FundAllocation Element
This element dictates whether the allocation frame will be attached to the Activity Detail screen.  If this element is present and set to Yes, the Allocation section will appear on the Activity Detail screen.  Further configuration will determine the funds that can be selected.
FundAllocation Elements And Attributes
Element/Tag Definition Attribute Element/Attribute Value and Description
<FundAllocation>
Required:
This is the start and end element. This is a required element for all transactions.
Yes:FundAllocation functionality is invoked.
No:FundAllocation functionality is not used.
ALLOCATIONTYPES
Percent , Amount, Mixed, Units
Comma separated list.
ALWAYSEQUALPERCENT
Yes , No
AMOUNTPRECISION
Integer
Sets the number of decimal places to be used for allocations with percent method code. Default values are 2 for Amount, 4 for Percent, and 6 for Unit.
ASSIGNMENT
Transfer: Defines the type of assignment.
CLASS
String:Defines the class of the fund.
EXCLUDEFUNDFIELD
String - Defines the value of the field or fund name to be included.
EXCLUDEFUNDFIELDVALUE Yes, No
EXCLUDEFUNDSTATUS
Yes, No
Excludes funds from being displayed based on fund status.
EXCLUDETYPE Allows funds to be excluded from the allocations that are moving money into a fund, based on the type of fund.
FUNDLIMIT
Integer:  Maximum number of funds that can be included in the allocation.
INCLUDEFUNDFIELD
String
INCLUDEFUNDFIELDVALUE
String - A comma-separated list of fund names that are allowed to be included.
PERCENTPRECISION
Integer: Sets the number of decimal places to be used for allocations with percent method code. Default values are 2 for Amount, 4 for Percent, and 6 for Unit.
REPEATFUND
Yes:Same fund can be selected in the From and To sections of a transfer allocation.
No:Same fund can NOT be selected in the From and To sections of a transfer allocation.
SHOWVALUATION
Yes: Fund values will be displayed. Must have YES in AllocationFrom element as well.
No: Fund values will NOT be displayed.
UNITPRECISION
Integer
USEFUNDCLASSALLOCATION
Yes, No
Indicates fund class allocation to be used.
XML Example
<FundAllocation ALLOCATIONTYPES=”Percent, Amount”>Yes</FundAllocation>
<FundAllocation PERCENTPRECISION=”2”>Yes</FundAllocation>
