CyberSource Point-to-Point Integration
CyberSource Point-to-Point integration allows you to process authorization and deposit transactions between Order Management System and CyberSource using point-to-point communication. Authorization and deposit processing remains the same in Order Management System; however, instead of using integration layer jobs to process the transactions and send the transactions to the service bureau via the queues defined for the integration layer job, Order Management System communicates with CyberSource via web services using the CyberSource Simple Order API Client for Java to send the transactions directly to the CyberSource system for processing.
Proxy server: When processing payment transactions, you can define a proxy server to act as an intermediary in order to increase security. Order Management System sends transactions to the proxy server and the proxy server sends the transactions along to the payment processor. The PROXY_HOST and PROXY_PORT properties in Working with Admin Properties (CPRP) allow you to define the IP address and port number used to connect to the proxy server during payment processing. If these properties are blank, the system does not route payment transactions through a proxy server and instead calls the payment processor directly.
The CyberSource integration supports the following transactions for credit cards and debit (switch) cards:
OROMS Transaction
CyberSource Transaction
See:
token request
paySubscriptionCreate
Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1)
authorization request:
         online
         batch
         token and authorization
ccAuthService
Performing Online Credit Card Authorizations and Using Batch Authorization
deposit request:
         debit
         credit
         authorization and debit
ccCaptureService
ccCreditService
Processing Auto Deposits (SDEP)
authorization reversal request
ccAuthReversalService
Credit Card Authorization Reversal
The integration also supports:
Process
See:
level II and level III processing
Level II and III Discounting
multicurrency
Multi Currency by Offer (E03)
card identification (CSV/CSP) for online transactions
Credit Card Security Service (CID, CVV2, CVC2)
Verified by Visa and MasterCard Secure Code programs
Credit Card Authentication Service
full address verification (AVS)
Address Verification Service (AVS)
deferred and installment billing
Deferred/Installment Billing Overview
Decision Manager
CyberSource Decision Manager Fraud Scoring
Supported version: The CyberSource Point-to-Point integration in Order Management System 19.2 or higher uses version 1.161 of the CyberSource Transaction XSD.
In this topic:
         CyberSource Point-to-Point Integration Setup
         CyberSource Point-to-Point Tokenization Process
         CyberSource Point-to-Point Authorization Process
         CyberSource Point-to-Point Deposit Process
         CyberSource Point-to-Point Authorization Reversal Process
         Subsequent Authorization Requests to CyberSource
         Sample CyberSource Transactions
         CyberSource Message Layouts
         CyberSource Token Request (paySubscriptionCreate) XML Message
         CyberSource Token Response (paySubscriptionCreate) XML Message
         CyberSource Authorization Request (ccAuthService) XML Message
         CyberSource Authorization Response (ccAuthService) XML Message
         CyberSource Token and Authorization Request (paySubscriptionCreate and ccAuthService) XML Message
         CyberSource Token and Authorization Response (paySubscriptionCreate and ccAuthService) XML Message
         CyberSource Debit Deposit Request (ccCaptureService) XML Message
         CyberSource Debit Deposit Response (ccCaptureService) XML Message
         CyberSource Credit Deposit Request (ccCreditService) XML Message
         CyberSource Credit Deposit Response (ccCreditService) XML Message
         CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message
         CyberSource Authorization and Deposit Response (ccAuthService and ccCaptureService) XML Message
         CyberSource Authorization Reversal Request (ccAuthReversalService) XML Message
         CyberSource Authorization Reversal Response (ccAuthReversalService) XML Message
Before you can use the CyberSource Point-to-Point integration, you must complete the required setup.
         Service Bureau Settings
         CyberSource Interface Properties
         Work with Pay Types (WPAY)
         Work with Order Types (WOTY)
         Security Key
For more information: See the CyberSource Simple Order API Client Developer Guide for more setup information, including recommendations on logging levels.
Use Defining Authorization Services (WASV) to create a service bureau for the CyberSource service that you will use to process authorizations and deposits via point-to-point communication.
CyberSource Setup using Point-to-Point
Service code
Must be CYB.
Application
Enter Auth/Deposit.
Merchant ID
Supplied by CyberSource.
Charge description
Enter CYBERSOURCE.
Request token
Select this field to perform credit card tokenization; otherwise, leave unselected.
Void auth at deposit
Select this field to void any unused portion of an authorization at deposit time; see Void Unused Authorization After Initial Deposit for processing details.
Send reversal
Select this field to perform a credit card authorization reversal when you process a cancellation associated with a credit card payment or deactivate a credit card payment; see Credit Card Authorization Reversal for processing details.
Integration layer processes
Leave these fields blank.
Media type
Enter Communication.
Batch/online
Enter Online or Batch.
Immediate response
Must be selected.
Immediate deposit
Leave unselected.
Primary authorization service
Should be blank.
Communication type
Enter Payment Link to indicate messages sent to and from CyberSource are processed directly.
Response time
Defines the timeout property passed to CyberSource; this is the number of seconds Order Management System waits for a response from CyberSource. The recommended setting is 30 seconds. Note: Order Management System does not wait the entire response time if it is not necessary.
Test mode?
Not used for the CyberSource integration; the CYB_PAY_LINK_SERVICE_SEND_TO_PRODUCTION setting in Working with Customer Properties (PROP) defines whether transactions are sent to the CyberSource TEST server or PRODUCTION server.
Override Reconciliation Id
Indicates whether to pass the invoice number or alternate order ID as the reconciliationID in a debit deposit, credit deposit, or authorization and deposit request to CyberSource, or not to pass either of these fields.
Country codes
Define a cross reference between your country code and the country code used by CyberSource.
Note:  This option also indicates whether a service bureau performs address verification processing for the country; however, regardless of the AVS setting, CyberSource always performs address verification.
See Defining Authorization Service Countries.
Currency codes
Define a cross reference between your currency code and the currency code used by the service bureau; see Defining Authorization Service Currencies.
Merchant ID Override
Define a merchant ID override for the different entities in your company; see Defining Merchant ID Overrides.
Paytype codes
Define a cross reference between your pay type code and the pay type code used by the service bureau; see Defining Vendor Paytype Codes.
Response codes
Define the reasons that the service bureau approves (authorizes) or declines a transaction. The codes are assigned to each transaction by the service bureau when approving or declining the request; see Defining Vendor Response Codes.
The Order Management System integration with CyberSource uses the CyberSource Simple Order API Client for Java as the communication protocol. The following properties are required to communicate with CyberSource.
CYB_PAY_LINK_SERVICE_KEY_DIRECTORY
The location of the encrypted security key file used by the web service API program to validate and secure transactions from Order Management System.
Note:  When defining the location, use a single forward slash.
Example:  /domain/conf/OMSFiles/Integrations/Cybersource/Key/, where domain is the WebLogic domain directory for Order Management System.
CYB_PAY_LINK_SERVICE_LOG_DIRECTORY
The location of the log written by the web service API program. Use this log to review the transactions processed between Order Management System and CyberSource.
Data security: For data security, Order Management System masks credit card information in this log.
Example:  /domain/conf/OMSFiles/Integrations/Cybersource/Log/, where domain is the WebLogic domain directory for Order Management System.
The name of the external system. Set this to CyberSource.
CYB_PAY_LINK_SERVICE_ENABLE_LOG
Defines whether the web service logs request and response messages.
true = Order Management System writes request and response messages to the CyberSource log.
false = Order Management System does not write request and response messages to the CyberSource log.
Data security: Set this value to false unless you are troubleshooting the Order Management System integration with CyberSource. Once you are done troubleshooting, delete any log files that are created.
Defines whether transactions are sent to the CyberSource TEST server or PRODUCTION server.
true = Order Management System sends transactions to the CyberSource PRODUCTION server.
false = Order Management System sends transactions to the CyberSource TEST server.
CyberSource Decision Manager Fraud Scoring Settings
Decision Manager Fraud Scoring uses the following settings.
CYB_PAY_LINK_DECISION_MANAGER_ENABLED
Defines whether CyberSource Decision Manager Fraud Scoring processing is enabled in the Order Management System Point-to-Point integration with CyberSource.
false = the Order Management System Point-to-Point integration with CyberSource does not support Decision Manager processing in CyberSource. Order Management System sends all authorization transactions to CyberSource with the decisionManager_enabled tag set to false, indicating Decision Manager processing should not occur. However, you can use CyberSource’s Decision Manager for authorization transactions you process on your web storefront.
true = the Order Management System Point-to-Point integration with CyberSource supports Decision Manager processing in CyberSource. Order Management System sends all authorization transactions to CyberSource with the decisionManager_enabled tag set to true, indicating Decision Manager processing should occur. See CyberSource Point-to-Point Decision Manager Process for more details.
CYB_PAY_LINK_DECISION_MANAGER_MERCHANT_ID_OVERRIDE
The merchant ID provided by CyberSource to use during Decision Manager Fraud Scoring processing. Used as the portfolio merchant ID in the URL, and the child merchant ID is e passed as report parameter.
If this setting is blank, the system uses the following hierarchy to determine the merchant ID to use:
         Merchant # field in the CC Paytype Cross Ref table
         Merchant ID field in the Merchant ID Override table
         Merchant ID field in the Authorization Services table
CYB_PAY_LINK_DECISION_MANAGER_KEY
A key, generated in CyberSource Decision Manager, that is used to authenticate the CyberSource Decision Manager Update periodic function (CYBDMUP).
CYB_PAY_LINK_DECISION_MANAGER_SECRET_KEY
CYB_PAY_LINK_DECISION_MANAGER_SEND_TO_PRODUCTION
Defines whether transactions are sent to the CyberSource Decision Manager TEST server or PRODUCTION server.
true = Order Management System sends transactions to the CyberSource Decision Manager PRODUCTION server.
false = Order Management System sends transactions to the CyberSource Decision Manager TEST server.
Use Working with Pay Types (WPAY) to define the CYB authorization and deposit service for each CyberSource pay type.
In order to perform online authorization on web orders, the Online Authorization setting for the order type on the web order must be set to Without Window. See Establishing Order Types (WOTY) for more information on setting up an order type.
Security Key
In order for the web service to work, you must generate a security key on the CyberSource Business Center web site. This file must be placed in the directory on the Order Management System application server that is defined in the CYB_PAY_LINK_SERVICE_KEY_DIRECTORY property.
See Appendix A - Generating and Verify Security Keys in the CyberSource Simple Order API for Java Developers Guide for instructions on how to generate a key.
If you have set the CYB_PAY_LINK_DECISION_MANAGER_ENABLED to true, you must complete the following setup for fraud scoring.
Order hold reasons for fraud scoring:
Hold Code
Assigned When
FC
Fraud Cancellation Hold
The CyberSource Decision Manager Update Process retrieves order information from Decision Manager for orders that were marked as review during the CyberSource Decision Manager Review Process. If the new decision assigned to the order is REJECT, indicating a user in Decision Manager reviewed the order and rejected the order, Order Management System:
         cancels the entire order using the cancel reason code defined in the Fraud Score Cancel Reason Code (M14) system control value.
         If the entire order cannot be cancelled, the system places the order on FC Fraud Cancellation hold.
FS
Fraud Scoring Hold
The online authorization transaction sent to CyberSource for the credit card payment on the order was evaluated by CyberSource Decision Manager Fraud Scoring and, based on the Decision Manager Order Profile settings, requires review for possible fraud.
Note:             These order hold reasons are delivered with the system in Establishing Order Hold Reason Codes (WOHR); see Introducing Order Hold Reason Codes for an overview.
Vendor response codes for fraud scoring: Define the reasons that the CyberSource service bureau declines a transaction due to fraud scoring; see Defining Vendor Response Codes.
Reason Code
Description
400
Fraud Score Exceeds Threshold.
Enter hold reason FS Fraud Scoring Hold to place the order on hold when an online authorization transaction receives this vendor response code from CyberSource.
480
Review Fraud Scoring.
481
Rejected by Decision Manager.
Enter hold reason FS Fraud Scoring Hold to place a web order on hold when an online authorization transaction receives this vendor response code from CyberSource.
Define a pop-up window message to display on the Select Authorization Response Option Window.
Note:  If the reason code returned from CyberSource is 481, the system deactivates the payment method on the order and requires you to enter another form of payment before you can accept the order.
System control values for fraud scoring:
System Control Value
Description
Enter the cancel reason code the system assigns to an order that is automatically canceled due to the fraud scoring results from CyberSource Decision Manager.
Cancel reason codes are defined in and validated against the Cancel Reason Code table; see Establishing Cancel Reason Codes (WCNR).
Product Classification for Fraud Scoring (M15)
Defines the product classification Order Management System sends to CyberSource during CyberSource Decision Manager Fraud Scoring.
         ITM CLASS = Order Management System maps the item’s item class description to the ProductCode in the CyberSource Authorization Request (ccAuthService) XML Message when CyberSource Decision Manager Fraud Scoring is enabled.
         ITM CATGRY = Order Management System maps the item’s item category description to the ProductCode in the CyberSource Authorization Request (ccAuthService) XML Message when CyberSource Decision Manager Fraud Scoring is enabled.
Note:  It is your responsibility to set up the item class description or item category description to match the correct value required by CyberSource Decision Manager.
Product classification for fraud scoring: Based on the setting of the Product Classification for Fraud Scoring (M15) system control value, set up the item class description or item category description to match the correct value required by CyberSource Decision Manager.
