work order ticket provides information about a finished good work order including:
• the work order number and its expected due date
• the finished good and its component items
• the component locations and quantities taken from each
• the quantity of components damaged during the work process
How to print: On the Work with Work Orders Screen, select Print Ticket for the work order you wish to print a ticket for, or select Print All Unprinted to print all tickets that have not yet been printed for existing work orders.
For more information: See the sample report in PDF format.
Contents:
• work order number
• item/SKU number
• item description
• warehouse
• buyer
• date printed
• order quantity
• date ordered
• date due
• component/SKU
• component description
• quantity per finished good
• quantity required per location
• location
• quantity pulled
• workorder pulled by
• produced by
• received in workcenter by (a workcenter is an area within the warehouse where the finished good is assembled)
• total hours
• item
• waste product (a component that was damaged during the finished good work order process)
• waste product quantity
• waste product location
• bind (a binder used during the finished good work order process)
• bind quantity
• bind location
• total quantity
• total location
• receipts
• receipt date
• receipt quantity
• receipt location
• reviewed by
• inspected by
• entered by
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
