Custom Print Window (Sample Data tab)
You can use the Custom Print window Sample Data tab to download sample data for designing the custom print template file. You can use the XML data to design the print template file in the Oracle Analytics Server.
The XML tags in the sample data are displayed for all the fields that are relevant to the selected data source. The XML tags are grouped according to the XML elements or data sets. The data sets displayed in the Sample Data tab are driven by the data source type. For a Workflow BP, the various elements are the upper forms, line items, workflow details, comments, and so forth.
  1. In the Sample Data tab click Generate.
  2. When finished, click Download.
  3. Click Apply.
  4. Click OK.
Last Published Tuesday, April 15, 2025
