Deleting a User
Company Administrators can delete an existing user from the shell template. This section describes how to manually delete a user from a shell.
Note: You can delete a user from a specific shell template but not from other shells that have been created using the template.
To delete an existing company user:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Templates, select Shells, select the [shell type], and open the [shell template].
- In the left Navigator, select User Administration, and then select Users.
- Select a user from the log.
- Click Delete.
- When the prompt appears that asks you to confirm deletion, click Yes to remove the membership from the shell template.
Last Published Tuesday, April 15, 2025
