Appendix C :Lease Sales and Usage Tax
C.1 Introduction
In general, ‘Sales Tax’ is a tax paid to a governing body for the sales of certain goods and services. Similarly, Lease sales tax is the tax collected either on the total up-front lease price or during the lease period.
The sales tax for lease depends on the state and county where the asset is registered and every country has a governing body to collect, monitor and regulate Sales and Usage Tax collection. Depending on the country, the rules to collect sales and usage tax can be controlled by individual State or generalized across states. However, in most of the regions the Sales and Usage tax collection process is categorized as indicated below:
Category
Tax collection type
Upfront
This type of tax is collected while funding the lease application and a cus­tomer has the flexibility to include the tax amount as part of Lease Receiv­ables.
Stream
This type of tax is collected as part of the Customer Service and tax is esti­mated during billing process, fee assessment and so on. The opening bal­ances are updated and calculated tax is indicated in customer statements.
Exemption
If a customer is eligible for tax exemption during a period of time, an exemption certificate is issued by tax authorities to confirm and exclude the allowed tax components.
OFSLL supports recording, calculating, billing and collecting lease sales and usage tax and provides multiple options to process the calculation internally or through an external third-party vendor like 'Vertex O Series'.
Following are the methods by which you can record and calculate lease tax:
Method
Description
Internal
In this method, you can use the Origination and Servicing modules to calcu­late lease sales tax based on setup parameters.
External / Vertex
In this method, you can use the external integrated lease tax compliance applications like Vertex to calculate Sales and Usage Tax. Here, you need to only configure the required components in OFSLL which quantify for tax cal­culation and outsource the actual tax calculation to Vertex.
Manual
In this method, you can calculate the lease tax externally and only update the details into OFSLL Origination and Customer Service modules.
Based on the value defined in the Company parameter ‘XSL_TAX_INTERFACE’ (SALES TAX INTERFACE), OFSLL determines the method selected for sales tax calculation.
Lease Sales and Usage tax can either be origin based or destination based. Origin based tax or production tax is levied where goods or services are produced. Destination based tax or consumption tax are levied where goods and services are consumed.
During the lease tax calculation, below are the address reference used to refer Source and Destination address.
OFSLL supports two Sales Tax Modes (UPFRONT and CYCLE) and two Tax Methods (PURCHASE_PRICE and PAYMENT_STREAM) to determine if the Sales and Usage Tax has to be collected during Origination or Customer Service. Based on state specific rules, the tax details are updated in respective modules with the following combination:
This document contains the following sections:
C.2 Internal Lease Tax Calculation
In this method, the lease sales and usage tax details are updated and computed within OFSLL using the Setup, Origination and Customer Service modules.
This section contains the following details:
C.2.1 Sales Tax Setup
The Sales Tax screen facilitates to capture tax rules for Origination and Customer Service using itemizations or transactions.
C.2.1.1 To setup sales tax
  1. Navigate to Setup > Administration > System > Sales Tax screen.
  2. In the ‘Sales Tax Definition’ section, click ‘Add’. You can also perform any of the Basic Operations mentioned in Navigation chapter. A brief description of the fields are given below:
    Field
    Description
    Tax
    Specify a unique value to identify the tax rule definition.
    Description
    Specify a description for the tax rule.
    Start Dt
    Select the start date for tax rule definition from the adjoining calendar.
    End Dt
    Select the end date for tax rule definition from the adjoining calendar.
    Enabled
    Check this box to enable the tax rule definition.
    Selection Criteria section
    Channel
    Select the method to calculate lease tax as either Internal or External (Vertex) from the drop-down list. The list is populated based on val­ues maintained in ‘TAX_CHANNEL_CD’ lookup code.
    Company
    Select the portfolio company from the drop-down list.
    Branch
    Select the portfolio branch from the drop-down list.
    Billing Cycle
    Select the frequency of billing cycle from the drop-down list. The list is populated based on values maintained in ‘LEASE_BILL_CY­CLE_CD’ lookup code.
    Product
    Select the product to which the sale tax rule is applicable from the drop-down list.
    Asset Class
    Select the asset class from the drop-down list.
    Asset Type
    Select the asset type from the drop-down list. The list is populated with all enabled Asset Types.
    Sub Type
    Select the asset sub type from the drop-down list.
    Asset Make
    Select the asset make from the drop-down list.
    Asset Model
    Select the asset model from the drop-down list.
    Age
    Specify the age of the asset.
    Source Address section - This section facilitates to record the location details where asset is manufactured.