Product codes used by CyberSource services are:
         adult_content: Adult content.
         coupon: Coupon applied to the entire order.
         default: Product classification has not been defined for the product.
         electronic_good: Electronic product other than software.
         electronic_software: Software distributed electronically rather than on disks or other media.
         handling_only: Fee that you charge the customer to cover administrative selling costs.
         service: Service that you perform for the customer.
         shipping_and_handling: The shipping portion is the charge for shipping the product to the customer. The handling portion is the fee you charge the customer to cover your administrative selling costs.
         shipping_only: Charge for transporting tangible personal property from your location to the customer. You must maintain documentation that clearly establishes the location where the title to the property passed from you to the customer.
         subscription: Subscription to a web site or other content.
Ship via service level for fraud scoring: Use the Create Ship Via (2 of 2) Screen to define a Decision Manager Level field for each ship via. Order Management System maps the Service Level for the ship via to the shipTo ShippingMethod in the CyberSource Authorization Request (ccAuthService) XML Message when the CyberSource Decision Manager Fraud Scoring is enabled. Valid values are:
         sameday: Courier or same day service.
         oneday: Next day or overnight service.
         twoday: Two day service.
         threeday: Three day service.
         lowcost: Lowest cost service
         pickup: Store pickup
         other: Other shipping method.
         none: No shipping method because product is a service or subscription.
When a ShippingMethod is defined for a ship to in the ccAuthService message, the shipping address is not automatically added to the Decision Manager negative list. You can add a shipping address to the negative list using the Transaction Marking Tool; see Marking Order Data During Order Review in the Case Management section of the Decision Manager User Guide.
Note:             To use a custom value, create a Decision Manager custom rule with the shipping method order element.
CyberSource Decision Manager Update periodic function: Use the Work with Periodic Function (WPER) menu option to create the CYBDMUP CyberSource Decision Mgr Upd periodic function (program name PFCYBDMUP). Assign this periodic function to a periodic process. Schedule this periodic process to run during the time period when users in Decision Manager are releasing orders from hold; for example, you might wish to run this every hour during business hours.
Note:             The CYBDMUP CyberSource Decision Mgr Upd periodic function retrieves information on orders that have been evaluated by the fraud scoring process and managed in Decision Manager using the CyberSource Decision Manager On Demand Conversion Report. The CyberSource Decision Manager On Demand Conversion Report is available in the CyberSource test environment for 2 weeks and is available in the CyberSource production environment for 18 months.
Decision Manager setup in CyberSource: In addition to the setup required in Order Management System to use CyberSource Decision Manager, you must complete setup in the CyberSource Business Center, including creating a custom report for conversion detail, for example:
         Select the Create Report option.
         Name the report ConversionDetailReport.
         Select a file format of XML.
         Select the Conversion Detail Report as the report type.
         Select a recurring report subscription with a subscription frequency of daily.
         Set the subscription start time and time zone.
         Under Advanced Report Features, select all.
The exact steps and options may vary. Contact your CyberSource representative for more information on the setup required in the CyberSource Business Center to use the Decision Manager application.
The Order Management System integration with CyberSource supports credit card authorization reversal. See Credit Card Authorization Reversal for an overview and processing details. The setup required for credit card authorization reversal is as follows.
For the CYB service bureau in Defining Authorization Services (WASV), select the Send reversal field to indicate the CyberSource service bureau supports credit card authorization reversal.
System control value for authorization reversal:
Description
Use Activation / Reversal Batch Processing (I50)
Must be unselected. If unselected, you must start the SVC_REVSL integration layer job to monitor for new authorization reversal triggers to process immediately.
The Order Management System integration with CyberSource supports credit card tokenization using a 19 digit token. See Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1) for an overview and processing details. The setup required for credit card tokenization is as follows.
         The CyberSource integration with Order Management System supports a 19 digit token. Contact CyberSource Customer Support to have your account configured for 19 digit tokens instead of 22 digit values for the subscription ID. The size of the subscription ID affects all customer profiles you create.
         A CyberSource token (subscription ID) never expires, and is removed from the CyberSource system only when deleted by the merchant. Although the token itself never expires, the card information associated with it, such as credit card expiration date, may, requiring an update.
For the CYB service bureau in Defining Authorization Services (WASV), select the Request token field to indicate the CyberSource service bureau supports credit card tokenization. You can select this field only if the Use Credit Card Tokenization (L18) system control value is selected.
System control values for credit card tokenization:
Description
Select this system control value to replace the credit card number in the Order Management System database with a token provided by CyberSource. In addition, the number will be encrypted if you have credit card encryption enabled.
Require Credit Card Token (L40)
Select this system control value to require a token for a credit card number. This ensures that credit card numbers are never stored in the Order Management System database and follows full PCI compliance and maximum security of sensitive data.
If the Credit Card Tokenization Process is unable to replace the card number with a token, the system:
         During Order Entry/Maintenance, Customer Memberships, and Change Invoice Payment Method: displays the Tokenization Warning window, requiring you to enter a different form of payment.
         During web order processing: replaces the credit card number with the text TOKENIZATION FAILED and places the order in an error status with the reason Invalid Credit Card. You can correct the credit card payment method and resend the card for tokenization in batch order entry.
Deselect this system control value to allow the system to accept a credit card number that has not been replaced with a token. The credit card number will be replaced by a token during authorization processing or when you use Work with Batch Tokenization (WBTK).
Note:  If you change the setting of this system control value, you must stop and restart the ORDER_IN integration layer job before your change takes effect for orders received through the Generic Order Interface (Order API).
Order Management System performs the following steps when you perform tokenization using point-to-point communication with CyberSource.
Note:             CyberSource refers to a token as a customer profile which has a submitter’s ID or token. You can configure your account in CyberSource to perform preauthorization and fraud checking based on the payment method for the new customer profile.
For more information: See Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1) for an overview on tokenization and processing details.
1.
Order Management System looks at the Communication type field for the CYB service bureau to determine how transactions are processed between Order Management System and the CyberSource service bureau.
For the CyberSource integration with Order Management System, the setting is Payment Link indicating Point-to-Point communication. The system sends token transactions directly to the CyberSource service bureau.
2.
If the Communication type field for the service bureau is Payment Link, Order Management System creates the CyberSource Token Request (paySubscriptionCreate) XML Message.
Note:  Order Management System removes any non-standard keyboard characters from the XML message before sending it to CyberSource.
The system also writes the token request message to the Trace Log if its Logging Level is set to DEBUG. Order Management System masks the card number in the log based on the setting of the Display Partial Credit Card Number in Logs (J16) system control value.
         If the Display Partial Credit Card Number in Logs (J16) system control value is selected in any company, the system displays the last four digits of the credit card number in the log; for example *************1111. If the credit card number is 4 digits or less, the entire credit card number displays as **********.
         If the Display Partial Credit Card Number in Logs (J16) system control value is unselected in every company, the system replaces the credit card number in the log with the word ***REMOVED***.
3.
Order Management System uses the settings in the CyberSource Interface Properties to send the CyberSource Token Request (paySubscriptionCreate) XML Message directly to the CyberSource service bureau.
Communication failure: The system tries to connect to CyberSource 3 times before flagging a transaction with a 150 General System Failure response code. If a transaction fails, any subsequent transactions will continue to process.
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG property setting is set to true, the system writes the token request message to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
4.
Once Order Management System sends the token request to CyberSource, the system waits for a response to the token request using the number of seconds defined in the Response time field for the CYB service bureau.
5.
The CyberSource service bureau receives the CyberSource Token Request (paySubscriptionCreate) XML Message, processes the request, and sends the CyberSource Token Response (paySubscriptionCreate) XML Message back to Order Management System.
6.
Order Management System receives the CyberSource Token Response (paySubscriptionCreate) XML Message and processes the response.
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG property setting is set to true, the system writes the token response to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
The system writes the token response to the Trace Log if its Logging Level is set to DEBUG. Order Management System masks the card number in the log based on the setting of the Display Partial Credit Card Number in Logs (J16) system control value.
7.
See the Security document for the updates that take place in Order Management System, depending on whether the tokenization transaction was approved or declined by the service bureau.
Order Management System performs the following steps when you process authorizations using point-to-point communication with CyberSource.
Request token? If you do not use credit card tokenization with CyberSource, the system sends a CyberSource Authorization Request (ccAuthService) XML Message to CyberSource.
If you use credit card tokenization with CyberSource and:
         The credit card number for the payment requesting authorization has already been replaced with a token, the system sends a CyberSource Authorization Request (ccAuthService) XML Message to CyberSource.
         The credit card number for the payment requesting authorization has not been replaced with a token, the system sends a CyberSource Token and Authorization Request (paySubscriptionCreate and ccAuthService) XML Message to CyberSource.
Perform fraud scoring? If the CYB_PAY_LINK_DECISION_MANAGER_ENABLED property setting is true, the system sends online authorization transactions to CyberSource with the decisionManager_enabled tag set to true, indicating Decision Manager processing should occur. See CyberSource Decision Manager Fraud Scoring for processing details.
Manual authorizations: CyberSource supports manual authorizations only if the manual authorization contains an authorization number, authorization date, authorization amount, and a valid authorization request ID (transaction ID) from CyberSource. If the manual authorization is not associated with a valid transaction ID from CyberSource, CyberSource will reject the deposit transaction because it is not associated with a valid authorization from CyberSource.
To define a manual authorization for a credit card payment that uses CyberSource as its service bureau:
         Orders received through the Generic Order Interface (Order API) must contain an auth_number, auth_date, auth_amount and a transaction_id that was obtained from CyberSource.
         Orders entered in Order Management System should go out to CyberSource for authorization before deposit processing. You can perform authorization during order entry, order maintenance or pick slip generation.
For more information: See:
         Performing Online Credit Card Authorizations for an overview on online authorizations and processing details.
         Using Batch Authorization for an overview on batch authorizations and processing details.
1.
For the CyberSource integration with Order Management System, the setting is Payment Link indicating Point-to-Point communication. The system sends authorization transactions directly to the CyberSource service bureau.
2.
If the Communication type field for the service bureau is Payment Link, Order Management System creates the authorization request.
Credit Card Tokenization?
-      The credit card number for the payment requesting authorization has already been replaced with a token, the system creates the CyberSource Authorization Request (ccAuthService) XML Message.
-      The credit card number for the payment requesting authorization has not been replaced with a token, the system creates the CyberSource Token and Authorization Request (paySubscriptionCreate and ccAuthService) XML Message. In this situation, the system sends an authorization request and also requests to replace the credit card number with a token.
Decision Manager Fraud Scoring?
If the CYB_PAY_LINK_DECISION_MANAGER_ENABLED property is true and you are processing an online authorization transaction, the system sends the online authorization transaction to CyberSource with the decisionManager_enabled tag set to true, indicating Decision Manager processing should occur. See CyberSource Decision Manager Fraud Scoring for processing details.
3.
The system writes the authorization request message to the Trace Log if its Logging Level is set to DEBUG. Order Management System masks the card number in the log based on the setting of the Display Partial Credit Card Number in Logs (J16) system control value.
4.
Order Management System uses the settings in Working with Customer Properties (PROP) to send the authorization request directly to the CyberSource service bureau.
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG property is set to true, the system writes the authorization request message to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
5.
Once Order Management System sends the authorization request to CyberSource, the system waits for a response to the authorization request using the number of seconds defined in the Response time field for the CYB service bureau.
6.
The CyberSource service bureau receives the authorization request, processes the request, and sends the authorization response back to Order Management System.
         If the authorization was processed using a token, CyberSource sends the CyberSource Authorization Response (ccAuthService) XML Message to Order Management System.
         If the authorization also requested a token, CyberSource sends the CyberSource Token and Authorization Response (paySubscriptionCreate and ccAuthService) XML Message to Order Management System.
7.
Order Management System receives the authorization response and processes the response:
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG setting in the property is set to true, the system writes the authorization response to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
The system writes the authorization response to the Trace Log if its Logging Level is set to DEBUG. Order Management System masks the card number in the log based on the setting of the Display Partial Credit Card Number in Logs (J16) system control value.
8.
See:
Online authorizations: What Happens When a Credit Card is Approved? and What Happens When a Credit Card is Declined? for the updates that take place in Order Management System, depending on whether the online authorization transaction was approved or declined by the service bureau.
Decision Manager Fraud Scoring: CyberSource Decision Manager Fraud Scoring for the updates that take place in Order Management System, depending on the fraud score assigned to the online authorization transaction.
Batch authorizations: Approved Authorizations and Declined Authorizations for the updates the take placed in Order Management System, depending on whether the batch authorization transaction was approved or declined by the service bureau.
Tokenization: Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1) for the updates that take place in Order Management System, depending on whether a token is returned in the authorization transaction.
Placing the credit card on hold: The credit card pay type may be placed on hold if the credit card is not approved, the AVS verification fails, or if the credit card identification fails. See Hierarchy for Placing the Credit Card On Hold for more information on the hierarchy the system uses to determine if the credit card pay type should go on hold.
Decision Manager is a service provided by CyberSource that allows you to use pre-defined and custom business rules to automatically identify orders that require further screening for fraud.
Based on the Decision Manager business rules, the order and payment information included in the authorization transaction, and the reply data received from the credit card authorization, Decision Manager determines which orders:
         have a low risk for fraud and can be immediately processed,
         have a higher probability for fraud and should be placed on hold for further review,
         are likely fraudulent and should be canceled.
