Updating the Addresses Section
At a minimum, you must enter one, which functions as the default company address. The default address is used to generate an online company location map. You can add up to six additional company addresses.
To update information in the Addresses section:
- On the Company Information page, choose one of the following:
- To update an existing address, click Edit
. - To add an additional address, click + Add.
- Complete the applicable fields.
- Address type: (Required) Select from the list.
- Attention: Select from the list. The list contains active users from the owner company and is sorted alphabetically by first name.
- Country: (Required) Select from the list.
- Address line 1: (Required) Enter the address.
- Address line 2: Enter additional address information.
- City: (Required) Enter the name of the city.
- State: (Required) Enter the name of the state or region.
- Zip: (Required) Enter the ZIP Code or postal code for your location.
- Phone: Enter a phone number.
- Fax: Enter a fax number.
- Choose one of the following:
- To save changes to an existing address, click Update.
- To save changes for an additional address, click Add.
See Also
Last Published Tuesday, April 15, 2025
