Appendix A ClearIVS SQL Script
The script below should be executed against the IVS database when preparing for versioning. It will leave current security intact.
DB2 Database
delete from ivsconfigpackagecontents
go
go
delete from ivsmigrationsetcontents
go
go
delete from ivsreleasepackage
go
delete from ivsreleasehistory
go
delete from ivsversion
go
delete from ivsversionfield
go
delete from ivsversionhistory
go
SELECT
(SELECT COUNT* FROM IvsConfigPackageContents) AS CPC,
(SELECT COUNT* FROM IvsConfigPackage) AS CP,
(SELECT COUNT* FROM IvsMigrationSetContents) AS MSC,
(SELECT COUNT* FROM IvsMigrationSet) AS MS,
(SELECT COUNT* FROM IvsReleasePackage) AS RP,
(SELECT COUNT* FROM IvsReleaseHistory) AS RH,
(SELECT COUNT* FROM IvsVersion) AS V,
(SELECT COUNT* FROM IvsVersionField) AS VF,
(SELECT COUNT* FROM IvsVersionHistory) AS VH
FROM sysibm.sysdummy1
go
Oracle Database
go
go
go
go
go
go
go
go
go
SELECT
FROM DUAL
go