    Country
    Select the country from the drop down list. The list is populated based on values defined in ‘COUNTRY_CD’ lookup code.
    Zip From
    Select the zip code from where the territory starts from the drop down list.
    Zip To
    Select the zip code up to where the territory ends from the drop down list.
    City
    Select the city from the drop-down list.
    State
    Select the state from the drop-down list.
    County
    Select the county from the drop-down list. The list is populated based on values defined in COUNTY_CD lookup code.
    Destination Address section - This section facilitates to record the location details where asset is sold.
    Country
    Zip From
    Zip To
    City
    State
    County
  3. Perform any of the Basic Actions mentioned in Navigation chapter.
C.2.1.2 Origination
The Origination tab of Sales Tax screen facilitates to capture details for ‘upfront’ tax calculation during Origination which is based on Purchase Price, Itemization/Lease Payment amount, and Total of Lease Payments.
  1. Navigate to Setup > Administration > System > Sales Tax > Origination tab.
  2. In the ‘Formula Details’ section, click ‘Add’. You can also perform any of the Basic Operations mentioned in Navigation chapter. A brief description of the fields are given below:
    Field
    Description
    Calc Method
    Select the lease tax calculation method as one of the following from the drop-down list. The list is populated based on SALES_TAX­_INT_AMT_CD lookup code for Internal calculation method and SALES_TAX_EXT_AMT_CD lookup code for Vertex.
    - Lease Payment Amount: fixed tax on lease installment amount
    - Total of Lease Payment: fixed tax on total lease amount
    - Flat Itemization: fixed tax amount charged for configured itemiza­tions
    - Percentage of Itemization Amount: fixed tax percentage charged for configured itemizations
    - Purchase Price Amount: fixed tax on purchase price of asset retail valuation.
    ** Refer to the illustrated example for information on calculation methods.
    Itemization
    Select the required itemization from the drop-down list. You can define multiple itemization for the selected calculation method to determine sales tax.
    Note: This field is available only if the calculation method is either FLAT ITEMIZATION AMOUNT or PERCENTAGE OF ITEMIZATION AMOUNT.
    Sign
    Select ‘+ve’ option (default) if the calculated sales tax amount is to be added to the lease application or ‘-ve’ option if a tax rebate is given on the lease application.
    Note: This field is displayed only for Internal sales tax calculation method.
    Value
    Based on the calculation method selected, specify either amount or percentage of tax to be calculated.
    Tax Exemp­tion
    Check this box to indicate if the tax formula can be exempted from sales tax calculation for lease applications having valid exemption details. Else, sales tax is assessed for lease application using this tax formula.
    Note: This check box is displayed only for Internal sales tax calcula­tion method.
    Enabled
    Check this box to enable the tax formula.
** The table below is an illustration on how upfront tax is determined for different calculation methods:
Payment Amt
Total Amt
MSRP
Item Amt
Calc Method
Tax %
Tax Amt
Payment Amt
Total Amt
$558.17
$20,093.72
$20,000
$20,000
Purchase Price
5%
NA
$558.17
$21,093.72
$558.17
$20,093.72
$20,000
$20,000
Percent of Itm Amt
5%
NA
$558.17
$21,093.72
$558.17
$20,093.72
$20,000
$20,000
Flat of Itm Amt
$1,000
$558.17
$21,093.72
$558.17
$20,093.72
$20,000
$20,000
Lease Payment Amt
5%
NA
$586.08
$21098.83
$558.17
$20,093.72
$20,000
$20,000
Total of Lease Payment Amt
5%
NA
$558.17
$21098.41
C.2.1.3 Customer Service
The Customer Service tab of Sales Tax screen facilitates to capture details for ‘Stream’ tax calculation when Bill/Due date or Late Charge transactions are posted, and also to estimate tax for Payoff Quote lease on unpaid lease amount.
  1. Navigate to Setup > Administration > System > Sales Tax > Customer Service tab.
    Field
    Description
    Calculation Method
    - Flat Transaction Amount - fixed tax amount charged for config­ured transactions.
    - Percentage of Transaction Amount - fixed tax percentage charged for configured transactions.
    Txn Code
    Select the transaction code from the drop-down list. The list is popu­lated with the following values based on SALES_TAX_TXNS_CD lookup code.
    - Bill/Due date
    - Late Charge
    - Payoff Quote lease
    ** For information on how tax is calculated based on combination of calculation method and transaction code, refer to the below illustrated example.
