Creating Integration Users
To create an integration user:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Integration Users.
- From the toolbar of the Integration Users log, click Create to open the Create User window.
- Fill out the form.
- Click Done.
The following explains each block and field in the Create User window:
General block provides general information about the integration user. The General block has the following fields:
- User Name
Note: The email address used for the User Name must be unique across all tenants.
- Status
- First Name
- Last Name
- Language (system default language)
- Description
- Time Zone (system default time zone)
- Date Format
Permissions block
It provides the ability to determine the permissions that the user has (for modules in the system). The Permissions block has the following fields:
Administration
- Company Administration
- Full Access: This permission will provide full access to the system.
- Create: This permission will provide access to all the POST services.
- Update: This permission will provide access to all the PUT services.
- Get: This permission will provide access to all the PUT services.
- User Administration
- Full Access: This permission will provide access to adding and maintaining user-level access.
Business Process
- Business Process Services
- Full Access: This permission will provide full access to services related to business processes (BPs).
- Create: This permission will provide access to all the POST services related to BPs.
- Update: This permission will provide access to all the PUT services related to BPs.
- Get: This permission will provide access to all the PUT services related to BPs.
- Non-Workflow Business Process Permissions
- Update: This permission will provide access for maintaining non-workflow BPs.
- Get: This permission will provide access to all the PUT services related to non-workflow BPs.
- Workflow Business Process Permissions
- Update: This permission will provide access to all the PUT services related to workflow BPs.
- Get: This permission will provide access to all the PUT services related to workflow BPs.
Document Manager
- Document Services
- Full Access: This permission will provide full access to services related to Documents.
- Create: This permission will provide access to all the POST services for Documents, which includes:
- Create Documents by Path
- Create Documents by Parent Folder ID
- Update: This permission will provide access to all the PUT services for Documents, which includes:
- Update Documents Metadata by Path
- Update Document Metadata by Document ID
- Get: This permission will provide access to all the PUT services for Documents, which includes:
- Get Documents by Path
- Get Documents by Parent Folder ID
- Get Document by File ID
- Delete: This permission will provide access to all POST services for documents which includes:
- Delete Documents by Node ID
- Folder Services
- Full Access: This permission will provide full access to services related to Folders.
- Create: This permission will provide access to all the POST services for Folders, which includes:
- Create Folder by Path
- Create Folder by Parent Folder ID
- Update: This permission will provide access to all the PUT services for Folders, which includes:
- Update Folders Metadata by Path
- Update Folder Metadata by Folder ID
- Get: This permission will provide access to all the PUT services for Folders, which includes:
- Get Folders, or Documents, Metadata by Path.
- Get Folders, or Documents, Metadata by Parent Folder ID.
Reporting
- User Defined Reports
- Get: This permission will provide access to all the PUT services for user-defined reports (UDRs).
Cost
- CBS Services
- Full Access: This permission will provide full access to services related to Work/Cost Breakdown Structure (WBS/CBS).
- Create: This permission will provide access to all the POST services related to CBS Services.
- Update: This permission will provide access to all the PUT services related to CBS Services.
- Get: This permission will provide access to all the PUT services related to CBS Services.
- CashFlow Services
- Full Access: This permission will provide full access to services related to CashFlow Services.
- Create: This permission will provide access to all the POST services related to CashFlow Services.
- Update: This permission will provide access to all the PUT services related to CashFlow Services.
- Get: This permission will provide access to all the PUT services related to CashFlow Services.
- CashFlow Permissions
- Update: This permission will provide access for maintaining permission levels for CashFlow Services.
Fund
- Fund Services
- Full Access: This permission will provide full access to services related to Fund Services.
- Create: This permission will provide access to all the POST services related to Fund Services.
- Update: This permission will provide access to all the PUT services related to Fund Services.
- Get: This permission will provide access to all the PUT services related to Fund Services.
Activity Manager
- WBS Services
- Create: This permission will provide access to all the POST services related to WBS Services.
- Update: This permission will provide access to all the PUT services related to WBS Services.
- Get: This permission will provide access to all the PUT services related to WBS Services.
- Activity Sheet Services
- Full Access: This permission will provide full access to services related to Activity Sheet Services.
- Create: This permission will provide access to all the POST services related to Activity Sheet Services.
- Update: This permission will provide access to all the PUT services related to Activity Sheet Services.
- Get: This permission will provide access to all the PUT services related to Activity Sheet Services.
Master Rate Sheet
- Rate Sheet Services
- Full Access: This permission will provide full access to services related to Rate Sheet Services.
- Create: This permission will provide access to all the POST services related to Rate Sheet Services.
- Update: This permission will provide access to all the PUT services related to Rate Sheet Services.
- Get: This permission will provide access to all the PUT services related to Rate Sheet Services.
ExchangeRates
- Exchange Rates Services
- Update: This permission will provide access to all the PUT services related to Exchange Rates Services.
- Get: This permission will provide access to all the PUT services related to Exchange Rates Services.
Space Manager
Do not use; this feature is not supported in Unifier Essentials.
Last Published Tuesday, April 15, 2025