Authorization transactions that are placed on hold for further review are assigned to a case management work queue where a user can review the transaction and decide whether to accept or reject it.
For more information: Contact your CyberSource representative for the following documentation:
         Decision Manager Planning Guide for more information on how to implement Decision Manager to suit your business requirements and the complex processing that occurs in Decision Manager when evaluating an order for fraud.
         Decision Manager User Guide for more information on how to configure your Decision Manager Account in the Business Center and how to use Decision Manager for case management tasks.
         Decision Manager Reporting Guide for more information on the reports that are generated when you use Decision Manager services.
CyberSource Decision Manager Process
The CYB_PAY_LINK_DECISION_MANAGER_ENABLED property defines whether CyberSource Decision Manager Fraud Scoring processing is enabled in the Order Management System Point-to-Point integration with CyberSource.
         If this setting is false, the Order Management System Point-to-Point integration with CyberSource does not support Decision Manager processing in CyberSource. Order Management System sends all authorization transactions to CyberSource with the decisionManager_enabled tag set to false, indicating Decision Manager processing should not occur. However, you can use CyberSource’s Decision Manager for authorization transactions you process on your web storefront.
         If this setting is true, the Order Management System Point-to-Point integration with CyberSource supports Decision Manager processing in CyberSource. Order Management System sends all online authorization transactions to CyberSource with the decisionManager_enabled tag set to true, indicating Decision Manager processing should occur.
If the decisionManager_enabled tag in an online authorization request is set to true, Order Management System performs additional processing during the CyberSource Point-to-Point Authorization Process.
         Decision Manager Fraud Scoring occurs during online authorization processing only and does not occur for any batch authorization transaction.
         CyberSource performs Decision Manager Fraud Scoring after the online authorization transaction and any additional processing such as address verification is approved; if the online authorization transaction or additional processing is not approved, CyberSource does not perform Decision Manager Fraud Scoring against the order.
         The Decision Manager response and reason code are not stored in Order Management System.
         The Decision Manager Fraud Scoring process below describes fraud scoring for online transactions that occur during interactive order entry or when a web order is received into Order Management System. For web orders that receive an online authorization transaction before being sent to Order Management System:
         If the web authorization transaction was approved by Decision Manager, the order is received into Order Management System with no additional processing.
         If the web authorization transaction was marked as REVIEW by Decision Manager, the order is received into Order Management System with the FS Fraud Scoring hold reason code so that the order can be placed in a Held status.
         If the web authorization transaction was marked as REJECT by Decision Manager, the order is not sent to Order Management System.
1.
When Order Management System creates the online authorization request to send to CyberSource, if Decision Manager is enabled, the system includes additional information in the CyberSource Authorization Request (ccAuthService) XML Message:
         the decisionManager enabled tag is set to true
         billTo name and address information
         shipTo name and address information
         item information
2.
If the online authorization transaction is approved, the system uses the Decision Manager settings in Working with Customer Properties (PROP) to connect to the CyberSource Decision Manager application.
3.
Decision Manager uses the information in the CyberSource Authorization Request (ccAuthService) XML Message, the reply data received from the credit card authorization, and any additional processing to evaluate the order for fraud scoring. Decision Manager automatically accepts an order unless a business rule causes the order to be rejected or marked for review.
         Decision state REJECT indicates the order failed decision manager fraud scoring. Even if the authorization was approved, the order should not be processed.
         Decision state REVIEW indicates the order is flagged as possible fraud and needs to be reviewed by a user.
Orders that receive a REVIEW decision are assigned to a case management work queue where a user can review the order and decide whether to accept or reject it.
4.
CyberSource sends the CyberSource Authorization Response (ccAuthService) XML Message back to Order Management System, including the results of the Decision Manager fraud score.
The replyMessage decision setting in the response indicates whether the online authorization transaction was approved or declined by Decision Manager:
         ACCEPT indicates CyberSource approved the transaction.
         REVIEW indicates CyberSource Decision Manager marked the order for review for further analysis. The credit card authorization remains approved and valid, but the order may or may not be processed at a later time.
         ERROR indicates an error occurred while CyberSource was processing the transaction.
         REJECT indicates CyberSource Decision Manager rejected the transaction.
If the decision was REVIEW or REJECT, the replyMessage reasonCode provides additional information for the decision.
         400 indicates the fraud score exceeds your threshold.
         480 indicates the order is marked for review by Decision Manager.
         481 indicates the order is rejected by Decision Manager.
The response includes additional information related to Decision Manager in the afsReply, such as the total fraud score calculated for the order, the risk associated with the customer’s email domain, information that affected the score of the order, and whether the customer has a high order velocity.
Note:  The ccAuthReply reasonCode provides the reason the authorization transaction was approved or rejected by the authorization service; see CyberSource Point-to-Point Authorization Process for more information on the processing that occurs when an credit card authorization is approved or declined by CyberSource.
5.
Order Management System receives the online authorization response and processes the response.
         If the decision setting in the response is REVIEW (reason code 480), Order Management System places the order on FS Fraud Scoring hold. See CyberSource Decision Manager Review Process for more information.
         If the decision setting in the response is REJECT (reason code 481), Order Management System deactivates the credit card payment and requires you to add another form of payment before you can accept the order. See CyberSource Decision Manager Reject Process for more information.
         If the decision setting in the response is ACCEPT, Order Management System accepts the order; see What Happens When a Credit Card is Approved? for the updates that take place in Order Management System when an online authorization transaction is approved by the service bureau.
When an online authorization transaction is marked as REVIEW by Decision Manager, Order Management System:
         places the order on hold using the hold reason defined for the REVIEW vendor response (response code 480). Typically, you would define hold reason FS Fraud Scoring hold for vendor response 480.
         creates an order transaction history message indicating the order was placed on FS Fraud Scoring Hold; for example:
Type
Transaction Note
Amount
User
HOLD
SYS HLD - Fraud Scoring Hold
120.00
your admin user
Orders that receive a REVIEW decision are assigned to a case management work queue in Decision Manager. A user must log in to Decision Manager to review the order and decide whether to accept or reject it.
At scheduled intervals, run the CYBDMUP CyberSource Decision Manager Update periodic function to retrieve information on orders that have been evaluated by the fraud scoring process and managed in Decision Manager since the last time the periodic function was run.
Note:             Run this periodic function by company. Decision Manager returns information for all Order Management System orders across companies; however, Order Management System only processes the orders in the current company.
The periodic function:
         uses the CYB_PAY_LINK_SERVICE_SEND_TO_PRODUCTION property to determine whether to connect to the test or production server.
         uses the CYB_PAY_LINK_DECISION_MANAGER_KEY and CYB_PAY_LINK_DECISION_MANAGER_SECRET_KEY properties to connect to Decision Manager.
         requests order information in the Decision Manager On Demand Conversion Report based on the merchant ID defined in the CYB_PAY_LINK_DECISION_MANAGER_MERCHANT_ID_OVERRIDE property. If this setting is blank, the system uses the following hierarchy to determine the merchant ID to use:
Identifying orders: Order Management System uses the RequestID returned from Decision Manager and the TransactionID in the Authorization History table to match the order information returned from Decision Manager to an order in Order Management System. The system processes responses from Decision Manager only for the company where you executed the periodic function.
Log: You can review the information sent to CyberSource and the response received from CyberSource in the TRACE log if its logging level is set to DEBUG; for example:
The CyberSource Decision Manager Update process sends the request Information to CyberSource.
The CyberSource Decision Manager Update process receives the information from CyberSource, for example: "originalDecision":"REVIEW","newDecision":"ACCEPT".
If new decision is ACCEPT: If a user in Decision Manager accepted the order, Order Management System:
         releases the order from the FS Fraud Scoring hold.
         creates an order transaction history message indicating the order was released from hold; for example:
Type
Transaction Note
Amount
User
RELEASE
Removed Fraud Scoring hold
your admin user
         creates one or more order messages for any notes or reviewer comments made on the order in Decision Manager; for example:
Messages
Print
User
APPROVED BY ABC | ISSUER VERIFIED NAME AND ADDRESS
Nowhere
your admin user
If new decision is REJECT: If a user in Decision Manager rejected the order, Order Management System:
         If the cancel reason code reduces demand, the order status and line status update to Closed and the quantity ordered is decreased by the quantity cancelled; 0 displays if the entire line was cancelled. The quantity cancelled is not updated.
         If the cancel reason code does not reduce demand, the order status and line status update to Cancelled if the entire order is cancelled; otherwise, the order status and line status update to Closed if part of the order has shipped or was soldout. The quantity ordered is not updated and the quantity cancelled is updated with the cancel quantity.
         creates an order transaction history message indicating the order was cancelled; for example:
Type
Transaction Note
Amount
User
MAINT
System generated cancel processed
your admin user
CANCEL
Cancelled by Fraud Scoring
your admin user
Messages
Print
User
REJECTED BY ABC | FRAUD
Nowhere
your admin user
         If the Send reversal field is selected for the CYB service bureau, performs a Credit Card Authorization Reversal against the credit card payment.
         If the entire order cannot be cancelled, for example a pick exists for one or more items on the order, the system places the order on FC Fraud Cancellation hold and creates an order transaction history message indicating the order was placed on fraud scoring cancellation hold; for example:
Type
Transaction Note
Amount
User
HOLD
Apply Fraud Scoring Cancellation hold
your admin user
Note:             If order information is not returned from CyberSource, the order remains on FS Fraud Scoring hold.
Required report: To support Decision Manager processing and updates through the CYBDMUP periodic function, create a custom report in the CyberSource Decision Manager Portal with the following attributes:
         Report Name: ConversionDetailReport
         File Format: XML
         Report Type: Conversion Detail Report
         Frequency: Recurring report subscription
         Subscription Frequency: Daily
         Subscription Start Time: 12:00 AM
         Subscription Time Zone: Select your time zone
         Advanced Report Features: Check ‘Select All’
When an online authorization transaction is marked as REJECT by Decision Manager, Order Management System:
         deactivates the credit card payment, setting the To charge amount to .01,
         If the Send reversal field is selected for the CYB service bureau, performs a Credit Card Authorization Reversal against the deactivated credit card payment,
         creates an order transaction history message indicating the order was rejected by Decision Manager; for example:
Type
Transaction Note
Amount
User
SYSTEM UPDATE
FRAUD SCORE - REJECTED BY DECISION MANAG
120.00
your admin user
         during interactive order entry, displays the Select Authorization Response Option window. The message at this window should indicate the order has been rejected by Decision Manager. Regardless of whether you select Accept Order or Edit Order on this window, the system returns you to the order and requires you to add another form of payment before you can accept the order. Note: The system displays the Select Authorization Response Option window even if a vendor response pop up window message has not been defined and the Online authorization field for the order type is not set to Window (online eligible and display window).
         during web order processing, places the order on hold using the hold reason defined for the REJECT vendor response (response code 481) since the credit card payment on the order has been deactivated. Typically, you would define hold reason FS Fraud Scoring hold for vendor response 481. You need to add another form of payment before you can release the order from hold. If you try to release the order from hold in Release Held Orders (ERHO) without adding another form of payment, the system displays an error message: No payment methods have been defined for this order.
Order Management System performs the following steps when you process deposits for CyberSource using point-to-point communication.
Type of deposit?
         If the deposit is a debit to the credit card, Order Management System sends a CyberSource Debit Deposit Request (ccCaptureService) XML Message to CyberSource.
         If the deposit is a credit to the credit card, Order Management System sends a CyberSource Credit Deposit Request (ccCreditService) XML Message to CyberSource.
         If the deposit is a debit to the credit card and the deposit amount is greater than the authorization amount, the authorization has expired, or the deposit is for an installment amount, Order Management System sends a CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message to CyberSource.
Request token? If you use credit card tokenization with CyberSource and:
         The credit card number for the payment requesting deposit has already been replaced with a token, the system includes the token in the request sent to CyberSource.
         The credit card number for the payment requesting deposit has not been replaced with a token, the system includes customer and card information in the request sent to CyberSource.
For more information: See Processing Auto Deposits (SDEP) for an overview on deposits and processing details.
1.
Order Management System looks at the Communication type field for the CYB service bureau to determine how transactions are processed between Order Management System and the service bureau. F
For the CyberSource integration with Order Management System, the setting is Payment Link indication Point-to-Point communication. The system sends online authorization transactions directly to the CyberSource service bureau.
2.
If the Communication type field for the service bureau is Payment Link, Order Management System creates the deposit request:
The system writes the deposit request message to the Trace Log if its Logging Level is set to DEBUG. Order Management System masks the card number in the log based on the setting of the Display Partial Credit Card Number in Logs (J16) system control value.
3.
Order Management System uses the settings in the CyberSource Interface Properties to send the deposit request directly to the CyberSource service bureau.
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG property is set to true, the system writes the deposit request message to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
4.
Once Order Management System sends the deposit request to CyberSource, the system waits for a response to the deposit request using the number of seconds defined in the Response time field for the CYB service bureau.
5.
The CyberSource service bureau receives the deposit request, processes the request, and sends the deposit response back to Order Management System.
         If the deposit is a debit to the credit card, CyberSource sends a CyberSource Debit Deposit Response (ccCaptureService) XML Message to Order Management System.
         If the deposit is a credit to the credit card, CyberSource sends a CyberSource Credit Deposit Response (ccCreditService) XML Message to Order Management System.
         If the deposit is a debit to the credit card and the deposit amount is greater than the authorization amount, the authorization has expired, or the deposit is for an installment amount, CyberSource sends a CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message to Order Management System.