    Sign
    Select ‘+ve’ option (default) if the calculated sales tax amount is to be added to the lease account or ‘-ve’ option if a tax rebate is given on the lease account.
    Value
    Tax Exemp­tion
    Check this box to indicate if the tax formula can be exempted from sales tax calculation for lease accounts having valid exemption details. Else, sales tax is assessed for lease account using this tax formula.
    Enabled
** The table below is an illustration on how stream tax is calculated with the combination of calculation method and transaction code selected.
Txn Code
Calc Method
Tax %
Tax Amt
Txn Amt
Total Txn Amt
BILL/DUE DATE
Percentage of Transaction Amt
5%
$558.17
$586.08
BILL/DUE DATE
Flat Transaction Amt
$100
$558.17
$658.17
LATE CHARGE
5%
$20
$21
LATE CHARGE
$5
$20
$25
C.2.1.4 Range
The Range tab of Sales Tax screen facilitates to define range (gradual increase in tax rate) for tax calculation based on different charges levied for Product/Service.
For example if the cost of the vehicle is less than or equal to $20,000 then Sales and Usage Tax slab is 20% and if the cost is greater than $20,000 then slab is 30%. To facilitate this, below configuration should be maintained in the system.
Origination
Calculation Method
Itemization
Sign
Value
Enabled
ITM CASH SALES
100
Y
Range
Amount From
Percentage
Enabled
20000
20
Y
20001
30
Y
To define Range for Sales tax calculation
  1. Navigate to Setup > Administration > System > Sales Tax > Range tab.
  2. In the ‘Range Details’ section, click ‘Add’. You can also perform any of the Basic Operations mentioned in Navigation chapter. A brief description of the fields are given below:
    Field
    Description
    Amt From
    Specify the minimum amount from which tax has to be determined.
    Percent
    Specify the percentage of tax to be calculated based on amount.
    Enabled
    Check this box to enable the range.
C.2.2 Sales Tax Calculation at Origination
The sales and usage tax details defined in setup are used to calcuate tax in Origination Decision / Contract screen.
C.2.2.1 Calculate Tax in Decision/Contract tab
  1. Navigate to Origination > Underwriting / Funding > Decision/Contract screen.
  2. Click ‘Calculate Tax’ button. Based on the setup details, system calculates the sales tax for ‘Upfront’ and ‘Stream’ category in the following way:
C.2.2.2 Exempt Sales Tax in Decision/Contract tab
The ‘Tax Details’ sub tab in Decision/Contract tab facilitates to record tax exemption details. If exemption details are provided for the application, all the tax details marked with Exemption Indicator 'Y' in setup are exempted for this application.
Since the ‘Tax Details’ sub tab is available in both Decision and Contract tabs, you can choose to define sales tax exemption either during Decisioning or Funding. However, exemption selected during decisioning will be applicable on funding if no changes are made.
  1. Navigate to Origination > Underwriting / Funding > Decision/Contract > Tax Details sub tab.
  2. Click ‘Edit’. You can also perform any of the Basic Operations mentioned in Navigation chapter. A brief description of the fields are given below:
    Field
    Description
    Exemption
    Check this box to indicate that application is eligible for tax exemption Else, all the sales tax defined in setup are applicable for the applica­tion.
    Note: Sales tax exemption is eligible only if the exemption option is checked in both Origination (Tax Details tab) and Setup screen (Setup > Administration > System > Sales Tax screen).
    Exemption Start Dt
    Select the exemption start date from the adjoining calendar.
    Exemption End Dt
    Select the exemption end date from the adjoining calendar. This field is enabled on selecting the exemption start date.
    Reason
    Select the exemption reason from the drop-down list. This field is enabled only if ‘Exemption’ check box is selected.
    Tax Code
    View the tax code applied for this application.
C.2.2.3 Attach Sales Tax Exemption Certificate
For every sales tax exemption, you can provide a proof of verification by attaching the exemption certificate to the application. However, validating the authenticity of the certificate is not handled in OFSLL.
To attach sales tax certificate to an application, you need to first upload the document into the system through ‘Application Documents’ screen and attached it to the application through Application > Document tab.
  1. From the LHS menu, click Origination > Application Documents link.
  2. In the Document Maintenance > Action section, select ‘Attach Document (Client)’ option.
  3. In ‘Select Document’ section, browse for the file location and “Upload’.
  4. In ‘Document Details’ section, select the uploaded document and click ‘Edit”.
  1. Navigate to Origination > Underwriting / Funding and select the lease application.
  2. Click ‘Document’ tab. In ‘Application Document Details’ section, select the uploaded document and click ‘Upload’.
  3. (Optional) You can also edit the document details before upload by adding additional information as comments.
