Access Control for Integration Users
To set permissions for Integration Users:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Access Control.
- In the right pane, expand Administration Mode Access, and then expand User Administration.
- Click Integration Users.
You can assign the following permissions:
Permission | Expected Behavior When Checked |
Create | When you check this option, the system selects the following permissions:
A user with the "Create" permission can add users, modify the user status, and view the user details. |
Modify | When you check this option, the system selects the "View" permission. A user with the "Modify Status" permission can modify the user status and view the user details. |
View | A user with the "View" permission can view the user details. |
Last Published Tuesday, April 15, 2025
