Custom Report Window (Template File tab)
The Template File tab lets you upload:
- Multiple templates for the custom report (RTF, PDF, Excel, eText).
- Data model (.XDM) file (for report with external data model)
- XLIFF translation files
Use this tab to add, modify, remove, or download files and click Apply when finished.
You can build a Rich Text Format (RTF) report template and upload the template to your Custom Report in Unifier Essentials.
To create a simple RTF template:
- Open Microsoft Word.
The application must have the Microsoft Word Oracle Analytics Publisher plug-in installed. See Download and Install Oracle Analytics Publisher Desktop for Microsoft Office.
- Click the Word Oracle Analytics Publisher ribbon.
- Click Sample XML to import your sample data and wait until the data is loaded successfully.
Note: You may need to complete the General tab first and click Apply before this tab appears.
Last Published Tuesday, April 15, 2025