6.
Order Management System receives the deposit response and processes the response:
         Matches the deposit response to a deposit record in the CC Deposit Transaction table. When a match is found, the system updates the status of the Credit Card Deposit Transaction record to *RCVD and with the values in the deposit response. Also:
-      If an authorization code is returned in the response that does not match the authorization that was sent, the system creates an Authorization History record.
-      If an authorization exists on the order that was not used (the system sent a CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message to CyberSource because the deposit was a debit to the credit card and the deposit amount was greater than the authorization amount), the system voids the unused authorization(s).
         Completes the AUTO_DEP job and submits the DEP_UPDATE job to the QSYSNOMAX queue to process the remaining updates, such as generating reports. See Batch Deposit Updates.
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG property is set to true, the system writes the deposit response to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
The system writes the deposit response to the Trace Log if its Logging Level is set to DEBUG. Order Management System masks the card number in the log based on the setting of the Display Partial Credit Card Number in Logs (J16) system control value.
Rejected deposits: If a deposit is rejected, you can review the reason for the decline or contact CyberSource to identify why the deposit transaction was declined, and either manually confirm the deposit or resubmit it if the decline is for a reason that may pass in subsequent processing.
If a response is not received: If a deposit response is not received within the maximum wait time, Order Management System creates a record in the Request for Response table; see Working with Required Responses (WREQ) for processing details.
Retrieving responses from CyberSource: If a deposit response was not received within the maximum wait time, or if a communication failure occurred during transaction processing, you can use the receive deposits option on the Auto Deposit Screen to send a deposit request to CyberSource, requesting CyberSource to queue the deposit response so that Order Management System can retrieve it.
Order Management System performs the following steps when you perform authorization reversal using point-to-point communication with CyberSource.
For more information: See Credit Card Authorization Reversal for an overview on credit card authorization reversal and processing details.
1.
For the CyberSource integration with Order Management System, the setting is Payment Link indicating Point-to-Point communication. The system sends authorization reversal transactions directly to the CyberSource service bureau.
2.
If the Communication type field for the service bureau is Payment Link, Order Management System creates the CyberSource Authorization Reversal Request (ccAuthReversalService) XML Message.
The system also writes the authorization reversal request message to the Trace Log if its Logging Level is set to DEBUG. Order Management System masks the card number in the log based on the setting of the Display Partial Credit Card Number in Logs (J16) system control value.
3.
Order Management System uses the settings in the CyberSource Interface Properties to send the CyberSource Authorization Reversal Request (ccAuthReversalService) XML Message directly to the CyberSource service bureau.
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG property is set to true, the system writes the authorization reversal request message to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
4.
Once Order Management System sends the authorization reversal request to CyberSource, the system waits for a response to the authorization reversal request using the number of seconds defined in the Response time field for the CYB service bureau.
5.
The CyberSource service bureau receives the CyberSource Authorization Reversal Request (ccAuthReversalService) XML Message, processes the request, and sends the CyberSource Authorization Reversal Response (ccAuthReversalService) XML Message back to Order Management System.
6.
Order Management System receives the CyberSource Authorization Reversal Response (ccAuthReversalService) XML Message and processes the response.
If the CYB_PAY_LINK_SERVICE_ENABLE_LOG property is set to true, the system writes the authorization reversal response to the CyberSource web service log defined in the CYB_PAY_LINK_SERVICE_LOG_DIRECTORY. Order Management System masks the information in this log.
7.
See What Happens When the Authorization Reversal is Approved? and What Happens When the Authorization Reversal is Declined? for the updates that take place in Order Management System, depending on whether the authorization reversal transaction was approved or declined by the service bureau.
About subsequent authorizations: Order Management System sends CyberSource information indicating whether a transaction was initiated by the merchant, or by the customer. For example, when the customer initially places the order, this is a transaction initiated by the customer; if Order Management System submits a new deposit request for the payment method on the order because the initial request failed, this is a transaction initiated by the merchant.
CyberSource requires Order Management System to pass information identifying a subsequent authorization that was not initiated by the customer.
Term definitions:
         Merchant-Initiated Transactions (MIT): An authorization that the system initiates without the customer’s active participation.
         Cardholder-Initiated Transactions (CIT): An authorization that uses payment information provided by the customer.
         Credentials on File (COF): The cardholder payment information that is stored by the system. The credit card can be either tokenized or non-tokenized.
Which messages? The following messages include information about subsequent authorizations for order payment methods submitted to CyberSource:
Types of subsequent authorizations: Brief descriptions of subsequent authorization types include:
         Resubmission of a failed deposit: When the Supports Auth Resubmission flag is selected for CyberSource in Defining Authorization Services (WASV) and a previous deposit request failed. A subsequent authorization and deposit request is generated, with the subsequentAuth tag set to true and the subsequentAuthReason set to 1; otherwise, this tag is set to 3.
         Split shipment: When the order is not fulfilled in a single shipment. In this case, the request for the subsequent authorization includes a subsequentAuthReason set to 3 and passes the existing ci_transaction_id as the subsequentAuthTransactionID.
         Deferred or installment billing: When the order uses deferred or installment billing. In this case, the Notify of installments flag for the pay type indicates whether to send a commerceIndicator set to install in the ccAuthService element for the authorization and deposit request, or to include subsequent authorization tags similar to other types of subsequent authorizations, as described below.
For more information: See Deferred/Installment Billing Overview.
         Customer membership orders: When you generate orders for a customer membership that has been authorized. Authorization can take place either through the order originating the customer membership, or through a generated membership order. The CIT Transaction ID (customer-initiated transaction ID) and the original authorization amount for the credit card are stored on the customer membership, although this information is not displayed on any screen.
For more information: See Subsequent Authorizations to CyberSource for Membership Orders.
Details on the information passed to CyberSource: The information that might be passed related to subsequent authorizations includes the following.
Tag
Usage:
Not Passed When:
subsequentAuthFirst
Set to true if this is the first authorization request for the payment method, and not a merchant-initiated transaction. A first authorization can be:
         The first authorization request for the order payment method.
         The first authorization request after changing the credit card number for the order payment method.
         The authorization request generated after the first request failed.
         The authorization request for an order originating a customer membership.
         The authorization request for the first generated membership order after the credit card for the customer membership was updated.
If this is a subsequent authorization request, this tag is not passed. A subsequent request can be:
         A request generated after a previous request, such as a first authorization for a deferred or installment pay plan, has succeeded.
         A request generated after a previous request was voided.
         A request generated after an initial deposit request failed.
         A request generated for a generated membership order after the authorization was obtained.
subsequentAuth
Set to true if this is a subsequent authorization request (the subsequentAuthFirst was not passed), and
         The credit card information is tokenized; or,
         The credit card information is not tokenized, and the ci_transaction_id is stored on the Order Payment Method record. See the discussion of the subsequentAuthTransactionID, below, for more information.
         This is not a subsequent authorization request, or
         The credit card information is not tokenized, and there is no ci_transaction_id stored on the Order Payment Method record.
subsequentAuth Reason
If subsequentAuth is set to true:
         Set to 3 if:
         The request is for a reauthorization for split shipment or delayed shipment. A split or delayed shipment occurs when some of the goods that were ordered are not available for shipment at the time of purchase. When you ship goods after the authorization validity time limit set by Visa, you must perform a separate authorization to ensure that customer funds are available.
         This is an authorization and deposit request for a deferred or installment pay plan after the initial authorization, and the Notify of installments setting for the pay type is not selected.
         This is an authorization request for a generated membership order after the authorization was obtained for the customer membership.
         Set to 1 if the request is for resubmission of a declined deposit in an authorization and deposit request. This situation can occur if the Supports Auth Resubmission flag is selected for CyberSource in Defining Authorization Services (WASV) and a previous deposit request failed.
         This is not a subsequent authorization request or authorization and deposit request, or
         This is an authorization and deposit request that is for an order using deferred or installment billing, and the Notify of installments setting for the pay type is selected, or
         This is an authorization and deposit request that is not for an order using deferred or installment billing, or
subsequentAuth TransactionID
The ci_transaction_id identifying the authorization. Passed when this is a subsequent authorization (the subsequentAuthFirst was not passed), and the ci_transaction_id is stored on the Order Payment Method, either through the paymentNetworkTransactionID from a previous message from CyberSource, through the ci_transaction_id received in the Inbound Order XML Message (CWORDERIN),, or from the customer membership if this is a generated membership order.
This transaction ID is cleared from the Order Payment Method if you change the credit card number.
         There is no ci_transaction_id stored on the Order Payment Method record, or
         The card is tokenized.
subsequentAuth StoredCredential
Set to true if the authorization credentials are stored. Passed when this is a subsequent authorization (the subsequentAuthFirst was not passed), and the ci_transaction_id is stored on the Order Payment Method, either through the paymentNetworkTransactionID from a previous message from CyberSource, or through the ci_transaction_id received in the Inbound Order XML Message (CWORDERIN).
subsequentAuth OriginalAmount
The amount of the original approved authorization.
         If this is the CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message, and the previous deposit request failed without a change to the card number, this is the auth amount from Auth History.
         If this is the CyberSource Authorization Request (ccAuthService) XML Message or the CyberSource Token and Authorization Request (paySubscriptionCreate and ccAuthService) XML Message for a generated membership order, this is the original authorization amount from the customer membership, that was written to the order’s payment method record.
         Otherwise, if this is the CyberSource Authorization Request (ccAuthService) XML Message or the CyberSource Token and Authorization Request (paySubscriptionCreate and ccAuthService) XML Message and there was a previous approved authorization for the same card number on the order payment method, this is the authorization amount from the oldest Auth History record.
Sample CyberSource Transactions
         CyberSource Token (paySubscriptionCreate) Transaction: Sample Messages
         CyberSource Authorization (ccAuthService) Transaction without Decision Manager: Sample Messages
         CyberSource Authorization (ccAuthService) Transaction with Decision Manager: Sample Messages
         CyberSource Token and Authorization (paySubscriptionCreate and ccAuthService) Transaction: Sample Messages
         CyberSource Debit Deposit (ccCaptureService) Transaction: Sample Messages
         CyberSource Credit Deposit (ccCreditService) Transaction: Sample Messages
         CyberSource Authorization and Deposit (ccAuthService and ccCaptureService) Transaction: Sample Messages
         CyberSource Authorization Reversal (ccAuthReversalService) Transaction: Sample Messages
A sample of a CyberSource Token (paySubscriptionCreate) transaction is presented below.
Request: See CyberSource Token Request (paySubscriptionCreate) XML Message for mapping details.
<requestMessage xmlns="urn:schemas-cybersource-com:transaction-data-1.57">
<merchantID xmlns="urn:schemas-cybersource-com:transaction-data-1.57">merchID</merchantID>
<merchantReferenceCode>CMPORDER_NBR</merchantReferenceCode>
<billTo>
<firstName>FIRST</firstName>
<lastName>LAST</lastName>
<street1>STREET1</street1>
<city>CITY</city>
<state>MA</state>
<postalCode>POSTAL</postalCode>
<country>US</country>
<email>null@cybersource.com</email>
</billTo>
<purchaseTotals>
<currency>USD</currency>
</purchaseTotals>
<card>
<accountNumber>***** REMOVED *****</accountNumber>
<expirationMonth>12</expirationMonth>
<expirationYear>2012</expirationYear>
<cardType>001</cardType>
</card>
<recurringSubscriptionInfo>
<frequency>on-demand</frequency>
</recurringSubscriptionInfo>
<decisionManager>
<enabled>false</enabled>
</decisionManager>
<paySubscriptionCreateService run="true" />
</requestMessage>
Response: See CyberSource Token Response (paySubscriptionCreate) XML Message for mapping details.
<c:replyMessage xmlns:c="urn:schemas-cybersource-com:transaction-data-1.57">
<c:merchantReferenceCode>CMPORDER_NBR</c:merchantReferenceCode>
<c:requestID>REQUEST_ID</c:requestID>
<c:decision>ACCEPT</c:decision>
<c:reasonCode>100</c:reasonCode>
<c:requestToken>REQUEST_TOKEN</c:requestToken>
<c:purchaseTotals>
<c:currency>USD</c:currency>
</c:purchaseTotals>
<c:ccAuthReply>
<c:amount>0.00</c:amount>
<c:authorizationCode>AUTH_CODE</c:authorizationCode>
<c:avsCode>X</c:avsCode>
<c:avsCodeRaw>I1</c:avsCodeRaw>
<c:authorizedDateTime>2011-06-30T19:44:12Z</c:authorizedDateTime>
<c:processorResponse>100</c:processorResponse>
<c:reconciliationID>RECONCILIATIONID</c:reconciliationID>
<c:paymentNetworkTransactionID>TRANSACTIONID</c:paymentNetworkTransactionID>
</c:ccAuthReply>
<c:paySubscriptionCreateReply>
<c:subscriptionID>SUBSCRIPTION_ID</c:subscriptionID>
</c:paySubscriptionCreateReply>
</c:replyMessage>
A sample of a CyberSource Authorization (ccAuthService) transaction when Decision Manager is not enabled is presented below. This transaction uses the token, rather than the actual credit card number, to authorize a credit card payment.
Request: See CyberSource Authorization Request (ccAuthService) XML Message for mapping details.
