User Type
As part of the log attributes, the User Type column in the Users log identifies the type of user per following:
- SYS User Type/Standard: The SYS User Type/Standard User, which refers to both Company and Partner users, can have access to all modules.
- SYS User Type/Collaborator: The SYS User Type/Collaborator User can have access to all modules.
- SYS User Type/Portal: The SYS User Type/Portal User can only have access to the self-service portal login.
Note: The Portal User Type is not currently supported in Unifier Essentials.
Last Published Tuesday, April 15, 2025
