In this part:
• Entering Catalog Requests (WCAT) shows you how to use the Catalog Request screens to create catalog requests for new and existing customers, and to change, delete, or display catalog request records.
• Processing Catalog Requests (PCAT) shows you how to use the Process Catalog Requests screen, discusses printing options, and shows you how to reset printed requests so that you can reprint labels, if needed.
• Deleting All Printed Catalog Requests (DCAT) discusses the screen you use to delete all printed catalog requests at one time.
• Working with the Catalog Request Interface (WCRU) discusses processing catalog requests you receive through an interface with Order Management System.
• Catalog Request History Options describes the two catalog request-related options, Purge Catalog Request History (PCRH) and Purge Catalog Request History (PCRH).
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
