Auditing Consent Notices for Users Signing In through Web
To audit consent status for users signing in through web:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select General Administration, select User Consent, and then select Consent Status to display the log.
  3. Review the status for each user.
You can use the Consent Status log to track user acceptance.
The system tracks users based on the following responses to the consent notice:
By default, all users are tracked as Not Responded. When users sign in through web/mobile and accept or reject the consent notice, the system tracks their responses and assigns a status accordingly.
If you disable the consent notice option after it was enabled in an environment, the system will not reset the tracking status for web/mobile consent and tracking statuses will remain as they were.
The following toolbar options are displayed on the Consent Status log:
View: Lets you see the following out-of-the-box (OOTB) views:
When the view is changed to Group by Consent Status, by default the groups will be collapsed and an additional toolbar option of Expand/collapse will be displayed.
Search: Lets you find information about any user or group by way of:
Find on page: Lets you filter the contents of the log.
Print: Lets you print the contents of the log.
Reset Accepted Consent: This option is available when the consent notice option is enabled. This option lets you reset the Accepted consent status to Not Responded when there are changes in the agreement. Users who have View permission will not see this option.
The following columns are displayed on the Consent Status log:
Last Published Tuesday, April 15, 2025
