Purpose: Use the Job Management screen to work with submitted jobs that have been processed, are currently processing, or are waiting to be processed. The jobs listed at this screen include each interactive session for the user.
This topic also discusses options you can use to review the jobs currently running and correct a job’s status if it is inconsistent.
In this topic:
• Job Management Screen Options
• Jobs Excluded from the Long Running Jobs Monitor
• Applying Changes to the Monitor Properties
For more information: See:
• Display Active Batch Jobs (DABJ)
• Which Jobs are Active Batch Jobs?
• If a Batch Job is not on the Display Active Batch Jobs Screen
• Display Active Batch Jobs Screen
How to display this screen: Click
the My Jobs icon (
in the upper right area of a screen),
or select My Jobs from an Admin
screen (such as the About Application, Forms Management Screen, Document Management Screen, Commands, User
Control, or System Messages screens). When you advance to the screen this
way, it displays all jobs generated through your user ID. See the field
descriptions and screen options below for information on how to filter
the jobs listed on this screen.
Column sort: You can sort on any column by clicking the column heading name. When you first click, the sort is in ascending alphanumeric (A-Z) or numeric (lowest to highest) order. Click again to change the sort to descending (Z-A) or numeric (highest to lowest) order.
Information on this screen:
Field |
Description |
Provides the option for you to switch the job queue where one or more jobs should run. The system-delivered job queues are: • QBATCH (default) = The default job queue for most submitted jobs, such as reports and batch updates and processing. Processes one job at a time (single-threaded queue). • QSYSNOMAX = The default job queue for Generating Membership Orders (EGMO) and jobs submitted through Working with Integration Layer Processes (IJCT). Can process multiple jobs at the same time (multi-threaded queue). • QINTER = The job queue where interactive user sessions run. This job queue processes multiple jobs at the same time. • ASYNC = The job queue where background processes, submitted through Using the ASYNC Jobs (MBJC), run. Can process multiple jobs at the same time. • ECOMMERCE = The job queue where the ECOMM_CANC job and the ORDER_EDIT job (generated through the ORDER_IN job in Working with Integration Layer Processes (IJCT)) run automatically. Can process multiple jobs at the same time. • PICKGEN = The default job queue for Streamlined Pick Slip Generation (WSPS), Reprocess Authorizations Screen (RPAA), and Processing Auto Deposits (SDEP). Processes one job at a time. • AUTODEP = The default job queue for deposit processing. The DEP_UPDATE uses this queue, but the AUTO_DEP job does not. Processes one job at a time. |
<- Route Job |
Use this button to route a job to the queue selected in the Queue field, described above: • Select one or more jobs from the Job listings area, below. • Select a queue from the Output Queue field. • Click this button to move the job to the selected queue. You can select a different route only if the job has not yet started to run (Ready status). Also, you cannot re-route the BILL_UPD or SCHDDEP job. |
Default settings for jobs available for review: When you first advance to this screen, up to 200 jobs submitted by your user ID are currently available for review by scrolling up or down with the right-hand scroll bar. The jobs are listed in reverse chronological order (newest to oldest). A message displays if more that 200 jobs are available for review: The maximum number of records was exceeded. Please refine search criteria. Showing records 1-200. Available jobs updated when you filter: When you enter or select any search criteria and then click Filter, the screen displays up to 200 jobs that match these criteria. Example: The screen currently includes 200 jobs available for review in reverse chronological order (newest to oldest): 180 of these jobs run in QBATCH, and 20 run in ASYNC. When you select QBATCH from the Queue field and click OK, the screen displays up to 200 jobs that run in QBATCH. Available jobs restricted: If your user control record does not have All job authority selected, you cannot review jobs submitted by other users. Example: If you do not have All job authority, when you filter on a Job name of PICK_GEN, pick slip generation jobs submitted by other users are not displayed. |
Action |
An arrow in this field indicates an action can be performed against the job. Valid actions are: • Hold = Available if the job’s status is Ready. • Release = Available if the job’s status is Hold. • End = Available if the job’s status is Message. This option should not ordinarily be used. Use the JOBCLN periodic function instead. • Delete = Available if the job’s status is Ready, Hold, Finished, Error, or End. If you attempt to delete a job that is actually running, the screen displays an error message. See the Job Management Screen Options. If a job is currently running but you suspect that the job is not running normally, use the JOBCLN periodic function. See Using the JOBCLN Function to Resolve Job Status Across Servers for more information. |
User name |
