Reassigning Tasks Access Control
Access to the Tasks Reassignment node is by permissions.
To grant permission:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Access Control.
- In the right pane, expand Administration Mode Access, expand User Administration, and then expand Tasks Reassignments.
- Click Active User Tasks and use the Module Permission Settings dialog box to select users, or groups, and set permissions.
- Click Inactive User Tasks and use the Module Permission Settings dialog box to select users, or groups, and set permissions.
The "Enable" permission enables the user to:
- View the task
- Reassign the task
You can assign the permissions to either an individual user or a group.
The permission changes are applicable to all modules, where the permissions can be set, for example:
- User and then select Permissions
- Group and then select Permissions
- Permission template
Last Published Tuesday, April 15, 2025