The sales tax exemption certificate is linked to the application. For more information on the process of document upload, refer to ‘Application Documents’ chapter in the User Guide.
C.2.2.4 Generate Lease Sale and Usage Tax Report
After the sales tax details are calculated, you can retrieve the information to view the sales tax amount recorded during calculation and actual tax collected after funding, by generating ‘Sales usage tax (Lease)’ report. This report can be generated for all applications with Sales Tax Mode and Tax Method ‘UPFRONT/ PURCHASE_PRICE’.
In the report, the tax recorded before funding is referred as ‘Quotation Tax Amt’ and actual tax recorded for the application is referred as ‘Invoice Tax Amt’. Since this is a system generated report, any difference in these amount are to be manually updated into the account.
  1. From the LHS menu, click Origination > Reports link.
  2. In the ‘Reports’ section, filter report with description ‘SALES USAGE TAX - LEASE’.
  3. In the ‘Report Parameters’ section, select/specify the required parameters and click ‘Run Report’.
The report is generated in the selected format with the details as indicated below. For detailed information on report generation process, refer to ‘Reports’ chapter in User Guide.
C.2.3 Sales Tax Calculation at Customer Service
The sales and usage tax details defined in Setup > Sales Tax > Customer Service tab are used to calculate sales tax for ‘Stream’ accounts. OFSLL records sales tax by posting Sales / Use Tax transaction which in-tun updates the Sales / Usage Tax balance on the account.
C.2.3.1 Calculate Tax in Customer Service
  1. For the calculation method defined in setup as either ‘Flat Transaction Amount’ or ‘Percentage of Transaction Amount’, the scheduled batch job posts the following type of transactions:
    Transaction Code
    Batch Job
    Transaction
    Bill/Due Date
    TXNDDT_BJ_100_01
    BILLING/DUE DATES PROCESSING
    DDT
    BILL/DUE DATE
    Late Charge
    TXNLTC_BJ_100_01
    LATE CHARGE PROCESSING
    FLC
    LATE CHARGE
  1. On successfully posting the transaction, the details are updated on to the customer account in Customer Service > Transaction History > Transactions tab.
  2. For the calculation method defined in setup as ‘Payoff Quote Lease’, on posting this transaction system calculates the tax on unpaid Lease Receivables and displays the Sales / Usage Tax due bucket with the total of current outstanding and future dues.
C.2.3.2 Exempt Sales Tax in Customer Service
If exemption details are provided in Origination, system automatically propagates the same to Customer Service account. You can update exemption details during Customer Service for an account by posting a non-monetary ‘SALES TAX EXEMPTION DETAILS MAINTENANCE’ transaction.
For information on populating the parameter values, refer to Exempt Sales Tax in Decision/Contract tab section.
On successfully posting the transaction, the exemption details are updated in Servicing > Customer Service > Account Details > Tax Details tab.
C.2.3.3 Attach Sales Tax Exemption Certificate
For every sales tax exemption, you can provide a proof of verification by attaching the exemption certificate to the account. However, validating the authenticity of the certificate is not handled in OFSLL.
To attach sales tax certificate to an application, you need to first upload the document into the system through ‘Account Documents’ screen and attached it to the application through Customer Service > Document Tracking tab.
  1. From the LHS menu, click Servicing > Account Documents link.
  1. Navigate to Servicing > Customer Service > Document Tracking tab and select the lease application.
  2. Click ‘Document’ tab. In ‘Account Document Details’ section, select the uploaded document and click ‘Upload’.
The sales tax exemption certificate is linked to the application. For more information on the process of document upload, refer to ‘Account Documents’ chapter in User Guide.
C.2.3.4 Sales tax in Account Statement
The sales and usage tax calculated on the account is captured in Servicing > Customer Service > Account Details > Statements tab so that the customer is updated about lease sales tax amount levied on the account. Updating the sales tax details in ‘Statement Details’ section is done through a scheduled batch job.
C.2.3.5 Generate Lease Sale and Usage Tax Report
After the sales tax details are calculated, you can retrieve the information to view the sales tax amount recorded on the account, by generating ‘Sales usage tax (Lease)’ report. This report can be generated for all accounts with Sales Tax Mode and Tax Method ‘CYCLE/ PAYMENT_STREAM’.
