Permission Control for Consent Notice
You can assign Consent Notice permissions in the following permissions-related modules:
Access Control
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Access Control.
  3. In the right pane, expand Administration Mode Access, expand General Administration, and then expand Consent Notice.
User Administration
  3. In the right pane, expand Administration Mode Access, and then expand User Administration.
  4. Assign Consent Notice permissions through the Company Users, Partner Users, or Groups sub-nodes.
Standards & Libraries
  2. In the left Navigator, select Standards & Libraries, and then select Permission Templates.
  3. In the right pane, use Permission Templates to assign Consent Notice permissions.
Permissions can be given by anyone who has access to the nodes.
Users who have the Modify permission will be able to modify the setup and other details related to Consent Notice, for either user or bidder consent.
If a user has only the View permission for the Consent Notice node, the user will have only permission to view the setup and will not be able to make any edits to the consent notice setup or other details.
Last Published Tuesday, April 15, 2025