The user name of the person who submitted the job, or who is using an interactive session. Defaults to your user ID. Submitted through web service request? When you use the CWProcessIn message or the ProcessIn message to start a periodic process, if the message did not indicate to wait for completion, the job is listed under the default user set up during installation; otherwise, if the message indicated to wait for completion, the job is not listed on this screen. Contact your cloud administrator or system administrator to confirm the user ID of the default user, and see Using the CWProcessIn Message to Start a Periodic Process or Using the ProcessIn REST Message to Start a Periodic Process for background. Filter options: The following options are available only for users whose All Job Authority setting is selected: • to display jobs submitted by another user: enter a complete, valid user ID and click OK. • to display jobs regardless of the user who submitted them: clear the current entry in this field and click OK. See the Administration guide for more information on setting up users. |
A code identifying the job. The job name for an interactive session has a name starting with QPADEV (for example, QPADEV0B9A). Defaults to blank. Note: • The
reports icon ( • The auto-deposit and billing update jobs are displayed with the company number as a suffix. for example: AUTO_DEP123 or BILL_UPD123. These jobs are generated through the BILLUPD and SCHDDEP periodic functions; also, the Submit Auto Deposits (SDEP) menu option submits the auto-deposit job. Filter options: • to display jobs based on job name: enter a full or partial job name and click OK. • to display jobs regardless of name: if you have previously entered a job name, clear the entry and click OK. No report? If
there was no information matching the selection criteria for the
report, the system may not generate a blank report; instead, you
see the reports icon ( |
Job |
A system-assigned identification number to track the job. A job number of 0 can indicate that a job, such as the auto-deposit job, was started while another instance of the job was running for the same company. In this case, the job is in Error status. |
Status |
The current status of the job. Possible statuses are: • blank (default) = Select this option to display all jobs regardless of status. • Ready = The job is currently waiting in the indicated job queue for processing because another job is currently active in that job queue, and the queue is single-threaded (processes only one job at a time). Optionally, you can expedite processing by routing the job to a different job queue that does not currently have a job running, or that is multi-threaded: Select the job, select the Output Queue at the top of the screen, and click <- Route Job. • Held = The job is held. Optionally, you can release the job by selecting the Action checkbox to the left of the job and selecting Release. • Run = The job is currently running normally. It is not possible to hold the job or change its job queue. Note: An auto-deposit or billing update job's status may be displayed as Run after a system restart even though it is not actually running. Use JOBCLN to resolve. Using the JOBCLN Function to Resolve Job Status Across Servers for more information. • Finished = The job has finished
running normally. If there is a reports icon ( |
• Message = Can occur if Order Management System has written a message to a log file, and the job cannot continue processing. Note: Occasionally, the async jobs go into Message status even though they are continuing to process records. See Troubleshooting the Async Jobs for more information. • End = Someone has manually ended a job whose status was Run, but was not running normally (perhaps because the server rebooted while the job was running). In this case, use the JOBCLN periodic function. See Using the JOBCLN Function to Resolve Job Status Across Servers for more information. • Error = Someone has manually ended a job that was not running normally. A job can also be in this status if a job was submitted while an active procedure for a prior submission of the job had not been deleted. Also, the BILL_UPD or AUTO_DEP job can be in error if submitted for the same company where an instance of the job is already running, or if the server is restarted while the job was running; after restart, a job monitor would put the job in Error status if it was previously in Run status, but not running. Integration layer jobs Jobs you start through the Working with Integration Layer Processes (IJCT) option might not display the current, correct status if they receive inbound messages and have not yet received any messages to process. |
Async jobs When the async jobs in the Background Job Control (MBJC) menu option are active, the system periodically checks the status of each async job, and changes the status to Run, if necessary. For example, if the ORDR_ASYNC job is active and you end it at this screen, the system automatically changes the status of the job back to Run. To start or stop the async jobs, use the Background Job Control (MBJC) menu option. See Working with the CNTL_ASYNC Job. Filter options: • to display jobs by status: select a status from the drop-down list and click OK. • to display jobs regardless of status: if you have previously selected a status, clear the entry and click OK. |
