Custom Report Window (Sample Data tab)
The Sample Data tab lets you generate the sample XML data, which you can use to create layouts for the custom report. In the case of an external data model-based report, the report must have been published to the Oracle Analytics Server at least once before the sample XML data can be generated.
Note: Depending on the Report Level that you have selected in the General tab, the fields and selections in this tab change.
- In the Sample Data tab select a sample, determine the number of rows that you want to see, and click Generate.
- When finished, click Download.
- Click Apply.
- Click OK.
Last Published Tuesday, April 15, 2025
