The Print Disembark Letter allows you to print and notify guests of their debarkation time and meeting location.
- From the Cashier File menu, select the Print Disembark Letter option.
- Select the Disembarkation Date from the drop-down list.
- In the Detail Selection section, select the appropriate option and click Search.
- Select the Passenger name from Selected Passenger section and then click Print Selected.