  1. From the LHS menu, click Servicing > Reports link.
C.3 External Lease Tax Calculation
In this method, the lease sales and usage tax details are computed in an external integrated system called Vertex® - Indirect Tax for Leasing and on a successfully tax computation, the sales tax details are updated into OFSLL setup, Origination and Customer Service modules.
Vertex® Indirect Tax for Leasing facilitates with tax calculation solutions to address the needs of leasing software vendors and their enterprise customers within the equipment and vehicle leasing industries. Vertex Leasing leverages the Vertex O Series platform and automates the taxability and ongoing maintenance of rental and leasing rules.
C.3.1 OFSLL Vertex Integration
The below image indicates Vertex integration with OFSLL and the associated components.
A brief description of the integrated components are provided below:
Vertex Adapter - This adapter is used to receive OFSLL interface data and create Vertex Specific SOAP Request/Response. Vertex provides ‘FlexibleFields’ to exchange implementation specific customization data. These fields are mapped to PL/SQL custom fields in Vertex Adapter and can be customized during implementation. However, this is Vertex specific adapter and has to be replaced specifically to support other Tax Vendor.
Common Tax API - When Vertex Adapter receives a response, OFSLL uses Common Tax API to update Sale and Usage Tax details. This adapter contains exit point and can be used to update Tax details from External System.
MDB Interface - To support Vertex interface new message types, following services are added:
Also the existing error queue [OFSLL_OUTBOUND_Q] is enhanced to record Vertex interface error messages during the integration.
For more details on integration, refer to OFSLL technical documentation. During the process of integration, there observed discrepancies are noted. Refer to Limitations of Vertex integration section for details.
Note
During Origination, all Vertex interface calls are handled through user interface and on Funding/Customer Service, these calls are made from database using MDB flow.
Following Vertex services are used in OFSLL with the integration. For detail information, refer Vertex O Series documentation.
Service
Description
Quotation Request
It is used to estimate the Tax of the proposed Lease Contract. This service is triggered by OFSLL to estimate tax during Decision/Con­tract and Lease Payoff Quote.
Invoice Request
It is used to bill the Tax for the Lease Contract. This service is trig­gered by OFSLL to record tax during Funding and Lease transac­tion posting.
Delete Request
It is used to reverse Vertex Invoice request. Every Vertex Invoice request trigged from OFSLL use ‘transactionId’ to stamp OFSLL internal transaction reference. This internal transaction id is used by this service to reverse Vertex Invoice request based on OFSLL reversal.
Create Customer Request
It is used to register a Customer.
Create Certificate Request
It is used to upload Tax Exception Certificate Id for Customer.
C.3.2 Setup changes
To enable Vertex integration, the company parameter XSL_TAX_INTERFACE’ has to be updated as 'VERTEX' and ‘VTX_OUTBOUND_URL’ also needs to be updated with valid Vertex URL.
The sales tax information recorded in OFSLL Setup > Administration > System > Sales Tax screen is exchanged with Vertex interface through vertex adapter using SOAP Request/Response.
For information on recording sales tax rules in setup, refer to Sales Tax Setup section.
C.3.3 Changes in Origination Module
Since the process of sales tax collection is handled from external system, the information received from Vertex are only updated into the respective tables in OFSLL. The same is available in the UI as detailed in Sales Tax Calculation at Origination section.
To load exemption certificate into OFSLL, follow the same process as detailed for internal sale tax calculation method using in Origination > Underwriting / Funding ‘Document’ tab. To upload sales tax exemption certificate to vertex, click “Upload’ button in the Application documents tab.
On successful upload, a ‘Tax Exemption Certificate ID’ is updated in to the system and the ‘Upload’ button is disabled.
C.3.4 Changes in Customer Service Module
The sales tax calculation process is similar to the internal method as detailed in Sales Tax Calculation at Customer Service section except that the Sales/Usage Tax - link transactions is posted only on receiving the tax details from Vertex. This transaction will be posted after posting the main transaction.
To load exemption certificate into OFSLL, follow the same process as detailed for internal sale tax calculation method using in Servicing > Customer Service > Document Tracking tab. To upload sales tax exemption certificate to vertex, click “Upload’ button in the Account Document Details section tab.
C.3.5 Limitations of Vertex integration
Following are the limitation noticed with Vertex integration:
C.4 Manual Lease Tax Calculation
In this method, the Lease Sales and Usage tax are computed manually and only the calculated details are recorded into OFSLL Setup, Origination, and Customer Service modules. For information on updating the details in the respective modules, refer to Internal Lease Tax Calculation section.
Since OFSLL interface only supports to record and display the information, validating and processing the same has to be done outside the system.
