Custom Print Window (Template File tab)
The Template File tab contains information about the print layout, along with the corresponding templates and XLIFF translations.
You can build a Rich Text Format (RTF) print template and upload the template to your Custom Print in the system.
To create a simple RTF template:
  1. Open Microsoft Word.
    The application must have the Microsoft Word Oracle Analytics Publisher plug-in installed. See Download and Install Oracle Analytics Publisher Desktop for Microsoft Office.
  2. Click the Word Oracle Analytics Publisher ribbon.
  3. Click Sample XML to import your sample data and wait until the data is loaded successfully.
You can use the following option for each template:
Add
Use Add to upload the print layout and the translated XLIFF files. The XLIFF files are used for translation purposes. When you click Add, the "Add template and Files" window opens.
The "Add template and Files" window has two sections:
Template
The Template section contains the following fields:
A Template Type can be changed if the template is in Creation stage. After it is created, the Template Type cannot be modified, and the custom print designer must create a template (of the desired type) and remove the one that is no longer required.
Translated XLIFF files for the Template
If you want to internationalize the product, the translated XLIFF files can be uploaded, for the corresponding languages, in the Translated XLIFF filed for template section.
Note: The languages listed are the active languages selected by the administrator in the Configuration - Internationalization log.
Click Apply when finished.
When you open an existing Custom Print, the Template File tab lists all available templates. The first template is always marked as Default, but you can change the default template.
Modify
Use Modify to modify the existing print template and XLIFF files. You must select an existing file before you can proceed. When you click Modify, the "Modify Template and Files" window opens.
The "Modify Template and Files" window has two sections:
Template
Remove
To remove a Custom Print template, select the template, and click Remove.
Note: To delete a Custom Print template, you can select the Custom Print template from the log and click Delete. You can delete a Custom Print template regardless of the Custom Print template status.
Download
The Download option lets you download the template and the corresponding translated XLIFF files. You must select an existing file before you can proceed.
When you click Download, a zip file is generated. The zip file name format must be:
Template_<Numeric part of report key>_<File Type>.zip
Example
Template_483_PDF.zip
You can copy a Custom Print template to use as a base for a new Custom Print template.
Note: After copying a Custom Print template, the term, "Copy of" appears at the beginning of the name of the new Custom Print template.
Last Published Tuesday, April 15, 2025