Started |
The date and time when the job started on the current server. Defaults to blank. NONE indicates the job has not yet finished (the status is Ready, Hold, or Run). Filter options: • to display jobs started on or after a specific
date: click the calendar icon ( • to display jobs started on the current date: click the calendar icon, select Today from the bottom of the calendar, and click OK. • to display jobs regardless of start date: if you have previously selected a date, clear the date and click OK. |
Ended |
The date and time when the job finished. Defaults to blank. NONE indicates the job has not yet finished (the status is Ready, Hold, or Run). Filter options: • to display jobs ended on or before a specific
date: click the calendar icon ( • to display jobs ended on the current date: click the calendar icon, select Today from the bottom of the calendar, and click OK. • to display jobs regardless of end date: if you have previously selected a date, clear the date and click OK. |
Runtime |
The amount of time, in seconds, that the job took to run. Set to 0 if the job has not yet completed. Display-only. |
Output Queue |
The job queue where the job will run, is running, or ran. Defaults to blank. See the Output Queue field above for a listing of system-delivered queues. No output queue is displayed for the BILL_UPD123 or AUTO_DEP123 jobs, where 123 is the company number. These jobs are generated through the BILLUPD and SCHDDEP periodic functions, or by submitting deposits through the Submit Auto Deposit (SDEP) option. Filter options: • to display jobs by queue: select a queue from the drop-down list and click OK. • to display jobs regardless of queue: if you have previously selected a queue, clear the queue and click OK. |
Option |
Procedure |
Change which jobs are displayed on the screen |
Restrict or expand the list of displayed jobs based on one of the available column headings |
See the Job Listings for information on how to filter the jobs displayed based on various criteria. |
Refresh data listed on the screen |
Click Refresh. Newly submitted jobs are added to the screen in RDY status as they are submitted, and the status of existing jobs is updated. |
Sort by column |
Click the column heading name. When you first click, the sort is in ascending alphanumeric (A-Z) or numeric (lowest to highest) order. Click again to change the sort to descending (Z-A) or numeric (highest to lowest) order. |
Change a job’s status or queue |
Hold a job |
If the job has not yet processed (its status is Ready), you can hold it by selecting Hold in the Action field for the job. |
Release a job |
If the job is currently held (its status is Hold), you can release it by selecting Release in the Action field for the job. |
End a job that is currently running |
The End option, available when the job’s status is Message, should not ordinarily be used. If a job is currently running but you suspect that the job is not running normally, use the JOBCLN periodic function. See Using the JOBCLN Function to Resolve Job Status Across Servers for more information. |
Delete an individual job |
If the job’s status is Ready, Hold, Finished, Error, or End, and is not actually running, you can delete the job by selecting Delete in the Action field for the job. Note: • Deleting a job also automatically deletes all generated reports for that job that would also be available under the Document Management (My Docs) screen; however, it does not delete forms that are available at the Forms Management (My Forms) screen. • Although no error message is displayed, you cannot actually delete the AUTO_DEP job or the BILL_UPD job. Note that each of these jobs are displayed with the company number as a suffix, such as AUTO_DEP123 or BILL_UPD123. These jobs are generated through the BILLUPD and SCHDDEP periodic functions, or by submitting deposits through the Submit Auto Deposit (SDEP) option. |
Delete selected jobs |
Select the check box to the left of each job you wish to delete and select Delete at the top of the screen. Note: • You can delete a job only if its status is Ready, Hold, Finished, Error, or End and it is not actually running. • Do not select delete for a job that is currently running. If you attempt to delete any jobs that are currently running, the screen displays an error message. • Deleting a job also automatically deletes all generated reports for that job that would also be available under the Document Management (My Docs) screen; however, it does not delete forms that are available at the Forms Management (My Forms) screen. • Although no error message is displayed, you cannot actually delete the AUTO_DEP job or the BILL_UPD job. Note that each of these jobs are displayed with the company number as a suffix, such as AUTO_DEP123 or BILL_UPD123. These jobs are generated through the BILLUPD and SCHDDEP periodic functions, or by submitting deposits through the Submit Auto Deposit (SDEP) option. |
Route one or more jobs to a different queue |
