Uploading a Template for External Data Model Type Custom Report
To upload a template for External data model type custom report:
- In the Report file tab, click the Add/Modify button.
- Click the Browse button, navigate to the .XDM file you want to use for the data model, and click the Upload button.
The system uploads the data model for the report to the BI server.
- (Optional) To modify the data model, you can download it to your local drive by clicking the Download button.
- Click OK.
You must upload the Data Model file (.XDM) from the custom report Template File tab, using the following parameters:
uuu_p_project_idProject ID
uuu_p_context_company_idCompany ID
uuu_p_process_idWorkflow process ID
uuu_p_source_idBusiness process record ID
uuu_p_object_typeBusiness process ID
uuu_p_hide_task_detailsTo hide the task status if the user does not have permission. The value of 0 is passed if the user does not have permission to view the task statuses.
uuu_p_hidden_commentsTo view the hidden comments if the user has the permission. The value of 1 is passed if the user has the permission to view hidden comments.
These parameters are used to pass information from the Unifier Essentials runtime to the Oracle Analytics Server (integration at runtime).
Last Published Tuesday, April 15, 2025
