Engine Error Output Window
The Engine Error Output window displays errors that are found when a transaction, segment or calculate general rule is compiled. It also displays validation errors that occur when checking-in or saving information in the Admin Explorer tab. If this window is not visible, click Window on the Main Menu and select it.
There are four types of errors that are listed in the Engine Error Output window.
Translation Error is an error that was caused by a syntax error in the math section. All translation errors will be listed at one time.
Compilation Error is an error with the configuration in the math section. In this situation, the compile feature stops compiling the configuration of a transaction after it locates this type of error. Only one compilation error at a time is handled. After resolving the compilation error and selecting the Save button
, the compiler
runs again through the configuration and locates the next compilation
error. This process repeats until all errors have
been resolved. -
Runtime Error is a system code error.
Warning doesn't keep transactions or segments from compiling. It simply provides an alert regarding missing information or information that is not critical for compilation.
Refer to Compile a Transaction or Segment for the steps involved in compiling.