If the job is currently ready for processing (its status is Ready) or is hold (its status is Hold) you can route it to a different queue by: • Selecting the checkbox to the left of the job. • Selecting a different queue from the Output Queue drop-down list at the top of the screen. • Selecting <- Route Job at the top of the screen. Why route? You might want to route a job to a different queue to expedite processing (for example, if another job is currently running in the job’s default queue, and the queue is single-threaded, meaning that only one job at a time can run in that queue at a time). Note: You cannot re-route the BILL_UPD or SCHDDEP job. |
Advance to a different screen Note: If you advance to a different screen and then return, your filter entries are not retained. For example, if you are currently filtering on a specific queue, and you advance to the Document Management (My Docs) screen and return, the Queue column no longer filters on that queue. |
Display the server where a user is logged in, or display the command used to execute a job |
Move your cursor over the Action icon to the left of the job entry. The Command field displays: • User interactive sessions: the name and IP address of the server where the user is logged in. For example, a Command of OMS-srv/123.456.789.123 indicates that the user is logged into Order Management System on the OMS-srv server, which has an IP address of 123.456.789.123. • Batch or submitted jobs: the command executed for the job, such as CALL PGM(flr2012 ) PARM(' ' x'003F' x'00055F' 'N'). |
Review, and optionally print, reports generated by a job |
Click the reports icon ( Note: Forms, such as pick slips, purchase orders, or checks, are available from the Forms Management Screen rather than the Document Management Screen. |
Display information about Order Management System |
Select About. |
Advance to the Forms Management Screen |
Select My Forms. |
Advance to the Document Management Screen |
Select My Docs. |
Advance to the Advanced Commands screen. |
Select Advanced commands. This option is available only for users that have authority to the Advanced Commands option. |
Return to the previous Order Management System screen |
Select Exit. |
Question |
Possible Answer(s) |
Why are the background async jobs not starting correctly? |
Why can’t I change the status of an async job? |
When the async jobs in the Background Job Control (MBJC) menu option are active, the system periodically checks the status of each async job, and changes the status to Run, if necessary. For example, if the ORDR_ASYNC job is active and you end it at this screen, the system automatically changes the status of the job back to Run. To start or stop the async jobs, use the Background Job Control (MBJC) menu option. See Working with the CNTL_ASYNC Job. Also, to correct jobs whose statuses are incorrect, use the JOBCLN periodic function. See Using the JOBCLN Function to Resolve Job Status Across Servers for more information. |
Why do I receive the error Function key not allowed when I press F5 to refresh the Job Management screen? |
To refresh the Job Management screen, click Refresh. |
Why does a submitted job go into Message status? |
Typically, this occurs because someone has stopped and restarted Order Management System. In this case, use the JOBCLN periodic function to resolve. If this is not the reason, check the following logs to determine other possible reasons, looking for messages that were written to the log at the time when the job went into Message status. For example, an error such as out of memory, program not found, or null pointer might help you determine the cause of the problem. The jobs and the activities they track are: • CWDirect Log: General application processing. • MQ Log: XML and transactional message processing and message contents. • Application Log: Order Management System application processing. • Response Log: Jobs that require user intervention in order to proceed, such as authorizations and deposits, and stored value card activations, balance inquiries and authorization reversals. • Trace Log: Internal activity related to Order Management System application processing. • Manifest Log: Manifest processing. To Reset the Job Status Use the Display Active Batch Jobs Screen to determine if the job is actively running. To fix: If the job status is inconsistent, run the JOBCLN periodic function. See Using the JOBCLN Function to Resolve Job Status Across Servers for more information. |
Are job entries automatically deleted? |
Jobs older than the JOB_RETENTION_DAYS property in Working with Admin Properties (CPRP) are deleted when you restart Order Management System. Note that the AUTO_DEP and BILL_UPD jobs are not automatically deleted. |
How can I delete a job if it’s not actually running, regardless of the displayed status? |
If the screen displays an error message when you attempt to delete a job, but the job is not actually running, use the JOBCLN function, as described above. |
After I deleted all of the documents for a submitted job, why does the job remain on the My Jobs screen? |
Deleting all of the output for a submitted job does not delete the submitted job. You need to use the Delete option to remove the job. Note: You can delete a submitted job if it is in Finished status. Evaluate the status of a job that is in an Error status before removing it. Note that you cannot delete the AUTO_DEP job or the BILL_UPD jobs. |
Does deleting a job entry delete its associated documents? |
Deleting a job entry automatically deletes all generated reports for that job that would also be available under the Document Management (My Docs) screen; however, it does not delete forms that are available at the Forms Management (My Forms) screen. |
