Parameters for External Multiple Custom Print
The following is a list of parameters for the External Multiple type custom print that you must use in the data model to ensure that the Bulk Action (in Tasks and Business Processes logs) works properly:
Parameter Name | Description | Required | Comma-Separated Values |
| Contains the value of the Project IDs. | Yes | Yes |
| Contains the value of the customer's Company ID. | Yes | No |
| Contains the value of the Workflow Process IDs. | Yes Only for Workflow type business processes. | Yes |
| Contains the value of the Record IDs. | Yes | Yes |
| Contains the value of the space Record ID. | Yes Only for Space type business processes. | Yes |
Contains the value of the business process ID. | Yes | No |
| The user ID of the user. | No | No |
| The user's company ID. | No | No |
Last Published Tuesday, April 15, 2025