<purchaseTotals>
<grandTotalAmount>10.87</grandTotalAmount>
</purchaseTotals>
<subscriptionID>SUBSCRIPTION_ID</subscriptionID>
<decisionManager>
</decisionManager>
<ccAuthService run="true">
<commerceIndicator>moto</commerceIndicator>
</ccAuthService>
</requestMessage>
Response: See CyberSource Authorization Response (ccAuthService) XML Message for mapping details.
<c:purchaseTotals>
</c:purchaseTotals>
<c:ccAuthReply>
<c:amount>10.87</c:amount>
<c:authorizedDateTime>2011-07-01T14:10:04Z</c:authorizedDateTime>
<c:ownerMerchantID>merchID</c:ownerMerchantID>
</c:ccAuthReply>
</c:replyMessage>
A sample of a CyberSource Authorization (ccAuthService) transaction when Decision Manager is enabled is presented below. This transaction uses the token, rather than the actual credit card number, to authorize a credit card payment.
<clientLibrary xmlns="urn:schemas-cybersource-com:transaction-data-1.57">Java XML</clientLibrary>
<clientLibraryVersion xmlns="urn:schemas-cybersource-com:transaction-data-1.57">5.0.2</clientLibraryVersion>
<clientEnvironment xmlns="urn:schemas-cybersource-com:transaction-data-1.57">Windows NT (unknown)/6.2/Sun Microsystems Inc./1.6.0_30</clientEnvironment>
<billTo>
<city>CITY</city>
<state>MA</state>
<country>US </country>
<email>EMAIL_ADDR</email>
<customerID>CSTID</customerID>
</billTo>
<shipTo>
<city>CITY</city>
<state>MA</state>
<phoneNumber>PHONE</phoneNumber>
<shippingMethod>lowcost</shippingMethod>
</shipTo>
<item id="0">
<unitPrice>13.50</unitPrice>
<quantity>1</quantity>
<productCode>default</productCode>
<productName>ITEM DESCRIPTION </productName>
<productSKU>ITEM</productSKU>
</item>
<purchaseTotals>
<grandTotalAmount>16.67</grandTotalAmount>
</purchaseTotals>
<decisionManager>
<enabled>true</enabled>
</decisionManager>
</ccAuthService>
<businessRules>
<ignoreAVSResult>true</ignoreAVSResult>
<ignoreCVResult>true</ignoreCVResult>
</businessRules>
<subsequentAuthFirst>true</subsequentAuthFirst>
</requestMessage>
<c:decision>REVIEW</c:decision>
<c:reasonCode>480</c:reasonCode>
<c:purchaseTotals>
</c:purchaseTotals>
<c:ccAuthReply>
<c:amount>16.67</c:amount>
<c:authorizedDateTime>2014-05-01T14:17:41Z</c:authorizedDateTime>
</c:ccAuthReply>
<c:afsReply>
<c:afsResult>62</c:afsResult>
<c:hostSeverity>1</c:hostSeverity>
<c:consumerLocalTime>10:17:39</c:consumerLocalTime>
<c:afsFactorCode>H^R</c:afsFactorCode>
<c:velocityInfoCode>VEL-ADDR^VEL-NAME</c:velocityInfoCode>
<c:scoreModelUsed>xxxxxxx</c:scoreModelUsed>
<c:binCountry>xx</c:binCountry>
<c:cardAccountType>Coxxxxxxxxx&E</c:cardAccountType>
<c:cardScheme>Vixxxxxxxit</c:cardScheme>
<c:cardIssuer>JPMOxxxxxxxxxxxxxxxxxN.A.</c:cardIssuer>
</c:afsReply>
<c:decisionReply>
<c:casePriority>x</c:casePriority>
<c:activeProfileReply/>
</c:decisionReply>
</c:replyMessage>
A sample of a CyberSource Token and Authorization (paySubscriptionCreate and ccAuthService) transaction is presented below. This transaction sends the actual credit card number, rather than a token, to authorize a credit card payment. CyberSource replaces the credit card number with a token during the authorization process.
Request: See CyberSource Token and Authorization Request (paySubscriptionCreate and ccAuthService) XML Message for mapping details.
<billTo>
<city>CITY</city>
<state>MA</state>
</billTo>
<purchaseTotals>
</purchaseTotals>
<card>
</card>
<decisionManager>
</decisionManager>
</ccAuthService>
</requestMessage>
Response: See CyberSource Token and Authorization Response (paySubscriptionCreate and ccAuthService) XML Message for mapping details.
<c:purchaseTotals>
</c:purchaseTotals>
<c:ccAuthReply>
<c:authorizedDateTime>2011-07-01T14:55:04Z</c:authorizedDateTime>
</c:ccAuthReply>
</c:replyMessage>
A sample of a CyberSource Debit Deposit (ccCaptureService) transaction is presented below.
Request: See CyberSource Debit Deposit Request (ccCaptureService) XML Message for mapping details.
<invoiceHeader>
<userPO>USER_PO</userPO>
</invoiceHeader>
<item id="0">
<unitPrice>10.35</unitPrice>
<taxAmount>0.5175</taxAmount>
</item>
<purchaseTotals>
</purchaseTotals>
<ccCaptureService run="true">
<authRequestID>AUTH_REQ_ID</authRequestID>
<reconciliationID>RECONCILIATIONID</reconciliationID>
</ccCaptureService>
</requestMessage>
Response: See CyberSource Debit Deposit Response (ccCaptureService) XML Message for mapping details.
<c:purchaseTotals>
</c:purchaseTotals>
<c:ccCaptureReply>
<c:requestDateTime>2011-07-01T17:46:49Z</c:requestDateTime>
</c:ccCaptureReply>
</c:replyMessage>
A sample of a CyberSource Credit Deposit (ccCreditService) transaction is presented below.
Request: See CyberSource Credit Deposit Request (ccCreditService) XML Message for mapping details.
<invoiceHeader>
</invoiceHeader>
<billTo>
<city>CITY</city>
<state>MA</state>
</billTo>
<item id="0">
<productCode>ITEM</productCode>
<productName>REGULAR ITEM - BACK IN BUSINESS</productName>
<productSKU />
<unitOfMeasure>EA</unitOfMeasure>
<taxRate>0.0500</taxRate>
<totalAmount>10.35</totalAmount>
<discountAmount>39.65</discountAmount>
<commodityCode>0</commodityCode>
</item>
<purchaseTotals>
<freightAmount>0.00</freightAmount>
</purchaseTotals>
<ccCreditService run="true">
<purchasingLevel>3</purchasingLevel>
</ccCreditService>
</requestMessage>
Response: See CyberSource Credit Deposit Response (ccCreditService) XML Message for mapping details.
<c:purchaseTotals>
</c:purchaseTotals>
<c:ccCreditReply>
<c:requestDateTime>2011-07-01T20:14:15Z</c:requestDateTime>
<c:purchasingLevel3Enabled>Y</c:purchasingLevel3Enabled>
</c:ccCreditReply>
</c:replyMessage>
A sample of a CyberSource Authorization and Deposit (ccAuthService and ccCaptureService) transaction is presented below.
Request: See CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message for mapping details.
<invoiceHeader>
</invoiceHeader>
<item id="0">
<quantity>4</quantity>
<productSKU />
<taxAmount>2.07</taxAmount>
<totalAmount>41.40</totalAmount>
<discountAmount>158.60</discountAmount>
</item>
<item id="1">
<productSKU />
</item>
<purchaseTotals>
<discountAmount>198.25</discountAmount>
<grandTotalAmount>27.17</grandTotalAmount>
</purchaseTotals>
<decisionManager>
</decisionManager>
<commerceIndicator>moto</commerceIndicator> <reconciliationID>RECONCILIATIONID</reconciliationID>
</ccAuthService>
</ccCaptureService>
<subsequentAuth>true</subsequentAuth>
<subsequentAuthOriginalAmount>8.14</subsequentAuthOriginalAmount>
<subsequentAuthReason>3</subsequentAuthReason>
<subsequentAuthTransactionID>TRANSACTIONID</subsequentAuthTransactionID>
<subsequentAuthStoredCredential>true</subsequentAuthStoredCredential>
</requestMessage>
Response: See CyberSource Authorization and Deposit Response (ccAuthService and ccCaptureService) XML Message for mapping details.
<c:purchaseTotals>
</c:purchaseTotals>
<c:ccAuthReply>
<c:amount>27.17</c:amount>
<c:authorizedDateTime>2011-07-05T12:58:27Z</c:authorizedDateTime>
</c:ccAuthReply>
<c:ccCaptureReply>
<c:requestDateTime>2011-07-05T12:58:27Z</c:requestDateTime>
</c:ccCaptureReply>
</c:replyMessage>
A sample of a CyberSource Authorization Reversal (ccAuthReversalService) transaction is presented below.
Request: See CyberSource Authorization Reversal Request (ccAuthReversalService) XML Message for mapping details.
<purchaseTotals>
<grandTotalAmount>25.57</grandTotalAmount>
</purchaseTotals>
<ccAuthReversalService run="true">
</ccAuthReversalService>
</requestMessage>
Response: See CyberSource Authorization Reversal Response (ccAuthReversalService) XML Message for mapping details.
<c:purchaseTotals>
</c:purchaseTotals>
<c:ccAuthReversalReply>
<c:amount>25.57</c:amount>
<c:requestDateTime>2011-07-05T13:31:28Z</c:requestDateTime>
</c:ccAuthReversalReply>
</c:replyMessage>
CyberSource Message Layouts
The CyberSource Token Request (paySubscriptionCreate) XML message is used to request a token from CyberSource. See Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1) for processing details.
Sample transaction: See CyberSource Token (paySubscriptionCreate) Transaction: Sample Messages.
Special characters: Certain special characters cannot be passed in an attribute of an XML message except through the use of replacement text strings. Order Management System replaces the following special characters with the text strings listed below.
Special Character
Description
Replacement Text String
single quote
&apos;
double quote
&quot;
greater than
&gt;
less than
&lt;
ampersand
&amp;
Order Management System also removes any non-standard keyboard characters from the XML message before sending it to CyberSource.
The elements and attributes of the CyberSource Token Request (paySubscriptionCreate) XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
requestMessage
merchantID
The account number assigned by CyberSource to identify transmissions. From the:
         Merchant # field in the CC Paytype Cross Ref table, or
         Merchant ID field in the Merchant ID Override table, or
         Merchant ID field in the Authorization Services table.
The company code + order number. If the request is not associated with an order, the order number is zero-filled. From the Company and Order # fields in the Order Payment Method table.
billTo
CyberSource performs address verification against the bill to name and address included in the Token Request.
firstName
The bill to customer’s first name. From the:
         First name field in the Customer Bill To table, or
         NAM First name field in the Customer Sold To table.
lastName
The bill to customer’s last name. From the:
         Last name field in the Customer Bill To table, or
         NAM Last name field in the Customer Sold to table.
Note:  If a last name is not passed, CyberSource fails the transaction.
street1
The street address on the bill to customer’s address, followed by the text APT and the apartment or suite number defined for the bill to customer’s address. For example: 123 MAIN ST APT 2B. From the:
         Street address and APT Code in the Customer Bill To table, or
         NAM Street address and Apartment in the Customer Sold To table.
street2
The second address line on the bill to customer’s address. From the:
         Address line 2 field in the Customer Bill To table, or
         NAM Address line 2 in the Customer Sold To table.
city
The city on the bill to address. From the:
         City field in the Customer Bill To table, or
         City field in the Customer Sold To table.
state
The state code on the bill to customer’s address. From the:
         State field in the Customer Bill To table, or
         NAM State field in the Customer Sold To table.
postalCode
The zip code on the bill to customer’s address.
If the country code is US, the 9-digit zip code is in 99999-9999 format.
If the country code is CA, the 6-digit zip code is in A1B 2C3.
If the country code is JP, the 7-digit zip code is in 999-9999 format.
If the country code is GB, the 6-digit zip code is in AB12CD format.
From the:
         Zip field in the Customer Bill To table, or
         NAM Zip field in the Customer Sold To table.
country
The country code on the bill to customer’s address. The system uses the Work with Authorization Service Country Screen to cross-reference the Order Management System country code in the Customer Bill To table or Customer Sold To table to the CyberSource country code.
From the Auth Service Country field in the Auth Service Country table.
email
The bill to customer’s email address.
If an email address is not defined for the bill to customer, null@Cybersource.com defaults.
From the CST email address field in the Customer Sold To table.
purchaseTotals
currency
The currency on the order. The system uses the Work with Authorization Service Currency Screen to cross-reference the Order Management System currency code to the CyberSource currency code.
From the ASC Currency code field in the Auth Service Currency table.
card
CyberSource validates the credit card information included in the Token Request.
accountNumber
The card number to replace with a token.
If you use credit card encryption, the system decrypts the credit card number before sending it to CyberSource; see the Data Security and Encryption Guide on My Oracle Support (1988467.1).
From the OPM credit card number field in the Order Payment Method table.
expirationMonth
The month when the card expires, in MM format.
From the first 2 positions of the OPM expiration date field in the Order Payment Method table.
expirationYear
The year when the card expires, in YYYY format.
From the last 2 positions of the OPM expiration date field in the Order Payment Method table.
cardType
The vendor paytype code defined for the credit card pay type. This is the code CyberSource uses to identify the method of payment.
From the CPC vendor paytype/code field in the CC Paytype Cross Ref table.
cvIndicator
The card identification indictor defined for the card, indicating if a CID number has been defined. Valid values:
         1 = CID number is present on card.