How can I review all of the jobs for a particular job queue? |
On the Job Management screen, clear the User Name field, select the job queue from the Queue drop down box and click Filter. Note: This option is available only if you have the required authority based on your user control record. Contact your Order Management System representative if you need information on configuring user control records. |
Why can’t I see jobs submitted by all users? |
If your user control record does not have All job authority selected, you cannot review jobs submitted by other users. Contact your Order Management System representative if you need information on configuring user control records. |
Can I choose the job queue the system uses to process a job? |
When a job is first submitted to the job queue, the system automatically chooses which job queue to use to process the job, based on the type of job submitted. However, if the job has not yet processed (its status is Ready), you can route it to a different job queue by: • Selecting the check box to the left of the job. • Selecting the job queue from the drop-down box next to the <- Route Job button. • Selecting Route Job. This option is useful if, for example, a large job is currently active in QBATCH, and you would like to run a report job in a separate job queue so it will process quickly. Note: You cannot re-route the BILL_UPD or SCHDDEP job. |
How can I review and query batch jobs that have run? |
The Display Job History (DJHY) screen displays the Job History table. You can review the data and search by server, date range, job queue, and/or job name. The Job History table in the Order Management System database lists batch jobs that have run, including batch jobs that have been removed from the Job Management Screen. These records remain in this table up to the specified purge days. The fields in this table are: • Job #: The system-assigned identification number to track the job. • Job Name: The name of the job, such as PICK_OUT or BILL_ASYNC. • Start Date: The date the job was started. • Start Time: The time the job was started. • End Date: The date the job finished. Set to 0 if the job did not end. • End Time: The time the job finished. Set to 0 if the job did not end. • Submitted By: The user ID of the person who submitted the job. • Job Queue: The job queue where the job ran, such as QSYSNOMAX or ASYNC. • Server: The name and IP address of the Order Management System application server where the job ran. Purging Records in the Job History Table The JOB_HISTORY_PURGE_ DAYS setting in Working with Admin Properties (CPRP) defines how long to retain a batch job in the Job History table before the system purges it automatically based on the job’s End date. The default setting is 30 days. The system submits the Job History purge process each time you start the application server. Job History records that do not have an End Date (indicating the job did not end) are not purged. Note: This setting does not apply to the history records in the job_run_history table. These records are not currently purged. The job_run_history table contains records for the BILLUPD and SCHDDEP periodic functions. |
Long Running Jobs Monitor watches the batch jobs running on the Job Management Screen and sends a Long Running Job Email to a specified email address if a job runs without ending longer than a specified time.
Starting the Long Running Jobs Monitor: The Long Running Jobs Monitor starts when you stop and restart Order Management System.
Application log: Each time the Long Running Jobs Monitor is started or reloaded, the system writes a message to the Application Log if its Logging Level is set to INFO, indicating:
The Long Running Job Monitor is active and monitoring running batch jobs. Note: The system also writes this message to the Application log when the time defined in the CWDIRECTCP_LR_JOB_MONITOR_ REPEAT_ALERT_AFTER_X_CYCLES setting in Working with Admin Properties (CPRP) is reached. |
Long running job monitor is actively monitoring. |
The email address(es) that receive the Long Running Job Email, as defined in the CWDIRECTCP_LR_JOB_MONITOR_ ALERT_TO_EMAIL_ADDRESS setting in Working with Admin Properties (CPRP). |
Long running job monitor will send emails to : tbrown@example.com |
The batch jobs that are not watched; see Jobs Excluded from the Long Running Jobs Monitor. |
Long running job monitor not monitoring : ORDR_ASYNC Long running job monitor not monitoring : CUST_OUT Long running job monitor not monitoring : EMAIL_OUT |
The batch jobs that the Long Running Jobs Monitor watches using a time other than the default time, as defined in the CWDIRECTCP_LR_JOB_MONITOR_ ALERT_AFTER_X_MINUTES_ OVERRIDE setting in Working with Admin Properties (CPRP). |
Long running job monitor will alert on job : PICK_GEN after it runs over 120 minutes. |
In addition, the system writes a message to the Application log if you do not set up the CWDIRECTCP_LR_JOB_MONITOR properties in Working with Admin Properties (CPRP) correctly; for example: CWDIRECTCP_LR_JOB_MONITOR_REPEAT_ALERT_AFTER_X_CYCLES is not numeric. If an error occurs, you need to correct the error and stop and restart Order Management System.
