DownstreamMessagePushDefinition for JMS
DownstreamMessagePushDefinition defines message delivery using JMS protocol. DownstreamMessagePushDefinition for JMS requires the following details.
<ProviderUrl> </ProviderUrl>
<ConnectionFactory> </ConnectionFactory>
<JMSdestination> </JMSdestination>
<JMSDeliveryMode> </JMSDeliveryMode>
<JMSPriorityLevel> </JMSPriorityLevel>
<JMSTimetoLive> </JMSTimeToLive>
<JMSAcknowledgement> </JMSAcknowledgement>
DownstreamMessagePush Elements and Attributes
Element/Tag Parent Element Definition Attribute Element/Attribute Value and Description
<DownstreamMessagePushDefinition>
Opening and closing t tag for DownstreamMessagePushDefinition rule.
<Event> <DownstreamMessagePushDefinition> Required and Repeatable element: Specifies required event details. Event is repeatable with different Event environments.
<Event> Name of the event EVENTNAME Required:
Note: If the EVENT value in PushNotifications does not match with any EVENT NAME value in DownstreamMessagePushDefinition, system displays an error message.
<Event>
EVENTMETHOD Required: EventMethod can be JMS
<Event>
ENV
Required:
ENV can be Test/Prod/Dev to support SDLC. For same event there can be multiple destination addresses to support different environments.
Note: If messages from multiple events in the PushNotifications fails due to ENV value mismatch between PAS properties and DownstreamMessagePushDefinition,multiple,errors one for each EVENT will get displayed.
<JmsConfiguration> <Event> Opening tag for Address details. Contains required details to make service calls.
<ProviderUrl> <JmsConfiguration> Required: This element identifies the provider Url with port number.
<ConnectionFactory> <JmsConfiguration> Required: Value of this element can be the connection factory name.
<DestinationName> <JmsConfiguration> Required: Queue or Topic name
<DeliveryMode> <JmsConfiguration> Optional: As per JMS standards
<PriorityLevel> <JmsConfiguration> Optional: As per JMS standards
<TimetoLive> <JmsConfiguration> Optional:As per JMS standards
<AcknowledgementMode> <JmsConfiguration> Optional:As per JMS standards
<MaxTimeOut> <JmsConfiguration>
Required: It is the time an activity waits before timeout.
Value entered should be in milliseconds.
Value: Recommended timeout period is 100ms.
<Security> <Event> Defines security details.
<Security> Name of the security type TYPE
Required
Values: HTTP,WSS
<UserName> <Security> Required: Includes user details for authentication
<Password> <Security> Required: Includes password details for authentication
XML Schema
   <Event EVENTNAME=" " EVENTMETHOD="JMS" ENV=" ">
   <JmsConfiguration>
        <DestinationName> </DestinationName>
        <DeliveryMode> </DeliveryMode>
        <PriorityLevel> </PriorityLevel>
        <TimetoLive> </TimetoLive>
        <AcknowledgementMode> </AcknowledgementMode>
        <MaxTimeOut> </MaxTimeOut>
   </JmsConfiguration>
   <Security>
       <UserName> </UserName>
       <Password> </Password>
    </Security>
  </Event>
</DownstreamMessagePushDefinition>
XML Example
    <Event EVENTNAME="Event two" EVENTMETHOD="JMS" ENV="Test">
        <JmsConfiguration>
             <ProviderUrl>http://192.168.4.11:8011 </ProviderUrl>
        </JmsConfiguration>
        <Security>
           <User> </User>
       </Security>
    </Event>
    <EVENT EventNAME="Event two" EVENTMETHOD="JMS" ENV="Prod">
          <JmsConfiguration>
          </JmsConfiguration>
          <Security>
                   <User> </User>
          </Security>
     </Event>
