Encrypting Passwords in TomEE
Its a good practice to encrypt the data base passwords in tomee.xml and user passwords in tomcat-users.xml. Following is sample procedure/steps to encrypt the corresponding passwords.
Note: The following configuration is just an example to hash the passwords using 'SHA-512' algorithm. This should be changed depending upon the standards prescribed by individual companies.
To Hash the data base password in tomee.xml:
- Navigate to the bin folder in tomee home directory.
- Depending on the OS, open the corresponding files
- Open tomee.bat in command prompt for Windows. Open tomee.sh for Linux
- type the following:
- tomee.bat cipher <original password> for Windows. For Linux, tomee.sh cipher <original password>
- Example: tomee.bat/sh cipher password (cipher is the key word and password is the string which needs to be encrypted)
- Once the hashed string is available, update the password in the tomee.xml file as below:
<Resource id="ADMINSERVERSEARCHDS" type="javax.sql.DataSource">
jdbcDriver = oracle.jdbc.driver.OracleDriver
jdbcUrl = jdbc:oracle:thin:@localhost:1521:orcl
userName = oipaqa
password = pfgn0gS/5rozVUv5LG7YLA==
PasswordCipher = Static3DES
jtaManaged = false
</Resource>
To Hash the user password in tomcat-users.xml:
- Open digest.bat for Windows. Open digest.sh for Linux
- Generate the hashed string for the user password by providing the user password as input.
- For Using the SHA-256 algorithm:
- ./digest.sh -a sha-256 -h org.apache.catalina.realm.MessageDigestCredentialHandler password (this password is the actual user password) → For Linux env
- digest.bat -a sha-256 -h org.apache.catalina.realm.MessageDigestCredentialHandler password (this password is the actual user password) → For Windows env
- For Using the SHA-512 algorithm:
- ./digest.sh -a sha-512 -h org.apache.catalina.realm.MessageDigestCredentialHandler password (this password is the actual user password) → For Linux env
- digest.bat -a sha-512 -h org.apache.catalina.realm.MessageDigestCredentialHandler password (this password is the actual user password) → For Windows env
- For Using the SHA-md5 algorithm:
- ./digest.sh -a md5 -h org.apache.catalina.realm.MessageDigestCredentialHandler password (this password is the actual user password) → For Linux env
- digest.bat -a md5 -h org.apache.catalina.realm.MessageDigestCredentialHandler password (this password is the actual user password) → For Windows env
- Once the hashed string is generated with any of the above algorithms, change the configurations in server.xml file
Finally, the generated hashed password should be updated in the tomcat-users.xml file
<user username="qatester" password="c732f45c5877232dbbc992b464f381019c16c4b7bb8680a1452a08f6db6d910f$1$c1daf3eb0daadcb0e60ca97f42048c17143c7487b29ced0deb18994b856737a0f8274e40a121eca99ff0ff0579b8fcc413310ace9cb0fce543beeb4d462d5801" roles="SL_ADMIN" />
<Realm className="org.apache.catalina.realm.LockOutRealm">
<!-- This Realm uses the UserDatabase configured in the global JNDIresources under the key "UserDatabase". Any editsthat are performed against this UserDatabase are immediately available for use by the Realm.
<Realm className= "org.apache.catalina.realm.UserDatabaseRealm"resourceName="UserDatabase">
<CredentialHandler className="org.apache.catalina.realm.MessageDigestCredentialHandler" algorithm="SHA-512" />
</Realm>
</Realm>
The algorithm which selected for hashing the given password should the same as the algorithm mentioned in the server.xml file