         2 = CID number is present on card, but is illegible.
         9 = CID number is not present on card.
Included only for online transactions.
cvNumber
The card identification number defined for the card.
         Visa, MasterCard, Discover: The card identification number is a 3 digit number.
         American Express: The card identification number is a 4 digit number.
Note:  The card identification number is available only for online transactions; once an order is accepted, the system removes the card identification number from the order.
issueNumber
The card issue number defined for the card being processed.
From the OPM card issue # field in the Order Payment Method table.
startMonth
The start month defined for the card being processed, in MM format.
From the first 2 positions of the Start date field in the Order Payment Method table.
startYear
The start year defined for the card being processed, in YYYY format.
From the last 2 positions of the Start date field in the Order Payment Method table.
decisionManager
enabled
false defaults.
frequency
on-demand defaults.
Service_run
true defaults, indicating the message is for a token request.
The CyberSource Token Response (paySubscriptionCreate) XML message contains the response from CyberSource for the CyberSource Token Request (paySubscriptionCreate) XML Message.
The elements and attributes of the CyberSource Token Response (paySubscriptionCreate) XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
replyMessage
The response returned by CyberSource indicates whether the token request was accepted or rejected. If the transaction was accepted, CyberSource returns a token in the requestToken tag.
The company code + order number, used to match the response to the request. If the request is not associated with an order, the order number is zero-filled.
Corresponds to the Company and Order # fields in the Order Payment Method table.
requestID
A code assigned by CyberSource to match this response to subsequent transactions.
decision
REJECT indicates CyberSource rejected the transaction.
reasonCode
The reason the transaction was approved or rejected by CyberSource.
100 indicates the transaction was successful.
151 indicates the request was received by CyberSource but there was a server timeout. If you receive this reason, do not resend the request until you have reviewed the transaction status in the CyberSource Business Center. See the documentation for your CyberSource client (SDK) for information about how to handle retries in the case of system errors.
152 indicates the request was received by CyberSource but a service did not finish running in time. If you receive this reason, do not resend the request until you have reviewed the transaction status in the CyberSource Business Center. See the documentation for your CyberSource client (SDK) for information about how to handle retries in the case of system errors.
Corresponds to the Response Code field in the CC Vendor Response table.
See Reason Codes for the Simple Order API in the CyberSource Credit_Cards_SO_API.pdf document for a complete list of valid reason codes.
requestToken
The credit card number requesting tokenization, encrypted.
Updates the OPM credit card number field in the Order Payment Method table.
purchaseTotals
currency
Corresponds to the ASC Currency code field in the Auth Service Currency table.
ccAuthReply
CyberSource returns authorization information in the Token Response; however, Order Management System ignores this information.
reasonCode
amount
0.00 defaults for token transactions.
authorizationCode
The authorization code assigned to the transaction.
avsCode
The AVS code assigned to the transaction.
avsCodeRaw
cvCode
The card identification response for the credit card.
authorizedDateTime
The date and time when the transaction was processed, in YYYY-MM-DDTHH:MM:SSZ format.
processorResponse
The response code from the bank. Informational only.
reconciliationID
A code assigned by CyberSource as a reference number for the transaction.
reasonCode
subscriptionID
The token assigned to the credit card payment.
CyberSource uses this code to reference the customer profile information in the CyberSource database.
The CyberSource Authorization Request XML message is used to authorize a credit card payment.
Sample transaction: See:
Special Character
Description
single quote
&apos;
double quote
&quot;
greater than
&gt;
less than
&lt;
ampersand
&amp;
The elements and attributes of the ccAuthService Request XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
requestMessage
merchantID
         CYB_PAY_LINK_DECISION_MANAGER_MERCHANT_ID_OVERRIDE property, or
The company code + order number + order payment method sequence number.
From the Company, Order # and OPM Seq # fields in the Order Payment Method table.
Subsequent authorization tags: See Subsequent Authorization Requests to CyberSource for more information on the following tags.
subsequentAuthFirst
Set to true if this is the first authorization request for the payment method, and not a merchant-initiated transaction. A first authentication can be:
         An authorization request generated after the first request failed.
Not passed when: If this is a subsequent authorization request, this tag is not passed. A subsequent request can be:
See Subsequent Authorization Requests to CyberSource for more information.
subsequentAuth
Not passed when:
Set to 3 if subsequentAuth is set to true and:
Not passed when:
The ci_transaction_id identifying the authorization. Passed when this is a subsequent authorization (the subsequentAuthFirst was not passed), and the ci_transaction_id is stored on the Order Payment Method, either through the paymentNetworkTransactionID from a previous message from CyberSource, through the ci_transaction_id received in the Inbound Order XML Message (CWORDERIN), or from the customer membership if this is a generated membership order.
Not passed when:
Set to true if the authorization credentials are stored. Passed when this is a subsequent authorization (the subsequentAuthFirst was not passed), and the ci_transaction_id is stored on the Order Payment Method, either through the paymentNetworkTransactionID from a previous message from CyberSource, through the ci_transaction_id received in the Inbound Order XML Message (CWORDERIN), or from the customer membership if this is for a generated membership order.
Not passed when:
The amount of the original approved authorization. This is the authorization amount from the oldest Auth History record.
Not passed when:
billTo
Included if:
         you send the credit card number and not a token provided by CyberSource
         the CYB_PAY_LINK_DECISION_MANAGER_ENABLED setting in the CyberSource Interface Properties is set to true
firstName
lastName
street1
street2
city
state
postalCode
From the:
country
phoneNumber
The bill to customer’s day phone number.
From the:
         CT# Phone field in the Customer Bill To Phone # table for Phone # type D, or
         CS# Phone field in the Customer Sold To Phone # table for Phone # type D.
email
customerID
The Order Management System sold to customer number.
From the CST Customer # field in the Customer Sold To table.
customerPassword
The customer’s account password, used for merchant velocity use only and it not stored, displayed, or returned.
Note:  This field is not currently implemented in the Order Management System integration with CyberSource.
personalID
Personal identifier, supported only for CyberSource Latin American Processing.
shipTo
Included if the CYB_PAY_LINK_DECISION_MANAGER_ENABLED property is set to true.
The shipTo is different from the billTo if the customer specified an alternate shipping address on the order:
         order ship to: see Assigning an Order Shipping Address
         permanent ship to: see Using a Permanent Shipping Address in Order Entry
         recipient customer: see Adding a Recipient Order in Order Entry
firstName
The ship to customer’s first name. From the:
         First name field in the Customer Ship To table, or
lastName
The ship to customer’s last name. From the:
         Last name field in the Customer Ship To table, or
street1
The street address on the ship to customer’s address, followed by the text APT and the apartment or suite number defined for the ship to customer’s address. For example: 123 MAIN ST APT 2B. From the:
         Street address and Apartment in the Customer Ship To table, or
street2
The second address line on the ship to customer’s address. From the:
         Address line 2 field in the Customer Ship To table, or
city
The city on the ship to address. From the:
         City field in the Customer Ship To table, or
state
The state code on the ship to customer’s address. From the:
         State field in the Customer Ship To table, or
postalCode
The zip code on the ship to customer’s address.
From the:
         Zip field in the Customer Ship To table, or
country
The country code on the ship to customer’s address. The system uses the Work with Authorization Service Country Screen to cross-reference the Order Management System country code in the Customer Ship To table or Customer Sold To table to the CyberSource country code.
phoneNumber
The ship to customer’s day phone number.
From the:
         CT# Phone field in the Customer Ship To Phone # table for Phone # type D, or
shippingMethod
The service level defined for the ship to customer’s zip code.
Service levels defined in CyberSource Decision Manager are:
         sameday: Courier or same day service.
         oneday: Next day or overnight service.
         twoday: Two day service.
         threeday: Three day service.
         lowcost: Lowest cost service
         pickup: Store pickup. When a ShippingMethod is defined for a ship to in the ccAuthService message, the shipping address is not automatically added to the negative list. You can add a shipping address to the negative list using the Transaction Marking Tool; see Marking Order Data During Order Review in the Case Management section of the Decision Manager User Guide.
         other: Other shipping method.
         none: No shipping method because product is a service or subscription.
Note:  To use a custom value, create a Decision Manager custom rule with the shipping method order element.
From the Decision Manager Service Level field in the Ship Via table.
item
id
The number of items on the order, starting with 0. For example, if two items are on the order, the first item would be set to 0 and the second item would be set to 1.
unitPrice
The unit selling price of the product.
From the ODT Price field in the Order Detail table.
quantity
The quantity of the product being purchased.
From the ODT qty reserved field in the Order Detail table.
productCode
The type of product.
Product codes used by CyberSource services are:
         adult_content: Adult content.
         coupon: Coupon applied to the entire order.
         default: Product classification has not been defined for the product.
         electronic_good: Electronic product other than software.
         electronic_software: Software distributed electronically rather than on disks or other media.
         handling_only: Fee that you charge the customer to cover administrative selling costs.
         service: Service that you perform for the customer.
         shipping_and_handling: The shipping portion is the charge for shipping the product to the customer. The handling portion is the fee you charge the customer to cover your administrative selling costs.
         shipping_only: Charge for transporting tangible personal property from your location to the customer. You must maintain documentation that clearly establishes the location where the title to the property passed from you to the customer.
         subscription: Subscription to a web site or other content.
The setting of the Product Classification for Fraud Scoring (M15) system control value determines whether Order Management System sends the item’s item class description or item category description to CyberSource.
         If set to ITM CLASS, from the ICL description field in the Item Class table.
         If set to ITM CATGRY, from the Item category description field in the Item Category table.
productName
The name of the product.
If the item is a non-SKUed item, this is the item description.
If the item is a SKUed item, this is a concatenation of the item description + SKU description.
From the Description field in the Item table + the Description field in the SKU table.
productSKU
Merchant’s product identifier code.
If the item is a non-SKUed item, this is the item number.
If the item is a SKUed item, this is a concatenation of the item number + SKU code.
From the ITM Number field and SKU Code field in the SKU table.
purchaseTotals
currency
grandTotalAmount
The amount to authorize, including decimals, in the currency defined on the order.
Online transactions: From the OLA auth amt field in the Online Authorization table.
Batch transactions: From the Auth $ amt field in the CC Authorization Trans table.
Included only if the credit card number has been replaced with a token provided by CyberSource.
subscriptionID
The token for the credit card payment.
frequency
on-demand defaults.
card
Included if you send the credit card number and not a token provided by CyberSource.
accountNumber
The card number to authorize and replace with a token.
expirationMonth
expirationYear
cardType
cvIndicator
The card identification indicator defined for the card, indicating if a CID number has been defined. Valid values:
cvNumber
issueNumber
startMonth
startYear
merchantDefinedData
The merchantDefinedData fields can be used to store many types of information that may be unique to your business.
Note:  The merchantDefinedData fields are not currently implemented in the Order Management System integration with CyberSource. Contact your Order Management System representative if you would like to implement these fields in the Order Management System integration with CyberSource.
See Potential Uses for Merchant-Defined Data Fields in the CyberSource Decision Manager Developer Guide for examples of the type of information that can be captured in these fields.
merchantDefinedData_mddField_1 tomerchantDefinedData_mddField_100
Optional fields that you can use to store information.
The value appears in the Case Management Details window in the Business Center.
Merchant defined fields cannot be used to capture personally identifying information.
These fields can only be used if you are referencing target API version 1.75 or higher.
decisionManager
enabled
         true defaults if the CYB_PAY_LINK_DECISION_MANAGER_ENABLED property is set to true. In this situation, CyberSource Decision Manager evaluates the transaction for possible fraud. See CyberSource Decision Manager Fraud Scoring for processing details.
         false defaults if the CYB_PAY_LINK_DECISION_MANAGER_ENABLED property is set to any value other than true.
profile
Allows you to specify the name of a different profile to use to evaluate orders.
ccAuthService
ccAuthService_run
true defaults.
commerceIndicator
internet defaults if the E-Commerce indicator (Future use status 1) field in the Order Header table is set to I or the order type for the order matches the order type defined in the E-Commerce Order Type (G42) system control value; otherwise, moto defaults.
cavv
A code received from an authentication service, such as Visa’s Verified by Visa program or MasterCard’s SecureCode program, indicating whether the card authentication password the cardholder provided was approved for the credit card. See Credit Card Authentication Service for more information.
From the Authentication value field in the Order Payment Method table.
eciRaw
businessRules
ignoreAVSResult
true defaults.
ignoreCVResult
true defaults.
The CyberSource Authorization Response XML message contains the response from CyberSource for the CyberSource Authorization Request (ccAuthService) XML Message.
The elements and attributes of the ccAuthService Response XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
replyMessage
The company code + order number + order payment method sequence number, used to match the response to the correct request.
Corresponds to the Company, Order # and OPM Seq # fields in the Order Payment Method table.
requestID
The unique transaction ID assigned by CyberSource for the transaction.
Updates the Transaction ID field in the Authorization History table, and saved in the Invoice Payment Method table at billing.
decision
The overall decision for the entire request from Decision Manager.
REVIEW indicates CyberSource Decision Manager marked the order for review for further analysis. The credit card authorization remains approved and valid, but the order may or may not be processed at a later time. See CyberSource Decision Manager Review Process for more information.
REJECT indicates CyberSource Decision Manager rejected the transaction. Order Management System deactivates the credit card payment and requires you to add another form of payment before you can accept the order. See CyberSource Decision Manager Reject Process for more information.
reasonCode
The reason the transaction was approved or rejected by Decision Manager.
