Assigning Permissions
The Company Administrator assigns access permissions to the Internationalization node, and the permissions can be set for both Users and Groups.
There are two types of permissions available for the Internationalization node:
- Configure
- View
Users who have Configure permission can translate the custom strings, and Users who have View permission can only view the translated custom strings.
To assign permissions to a User through the Company Users or Partner Users node:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select either Company Users or Partner Users.
- Select a user from the log.
- Go to the Permissions tab.
- Expand Administration Mode Access, expand Configuration, and select Internationalization.
- Assign permissions as necessary.
To assign permissions to a User with Access Control:
- In the left Navigator, select User Administration, and then select Access Control.
- In the pane on the right, expand Administration Mode Access, expand Configuration, and select Internationalization.
- Click Add.
- Click Add Users/Groups.
- Select all users to assign permissions to and click Add. Click OK when finished.
- In the Permission Settings block, assign View or Configure permissions to all selected users. Click OK when finished.
See Also
Translating Custom Strings (Internationalization)
Internationalization Node Properties
Displaying Custom Strings and System Strings
Internationalization and CSV Files
Internationalization and Web Services
Internationalization (Email Notifications)
Internationalization (Support for Tools)
Internationalization (Oracle Analytics Server Custom Reports)
Internationalization (Dashboards)
Internationalization (Help Files)
Internationalization (Spell Check)
Internationalization (Date and Time Zone Formats)
Internationalization (Audit Log)
Last Published Tuesday, April 15, 2025