The Long Running Jobs Monitor watches batch jobs in a Run status only.
The Long Running Jobs Monitor does not watch:
• interactive jobs.
• batch jobs that are not running (for example, the job is in a ready status or is on hold).
• any integration layer job:
• that does not have queues defined.
• that has a process queue marked as Enabled on the Integration Layer Process Queue Screen. The system excludes any active batch job whose name matches the Inbound job name defined for the integration layer process queue. If an Inbound job name is not defined, the system excludes any active batch job whose name matches the Process ID defined for the integration layer process queue. Note: If you change the Enabled flag for an integration layer process queue job, your changes take effect the next time you stop and restart Order Management System.
• batch jobs included in the CWDIRECTCP_LR_JOB_MONITOR_EXCLUDE_JOBS list in Working with Admin Properties (CPRP).
The system generates this email when a batch job runs longer than a specified time.
• If a batch job is not defined in the CWDIRECTCP_LR_JOB_MONITOR_EXCLUDE_JOBS or CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_OVERRIDE settings in Working with Admin Properties (CPRP), the system generates this email when the batch job runs longer than the number of minutes defined in the CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_DEFAULT setting.
• If a batch job is defined in the CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_OVERRIDE setting in Working with Admin Properties (CPRP), the system generates this email when the batch job runs longer than the number of minutes defined after the batch job name. For example, if this setting contains PICK_GEN,120, the system sends a Long Running Job Email if the PICK_GEN batch job runs longer than 120 minutes.
The CWDIRECTCP_LR_JOB_MONITOR_ALERT_TO_EMAIL_ADDRESS setting in Working with Admin Properties (CPRP) defines the email address(es) that receive this email.
Sample email: If more than one batch job requires a Long Running Job email at the same time, the system sends one email for both jobs.
OMS@EXAMPLE.com |
To: |
First Last |
Subject: |
Long Running Job |
PICK_GEN submitted by FLast has been running for over 120 minutes. |
What to do if you receive this email: If you receive a Long Running Job email, evaluate the batch job and determine if the length of time it has been running is within a normal run time.
• If the batch job is within a normal run time, let the job run until it is finished.
• If you think the batch job has been running for too long and you wish to end it, have all users log out of Order Management System and restart the application server where the batch job is running. Note: Restarting the application server will end all batch jobs running on this server.
Sending another Long Running Job Email for the Same Job
If a batch job is still running after the Long Running Jobs Monitor has watched the job for the number of times defined in the CWDIRECTCP_LR_JOB_MONITOR_REPEAT_ALERT_AFTER_X_CYCLES setting in Working with Admin Properties (CPRP), the system sends another Long Running Job email.
Example: Working with Admin Properties (CPRP) has the following settings:
• LR_JOB_MONITOR_RUNS_EVERY_X_MINUTES = 30
• CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_DEFAULT = 60
• LR_JOB_MONITOR_REPEAT_ALERT_AFTER_X_CYCLES = 2
• CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_OVERRIDE = PICKGEN,90
1. You submit the PICK_GEN job.
2. After 30 minutes, the Long Running Jobs Monitor looks for jobs that have been running longer than the number of minutes defined in the ALERT_AFTER_X_MINUTES_DEFAULT or ALERT_AFTER_X_MINUTES_OVERRIDE setting. Because the PICK_GEN job is included in the ALERT_AFTER_X_MINUTES_OVERRIDE setting (PICK_GEN,90) and the number of minutes the job has been running is 30, the system does not send a Long Running Job Email.
3. After another 30 minutes (60 minutes total), the Long Running Jobs Monitor looks for jobs that have been running longer than the number of minutes defined in the ALERT_AFTER_X_MINUTES_DEFAULT or ALERT_AFTER_X_MINUTES_OVERRIDE setting. Because the PICK_GEN job is included in the ALERT_AFTER_X_MINUTES_OVERRIDE setting (PICK_GEN,90) and the number of minutes the job has been running is 60, the system does not send a Long Running Job Email.