See the CyberSource documentation for a complete list of valid reason codes.
requestToken
The token assigned to the credit card associated with the authorization transaction, encrypted.
purchaseTotals
currency
ccAuthReply
reasonCode
The reason the authorization transaction was approved or rejected by the authorization service.
Corresponds to the Response Code field in the CC Vendor Response table and updates the AUH vendor response field in the Authorization History table.
amount
The amount authorized by CyberSource, including decimals, in the currency defined on the order.
If the authorization is for a customer membership order, the original authorization amount is also saved for the customer membership if it was not already populated.
Updates th e AUH amount authorized field in the Authorization History table.
authorizationCode
The authorization number provided by CyberSource.
Updates the AUH auth # field in the Authorization History table.
avsCode
The address verification response for the credit card.
Updates the AUH AVS response field in the Authorization History table.
avsCodeRaw
The address verification response for the credit card, from the processor.
cvCode
Updates the AUH Vendor Response 2 field in the Authorization History table.
authorizedDateTime
The date and time the credit card was authorized, in YYYY-MM-DDTHH:MM:SSZ format.
Updates the AUH auth date field in the Authorization History table.
processorResponse
reconciliationID
The customer-initiated transaction ID obtained when authorizing the credit card. Included only when the credit card has not previously been authorized.
A customer-initiated transaction ID is required for a credit card payment method only when tokenization is not enabled for CyberSource.
This ID can also be updated with the ci_transaction_id in the Inbound Order XML Message (CWORDERIN). It is stored for the Order Payment Method, and not updated once populated unless you change the credit card number.
If the authorization is for a customer membership order, the ID is also saved for the customer membership if it was not already populated.
ownerMerchantID
The account number assigned by CyberSource to identify transmissions. Corresponds to the:
afsReply
CyberSource Advanced Fraud Screen reply. Informational only; these fields are not implemented in the Order Management System integration with CyberSource.
Included if the CYB_PAY_LINK_DECISION_MANAGER_ENABLED setting in the CyberSource Interface Properties is set to true.
reasonCode
Numeric value corresponding to the result of the Advanced Fraud Screen request.
afsResult
Total score calculated for the order.
hostSeverity
The risk associated with the customer’s email domain. From 0-5, where 0 represents an undetermined risk and 5 represents the highest risk.
consumerLocalTime
Customer’s local time in HH:MM:SS format. Calculated from the request time and the customer’s billing address.
afsFactorCode
Information that affected the score of the order. This field can contain one or more codes, separated by carets (^), for example: B^Y.
See Risk Factor Codes in the CyberSource Decision Manager Developer Guide for a list of factor codes used by CyberSource.
addressInfoCode
Indicates a mismatch between the customer’s billing and shipping addresses. This field can contain one or more codes, separated by carets (^).
See Address Information Codes in the CyberSource Decision Manager Developer Guide for a list of address info codes used by CyberSource.
internetInfoCode
Indicates a problem with the customer’s email address, IP address, or billing address. This field can contain one or more codes, separated by carets (^). See Information Codes in the CyberSource Decision Manager Developer Guide for a list of possible values.
suspiciousInfoCode
Indicates that the customer provided potentially suspicious information. This field can contain one or more codes, separated by carets (^), for example: INTL-BIN^RISK-T.
See Suspicious Data Information Codes in the CyberSource Decision Manager Developer Guide for a list of suspicious info codes used by CyberSource.
velocityInfoCode
Indicates that the customer has a high order velocity (purchase frequency). This field can contain one or more codes, separated by carets (^), for example: VELV-SA^VELI-CC^VELSIP.
scoreModelUsed
Name of the score model used for the transaction.
binCountry
Two-digit country code associated with the BIN of the customer’s card used for the payment.
cardAccountType
Type of payment card account, such as credit card, debit card, or prepaid card account type.
cardScheme
Subtype of card account.
         Maestro International
         Maestro UK Domestic
         MasterCard Credit
         MasterCard Debit
         Visa Credit
         Visa Debit
         Visa Electron
cardIssuer
Name of the bank or entity that issued the card account.
decisionReply
CyberSource Decision Manager reply. Informational only; these fields are not implemented in the Order Management System integration with CyberSource.
activeProfileReply_
destinationQueue
When verbose mode is enabled, name of the queue where orders that are not automatically accepted are sent.
activeProfileReply_name
When verbose mode is enabled, name of the active profile chosen by the profile selector. If no profile selector exists, the default active profile is chosen.
activeProfileReply_
rulesTriggered_
ruleResultItem_#_
decision
When verbose mode is enabled, summarizes the result for the rule specified according to the setting that you chose in the Profile Editor. This field contains one of the following values:
         ACCEPT
         ERROR
         REJECT
         REVIEW
activeProfileReply_
rulesTriggered_
ruleResultItem_#_
evaluation
When verbose mode is enabled, raw evaluation result of the rule specified by the number #. This field contains one of the following values:
         T: The rule is true.
         F: The rule is false.
         N: The rule cannot be evaluated because the data is insufficient.
         E: The rule cannot be evaluated because an
error occurred.
activeProfileReply_
rulesTriggered_
ruleResultItem_#_name
When verbose mode is enabled, description of the rule as it appears in the Profile Editor.
activeProfileReply_
selectedBy
When verbose mode is enabled, name of the profile selector rule that chooses the profile to use for the transaction. If no profile selector exists, the value is Default Active Profile.
casePriority
You receive this field only if you subscribe to the Enhanced Case Management service. The priority level ranges from 1 (highest) – 5 (lowest); the default value is 3. If you do not assign a priority to your rules or to your profiles, the default value is given to the order.
velocityInfoCode
List of information codes triggered by the order.
These information codes were generated when you created the order and product velocity rules and are returned so that you can associate them with the rules.
The CyberSource ccAuthService Request XML message is used to authorize a credit card payment and to also request a token in the same transaction.
Sample transaction: See CyberSource Token and Authorization (paySubscriptionCreate and ccAuthService) Transaction: Sample Messages.
Special Character
Description
single quote
&apos;
double quote
&quot;
greater than
&gt;
less than
&lt;
ampersand
&amp;
Attribute Name
Comments
requestMessage
merchantID
subsequentAuthFirst
subsequentAuth
Not passed when:
Set to 3 when subsequentAuth is set to true and:
Not passed when this is not a subsequent authorization request.
Not passed when:
Set to true if the authorization credentials are stored. Passed when this is a subsequent authorization (the subsequentAuthFirst was not passed), and the ci_transaction_id is stored on the Order Payment Method, either through the paymentNetworkTransactionID from a previous message from CyberSource, through the ci_transaction_id received in the Inbound Order XML Message (CWORDERIN), or from the customer membership if this is a generated membership order.
Not passed when:
Not passed when:
billTo
firstName
lastName
street1
street2
city
state
postalCode
From the:
country
email
purchaseTotals
currency
grandTotalAmount
card
accountNumber
The card number to authorized and replace with a token.
expirationMonth
expirationYear
cardType
cvIndicator
cvNumber
issueNumber
startMonth
startYear
ccAuthService_run
true defaults.
frequency
on-demand defaults.
decisionManager
enabled
false defaults.
ccAuthService
ccAuthService_run
true defaults.
commerceIndicator
cavv
eciRaw
Service_run
true defaults.
businessRules
ignoreAVSResult
true defaults.
ignoreCVResult
true defaults.
The CyberSource ccAuthService Response XML message contains the response from CyberSource for the CyberSource Token and Authorization Request (paySubscriptionCreate and ccAuthService) XML Message.
Attribute Name
Comments
replyMessage
The order number + order payment method sequence number, used to match the response to the correct request.
Corresponds to the Order # and OPM Seq # fields in the Order Payment Method table.
requestID
Updates the Transaction ID field in the Authorization History table.
decision
ACCEPT indicates CyberSource approved the transaction.
ERROR indicates an error occurred while CyberSource was processing the transaction.
reasonCode
requestToken
purchaseTotals
currency
ccAuthReply
reasonCode
amount
Updates the AUH amount authorized field in the Authorization History table.
authorizationCode
avsCode
avsCodeRaw
cvCode
authorizedDateTime
processorResponse
reconciliationID
A customer-initiated transaction ID is required for a credit card payment method only when tokenization is not enabled for CyberSource; however, if the ID is passed, it is stored regardless of whether tokenization is enabled.
reasonCode
subscriptionID
The CyberSource Debit Deposit Request XML message is used to deposit a debit invoice whose amount is equal to or less than the authorization amount.
Sample transaction: See CyberSource Debit Deposit (ccCaptureService) Transaction: Sample Messages.
Special Character
Description
single quote
&apos;
double quote
&quot;
greater than
&gt;
less than
&lt;
ampersand
&amp;
The elements and attributes of the CyberSource Debit Deposit Request (ccCaptureService) XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
requestMessage
merchantID
invoiceHeader
userPO
The purchase order number associated with the deposit. From the Purchase order # field in the Order Ship To table.
If a purchase order is not defined, the system defaults the Order Management System order number. From the Order # field in the Order Payment Method table.
Included only if the transaction qualifies for level II or III discounting and the payment method is Visa, American Express, or MasterCard; see Level II and III Discounting.
billTo
Included only if you do not use credit card tokenization or if the credit card payment has not yet been replaced with a token from CyberSource.
firstName
lastName
street1
The street address on the bill to customer’s address. From the:
         Street address in the Customer Bill To table, or
         NAM Street address in the Customer Sold To table.
street2
The second address line on the bill to customer’s address, followed by the text APT and the apartment or suite number defined for the bill to customer’s address. For example: GARDEN TERRACE APT 2B. From the:
         Address line 2 and APT Code in the Customer Bill To table, or
         NAM Address line 2 and Apartment in the Customer Sold To table.
city
state
postalCode
From the:
country
email
If an email address is not defined for the bill to customer, null@CyberSource.com defaults.
item
id
0 defaults.
unitPrice
The unit price of the item, including decimals, in the currency defined on the order, minus any hidden tax included in the item price.
From the IDT Price field in the Invoice Detail table.
Included only if the transaction qualifies for level II or III discounting and the payment is a method other than Discover or JCB; see Level II and III Discounting.
quantity
The quantity of the item shipped.
From the IDT Qty shipped field in the Invoice Detail table.
Included only if the transaction qualifies for level III discounting and the payment method is Visa or MasterCard; see Level II and III Discounting.
productCode
The item number on the deposit.
From the ITM Number field in the Item table.
productName
A description of the item.
From the Description field in the Item table.
productSKU
The SKU of the item on the deposit.
From the SKU Code field in the SKU table.
taxAmount
The tax amount for the item, including decimals, in the currency defined on the order, including any hidden tax included in the item price.
From the Tax field in the Invoice Detail table.
Included only if the transaction qualifies for level II discounting and the payment method is Visa, American Express, or MasterCard, or the transaction qualifies for level III discounting and the payment method is Visa or MasterCard. See Level II and III Discounting.
unitOfMeasure
The unit of measure defined for the item.
From the Unit of measure field in the SKU table.
taxRate
The tax rate defined for the item. The system uses this calculation to determine the tax rate:
taxAmount / unitPrice = taxRate
totalAmount
The total price of the item, including decimals, in the currency defined on the order. The system uses this calculation to determine the total amount:
item_#_quantity x the item_#_unitPrice = item_#_totalAmount
discountAmount
The discount amount applied to the item, including decimals, in the currency defined on the order.
From the IDT Discount amount field in the Invoice Detail table.
commodityCode
The commodity code defined for the item.
From the SKU Commodity Code field in the SKU table.
grossNetIndicator
Y defaults if a value is passed in the vatTaxAmount tag; otherwise, N defaults.
Included only if the transaction qualifies for level III discounting and the payment method is MasterCard; see Level II and III Discounting.
discountIndicator
Y defaults if an amount greater than 0 exists in the discountAmount tag; otherwise, N defaults.
purchaseTotals
currency
discountAmount
The discount amount for the deposit, including decimals, in the currency defined on the order.
From the INS Discount amount filed in the Invoice Ship To table.
Included only if the transaction qualifies for level III discounting and the payment method is Visa; see Level II and III Discounting.
dutyAmount
The duty amount for the deposit, including decimals, in the currency defined on the order.
From the IDC Amount field in the Invoice Detail Charge table for IDC Type of Charge D.
grandTotalAmount
The amount to deposit, including decimals, in the currency defined on the order.
From the Total $ amt field in the CC Deposit Transaction table.
freightAmount
The freight amount for the deposit, including decimals, in the currency defined on the order.
From the INS Freight field in the Invoice Ship To table.
otherTax
vatTaxAmount
The VAT tax amount defined for the item, including decimals, in the currency defined on the order.
From the IDC Amount field in the Invoice Detail Charge table for IDC Type of Charge V.
vatTaxRate
The VAT percent defined for the ship to customer’s country.
From the CNT VAT percent in the Country table.
Included only if the transaction qualifies for level II discounting and the payment method is Visa; see Level II and III Discounting.
See How Hidden Tax is Calculated by Percentage for more information.
card
accountNumber
expirationMonth
expirationYear
cardType
issueNumber
startMonth
startYear
ccCaptureService
true defaults.
authRequestID
The transaction ID for the authorization associated with the deposit.
From the Transaction ID field in the Authorization History table.
reconciliationID
If the Override Reconciliation Id for CyberSource is set to:
         blank: Not passed.
         Invoice Number: The invoice number assigned at billing.
         Alternate Order Number: The alternate order number from the Order Header Extended table, if any; otherwise, not sent. This field is labeled the Alt ord at the Display Order Properties Screen.
For an e-commerce order, the alternate order number is the order_number passed in the Inbound Order XML Message (CWORDERIN) message to identify the order in the originating system or on the web storefront. If the e-commerce order number is a date, it is formatted without punctuation, for example: 20200114T123456.
If the reconciliationID in the request message does not specify an invoice number or alternate order number, then CyberSource assigns a reconciliationID as a reference number for the transaction, and passes it in the response message.
         The supported size of the reconciliationID varies based on the credit card processor. You need to confirm that the credit card processor used supports the length and attributes of the invoice number or alternate order number.
         It is possible that the reconciliationID may not be unique in CyberSource if, for example, you have multiple companies.
purchasingLevel
3 defaults if the transaction qualifies for level III discounting and the payment method is Visa or MasterCard; otherwise, this value is not passed. See Level II and III Discounting.
Service_run
true defaults if a token is requested in the deposit transaction.
ccCapture_sequence
The current sequence number for the order payment authorization request id for the deposit. Set to 1 if this is the first deposit for the order, and incrementing by 1 for each subsequent deposit.
Not sent if both the ccCapture_sequence and the ccCapture_totalCount are set to 1.
Sent when? This field is sent only if the Void auth at deposit flag for the authorization service is unselected, and the entire order does not ship and bill at once, based on the fact that it’s a debit invoice for less than the authorization amount.
Maximum sequence number: The maximum sequence number sent is 99, regardless of whether the actual number of deposits for the order is greater, and a sequence number of 99 is sent only for the final deposit. Otherwise, the message continues to include a sequence number of 98 until the final deposit request is generated. Note that the actual number of deposits is still tracked in the Authorization History record.
For more information: See Void Unused Authorization After Initial Deposit for background and more examples.
The total number of deposits for the order. Set to 99 if the total number of deposits is unknown.
If this is the final deposit for the order, the total count is set to match the current sequence number.
Example:  There are two lines on the order shipping separately. When the first line ships, the sequence is set to 1 and the total count is set to 99. When the second and final line ships, the sequence is set to 2 and the total count is also set to 2.
If large number of deposits: If the number of deposits to process for the order exceeds 99, a total count of 99 still continues to be sent in the deposit request message. Note that the actual number of deposits is still tracked in the Authorization History record.
The CyberSource Debit Deposit Response (ccCaptureService) XML message contains the response from CyberSource for the CyberSource Debit Deposit Request (ccCaptureService) XML Message.
The elements and attributes of the CyberSource Debit Deposit Response (ccCaptureService) XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
replyMessage
The company code + order number + order payment method sequence number, to match the response to the correct deposit.
Updates the Company, Order # and OPM Seq # fields in the CC Deposit History table.
requestID
decision
reasonCode
Corresponds to the Response Code field in the CC Vendor Response table and updates the Response code field in the CC Deposit History table.
requestToken
The token assigned to the credit card associated with the deposit transaction, encrypted.
purchaseTotals
currency
ccCaptureReply
reasonCode
Corresponds to the Response Code field in the CC Vendor Response table. Updates the Response code field in the CC Deposit History table.
requestDateTime
The date and time the deposit was authorized by CyberSource, in YYYY-MM-DDTHH:MM:SSZ format. Order Management System translates this date format to CYYMMDD format.
Updates the Deposit date field in the CC Deposit History table.
amount
The amount deposited, including decimals, in the currency defined on the order.
Updates the Deposit Amount field in the CC Deposit History table.
reconciliationID
The alternate order number or invoice number that was sent as the reconciliationID in the CyberSource Debit Deposit Request (ccCaptureService) XML Message; otherwise, this is a code assigned by CyberSource as a reference number for the transaction.
Note:  If this ID does not match alternate order number or invoice number that was sent in the request message, this could be because the number submitted in the request did not meet the length and formatting requirements of the credit card processor.
purchasingLevel3
Enabled
Y defaults if the transaction qualifies for level II discounting; otherwise, this value is not passed.
The CyberSource Credit Deposit Request XML message is used to deposit a credit invoice.
Sample transaction: See CyberSource Credit Deposit (ccCreditService) Transaction: Sample Messages.
Special Character
Description
single quote
&apos;
double quote
&quot;
greater than
&gt;
less than
&lt;
ampersand
&amp;
The elements and attributes of the ccCreditService Request XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
requestMessage
merchantID
invoiceHeader
userPO
billTo
firstName
lastName
street1
street2
city
state
postalCode
From the:
country
email
item
id
0 defaults.
unitPrice
quantity
productCode
productName
productSKU
taxAmount
Included only if the transaction qualifies for level II discounting and the payment method is Visa, American Express, or MasterCard, or the transaction qualifies for level III discounting and the payment method is Visa or MasterCard; see Level II and III Discounting.
unitOfMeasure
taxRate
totalAmount
discountAmount
commodityCode
purchaseTotals
currency
discountAmount
dutyAmount
grandTotalAmount
freightAmount
otherTax
vatTaxAmount
vatTaxRate
Included only if a token is passed.
subscriptionID
frequency
on-demand defaults.
ccCreditService
ccCreditService run
true defaults.
reconciliationID
         blank: Not passed.
purchasingLevel
3 defaults if the transaction qualifies for level II discounting and the payment method is Visa or MasterCard; otherwise, this value is not passed.
The CyberSource Credit Deposit Response (ccCreditService) XML message contains the response from CyberSource for the CyberSource Credit Deposit Request (ccCreditService) XML Message.
The elements and attributes of the CyberSource Credit Deposit Response (ccCreditService) XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
replyMessage
requestID
decision
reasonCode
requestToken
purchaseTotals
currency
ccCreditReply
reasonCode
requestDateTime
amount
reconciliationID
The alternate order number or invoice number that was sent as the reconciliationID in the CyberSource Credit Deposit Request (ccCreditService) XML Message; otherwise, this is a code assigned by CyberSource as a reference number for the transaction.
purchasingLevel3
Enabled
ownerMerchantID
The CyberSource Authorization and Deposit Request XML message is used to authorize and deposit a debit invoice. The system generates this message when:
         the deposit amount is greater than the authorization amount.
         the authorization has expired.
         the deposit is for a deferred payment plan.
         the deposit is for an installment payment plan after the initial deposit for the plan.
Sample transaction: See CyberSource Authorization and Deposit (ccAuthService and ccCaptureService) Transaction: Sample Messages.
Special Character
Description
single quote
&apos;
double quote
&quot;
greater than
&gt;
less than
&lt;
ampersand
&amp;
The elements and attributes of the Authorization and Capture Request XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
requestMessage
merchantID
subsequentAuthFirst
         The first authorization request for the order payment method.
         The first authorization request after changing the credit card number for the order payment method.
         The authorization request for an order originating a customer membership.
         The authorization request for the first generated membership order after the credit card for the customer membership was updated.
         A request generated after a previous request, such as a first authorization for a deferred or installment pay plan, has succeeded.
         A request generated after a previous request was voided.
         A request generated after an initial deposit request failed.
         A request generated for a generated membership order after the authorization was obtained.
subsequentAuth
Set to true if this is a subsequent authorization request (the subsequentAuthFirst was not passed), and
         The credit card information is tokenized; or,
         The credit card information is not tokenized, and the ci_transaction_id is stored on the Order Payment Method record. See the discussion of the subsequentAuthTransactionID, below, for more information.
Not passed when:
         This is not a subsequent authorization request, or
         The credit card information is not tokenized, and there is no ci_transaction_id stored on the Order Payment Method record.
Set to:
         1 if the Supports Auth Resubmission flag is selected for CyberSource in Defining Authorization Services (WASV) and if the request is for authorization and deposit of a failed deposit request.
         3 if subsequentAuth is set to true. For an authorization and deposit request for a deferred or installment pay plan after the initial authorization, set to 3 if the Notify of installments setting for the pay type is not selected.
Not passed when:
         This is not a subsequent authorization and deposit request, or
         This is an authorization and deposit request that is for an order using deferred or installment billing, and the Notify of installments flag for the pay type is selected, or
         This is an authorization and deposit request that is not for an order using deferred or installment billing, or
The ci_transaction_id identifying the authorization. Passed when this is a subsequent authorization (the subsequentAuthFirst was not passed), and the ci_transaction_id is stored on the Order Payment Method, either through the paymentNetworkTransactionID from a previous message from CyberSource, through the ci_transaction_id received in the Inbound Order XML Message (CWORDERIN), or from the customer membership if this is for a generated membership order.
This transaction ID is cleared from the Order Payment Method if you change the credit card number.
Not passed when:
         There is no ci_transaction_id stored on the Order Payment Method record.
Not passed when:
The amount of the original approved authorization.This is the auth amount from Auth History:
         If this is for a generated membership order, this is the original authorization amount from the customer membership, that was written to the order’s payment method record.
         Otherwise, if there was a previous approved authorization for the same card number on the order payment method, this is the authorization amount from the oldest Auth History record.
Not passed when:
         The order uses deferred or installment billing, and the Notify of installments setting for the pay type is selected, or
invoiceHeader
userPO
billTo
firstName
lastName
street1
street2
The second address line on the bill to customer’s address, followed by the text APT and the apartment or suite number defined for the bill to customer’s address. For example: TERRACE GARDEN APT 2B. From the:
city
state
postalCode
From the:
country
email
item
id
0 defaults.
unitPrice
quantity
productCode
productName
productSKU
taxAmount
unitOfMeasure
taxRate
totalAmount
discountAmount
commodityCode
purchaseTotals
currency
discountAmount
dutyAmount
grandTotalAmount
freightAmount
otherTax
vatTaxAmount
vatTaxRate
card
accountNumber
expirationMonth
expirationYear
cardType
issueNumber
startMonth
startYear
recurringSubscriptionInfo
subscriptionID
frequency
on-demand defaults.
decisionManager
enabled
false defaults.
ccAuthService
ccAuthService_run
true defaults.
reconciliationID
         blank: Not passed.
commerceIndicator
Deferred or installment billing? If the order uses deferred or installment billing and the Notify of installments flag for the pay type is selected, the commerceIndicator is set to install for the subsequent authorization and deposit request after the initial authorization. See Subsequent Authorization Requests to CyberSource for more information.
cavv
eciRaw
businessRules
ignoreAVSResult
true defaults.
ignoreCVResult
true defaults.
ccCaptureService
true defaults.
authRequestID
reconciliationID
         blank: Not passed.
purchasingLevel
Service_run
The CyberSource Authorization and Capture Response XML message contains the response from CyberSource for the CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message.
The elements and attributes of the Authorization and Capture Response XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
replyMessage
merchantReferenceCode
requestID
decision
reasonCode
requestToken
purchaseTotals
currency
ccAuthReply
reasonCode
amount
If this is for a customer membership order, the original authorization amount is also saved for the customer membership if it was not already populated.
authorizationCode
avsCode
avsCodeRaw
authorizedDateTime
processorResponse
reconciliationID
The alternate order number or invoice number that was sent as the reconciliationID in the CyberSource Authorization and Deposit Request (ccAuthService and ccCaptureService) XML Message; otherwise, this is a code assigned by CyberSource as a reference number for the transaction.
ownerMerchantID
If this is for a customer membership order, the ID is also saved for the customer membership if it was not already populated.
ccCaptureReply
reasonCode
requestDateTime
amount
reconciliationID
purchasingLevel3
Enabled
The CyberSource Authorization Reversal Request (ccAuthReversalService) XML message is used to reverse an authorization for a credit card payment. The system generates this message when the deposit amount is greater than the authorization amount and it has not been more than 72 hours since the authorization was obtained.
Sample transaction: See CyberSource Authorization Reversal (ccAuthReversalService) Transaction: Sample Messages.
Special Character
Description
single quote
&apos;
double quote
&quot;
greater than
&gt;
less than
&lt;
ampersand
&amp;
The elements and attributes of the Authorization Reversal Request (ccAuthReversalService) XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
requestMessage
merchantID
From the Company + Order # and OPM Seq # fields in the Order Payment Method table.
purchaseTotals
currency
grandTotalAmount
The amount to reverse, including decimals, in the currency defined on the order.
From the Amount authorized field in the Authorization History table.
true defaults.
authRequestID
The CyberSource Authorization Reversal Response (ccAuthReversalService) XML message contains the response from CyberSource for the CyberSource Authorization Reversal Request (ccAuthReversalService) XML Message.
The elements and attributes of the Authorization Reversal Response XML message that are used by Order Management System are described below. See the CyberSource Credit_Cards_SO_API.pdf document for more information on the additional values in this message.
Attribute Name
Comments
replyMessage
requestID
decision
reasonCode
Corresponds to the Response Code field in the CC Vendor Response table and its description updates the AHR response field in the Authorization History SVC Reversal table.
requestToken
purchaseTotals
currency
ccAuthReversalReply
reasonCode
amount
The amount reversed by CyberSource, including decimals, in the currency defined on the order.
Updates the AHR Reversal amount field in the Authorization History SVC Reversal table.
processorResponse
requestDateTime
The date and time the credit card reversal was authorized, in YYYY-MM-DDTHH:MM:SSZ format.
Updates the AHR creation date field in the Authorization History SVC Reversal table.
________________________________