4. After another 30 minutes (90 minutes total), the Long Running Jobs Monitor looks for jobs that have been running longer than the number of minutes defined in the ALERT_AFTER_X_MINUTES_DEFAULT or ALERT_AFTER_X_MINUTES_OVERRIDE setting. Because the PICK_GEN job is included in the ALERT_AFTER_X_MINUTES_OVERRIDE setting (PICK_GEN,90) and the number of minutes the job has been running is 90, the system sends a Long Running Job Email.
5. After another 30 minutes (120 minutes total), the Long Running Jobs Monitor looks for jobs that have been running longer than the number of minutes defined in the ALERT_AFTER_X_MINUTES_DEFAULT or ALERT_AFTER_X_MINUTES_OVERRIDE setting. Since a Long Running Job Email has already been generated for the PICK_GEN job, the system looks at the RUNS_EVERY_X_MINUTES and REPEAT_ALERT_AFTER_X_CYCLES settings to determine when to send another email (run every 30 minutes x 2 cycles = send another email after an additional 60 minutes). Because the PICK_GEN job has been running for an additional 30 minutes over the override, the system does not send an email.
6. After another 30 minutes (150 minutes total), the Long Running Jobs Monitor looks for jobs that have been running longer than the number of minutes defined in the ALERT_AFTER_X_MINUTES_DEFAULT or ALERT_AFTER_X_MINUTES_OVERRIDE setting. Since a Long Running Job Email has already been generated for the PICK_GEN job, the system looks at the RUNS_EVERY_X_MINUTES and REPEAT_ALERT_AFTER_X_CYCLES settings to determine when to send another email (run every 30 minutes x 2 cycles = send another email after an additional 60 minutes). Because the PICK_GEN job has been running for an additional 60 minutes over the ALERT_AFTER_X_MINUTES_OVERRIDE setting, the system sends another Long Running Job email.
Working with Admin Properties (CPRP) contains the settings required to enable the Long Running Jobs monitor.
Property Name |
Description |
CWDIRECTCP_LR_RUN_JOB_ MONITOR_ON_ THIS_SERVER this setting is defined in the CWDirectCP Server Properties File |
Indicates whether the Long Running Jobs Monitor runs on this application server. Valid values: Y = The Long Running Jobs Monitor runs on this server. N (default) or blank = The Long Running Jobs Monitor does not run on this server. Note: If you are using a multiple application server environment, set this value to Y on one server only. Typically, you would set this to Y on the application server that runs batch jobs. |
CWDIRECTCP_LR_JOB_MONITOR_RUNS_EVERY_X_MINUTES |
Required; must be numeric. How often, in minutes, the Long Running Jobs Monitor wakes up and looks at the running batch jobs on the Job Management Screen to determine if a job has been running longer than the number of minutes defined in the CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_DEFAULT setting. The default setting is 15 minutes. |
Required; must be numeric. Indicates how long, in minutes, a job must be running before the system sends a Long Running Job Email to the email address defined in the CWDIRECTCP_LR_JOB_MONITOR_ALERT_TO_ EMAIL_ADDRESS. Note: The system applies this time to all batch jobs not included in the CWDIRECTCP_LR_JOB_MONITOR_EXCLUDE_JOBS list or the CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_OVERRIDE list. The default setting is 30 minutes. |
Required; must be numeric. Indicates how many times the Long Running Jobs Monitor must find the same running batch job before sending another Long Running Job Email. Example: The Long Running Jobs Monitor configuration is as follows: LR_JOB_MONITOR_RUNS_EVERY_X_MINUTES = 15 LR_JOB_MONITOR_REPEAT_ALERT_AFTER_X_CYCLES = 5 If the PICK_GEN job runs longer than 15 minutes, the system sends a Long Running Job email. The system will not send another Long Running Job email unless the PICK_GEN job is still running after an additional 75 minutes (15 minutes x 5 cycles = 75). |
CWDIRECTCP_LR_JOB_MONITOR_ALERT_FROM_EMAIL_ADDRESS |
Required. The “from” email address for the Long Running Job Email. |
Required. The list of email addresses that receive the Long Running Job Email when a job requires user evaluation. Each email address entered must be separated by a semi-colon (;). For example: email1@add.com;email2@add.com. |
Optional. A list of batch jobs excluded from the Long Running Jobs Monitor evaluation. Typically, these are jobs that run all day, such as the Async, ECommerce, and Drop Ship Integration jobs, or jobs that do not require a Long Running Job Email if they run too long. Separate each job in the list with a comma. For example: IX_CDC,CNTL_ASYNC,ORDR_ASYNC,OTHR_ASYNC,BILL_ASYNC. The default setting is IX_CDC,CNTL_ASYNC,ORDR_ASYNC,OTHR_ASYNC,BILL_ASYNC,EBO_ASYNC,EC_STS_INQ,EC_RETURNS,EC_CANCELS,EC_CAT_REQ. Note: If you enter a batch job name here and the job is also defined in the CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_OVERRIDE setting, the system considers the job an override and it is not excluded from the Long Running Jobs monitor. |
Optional. A list of batch jobs that the Long Running Jobs Monitor watches using a time other than the default time defined in the CWDIRECTCP_LR_JOB_MONITOR_ALERT_AFTER_X_MINUTES_DEFAULT setting. The format for this setting is BATCH_JOB_NAME,99, where BATCH_JOB_NAME is the name of the batch job, and 99 is how long, in minutes, the job must run before the system sends a Long Running Job Email. Separate each batch job name and its time with a comma; for example: BATCH_JOB_NAME1,120,BATCH_JOB_NAME2,30. Example: The default time is 60 minutes, indicating a job must be running for 60 minutes before the system sends a Long Running Job email. However, the PICK_GEN job runs longer than 60 minutes on a regular basis and you don’t want to be notified about this job unless it runs longer than 120 minutes. In this situation, enter PICK_GEN,120. The default setting is blank. |
Optional. Allows changes to the Monitor Properties without having to stop and restart Order Management System. See Applying Changes to the Monitor Properties for instructions. RELOAD = The next time the Long Running Jobs Monitor wakes up, reload the settings in Monitor Properties and restart the Long Running Jobs Monitor to use the new settings. EXIT = Stop the Long Running Jobs Monitor and do not send alerts until Order Management System is stopped and restarted. When you stop and restart Order Management System, the new settings will take effect. RUN or any other value, including blank = Run the Long Running Jobs monitor using the current settings. Important: If you make a change to the properties and change this setting to RELOAD or EXIT, after your change takes effect, make sure you change this setting back to RUN, blank, or any other value other than RELOAD or EXIT. The default setting is blank. |
For more information: See Running a Periodic Process on Server Startup for more information on the settings in Working with Admin Properties (CPRP) related to running a specified periodic process and its assigned periodic functions on server startup.
Use the following steps to apply changes to the Monitor Properties in Working with Admin Properties (CPRP).
1. |
Update the monitor property settings in Working with Admin Properties (CPRP) you wish to change. |
2. |
Use the CWDIRECTCP_LR_JOB_MONITOR_CONTROLLER setting to indicate when you want the changes to take effect. • RELOAD = The next time the Long Running Jobs Monitor wakes up, reload the monitory property settings in Working with Admin Properties (CPRP) and restart the Long Running Jobs Monitor to use the new settings. • EXIT = Stop the Long Running Jobs Monitor and do not send any Long Running Job emails until Order Management System is stopped and restarted. When you stop and restart Order Management System, the new settings will take effect. |
3. |
The next time the Long Running Job Monitor wakes up, it looks at the CWDIRECTCP_LR_JOB_MONITOR_CONTROLLER setting. • If the CWDIRECTCP_LR_JOB_MONITOR_CONTROLLER setting is RELOAD, the job restarts and uses the new settings. The system writes a message to the Application log indicating the job has restarted: Long running job monitor is actively monitoring. • If the CWDIRECTCP_LR_JOB_MONITOR_CONTROLLER setting is EXIT, the job shuts down. |
4. |
Once the Long Running Jobs Monitor has restarted based on the CWDIRECTCP_LR_JOB_MONITOR_CONTROLLER setting, change this setting to RUN, blank, or any value other than RELOAD or EXIT and save and exit the file. |
Note: After the changes take effect, make sure you change the CWDIRECTCP_LR_JOB_MONITOR_CONTROLLER setting back to RUN, blank, or any other value other than RELOAD or EXIT. |
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2023, Oracle and/or its affiliates. All rights reserved.
Legal Notices
