Shell Landing Page (Admin)
After you create a shell, it is available for use. To access your shell landing page:
- Click the shell tab to open it.
- Switch to Admin mode.
- In the left Navigator, select your shell name on top.
The top section of the landing page contains the Shell Dashboard.
By default, the shell dashboard contains the following blocks:
- Tasks
- Notifications
- Image
- Details
- Links
The bottom section of the shell landing page displays a log of all sub-shells that have been created under the currently selected shell. For example, if you select the sub-shell South Bay, and then the further sub-shell Mathilda Northwest, this landing page displays.
By default, the following two tabs are displayed.
- Summary
- Workspaces
You can change the layout of the tabs in My Dashboard.
Example:
Block Length: 2 units
Block Height: 2 units
The following explains the various informational blocks in the Summary tab:
- Tasks
This block lists the total tasks belonging to the shell. When you click Tasks, you go to the Tasks log directly.
- Notifications
This block lists the total notifications belonging to the shell. When you click Notifications, you go to the Notifications log directly.
- Mails
This block lists the total mails belonging to the shell. When you on Mails, you go to the Inbox log directly.
- Project Image
This block displays an image, if available; otherwise, the block will be blank.
- Details
This block is displayed with either custom fields or default fields based on the configuration of the details block that is designed in shell manager.
You can edit the details block using the pen icon or through Edit dashboard option. This capability applies to block information, or to the fields that must be displayed in the block.
- Links
If links have been added to the shell details, then those links are displayed in this block.
- Sub-shell log
This block displays the sub-shells of parent shell, based on the view that you have selected. You can hide Workspaces in other dashboards.
The user-created dashboards support all of the existing functionalities, except the sub-shell log.
You cannot delete Workspaces tab in any Dashboard.
You cannot hide the Workspaces tab in My Dashboard. As a result, you cannot deselect the Show checkbox for Workspaces.
User will be able to hide Workspaces Tab in all user-defined Dashboards and will be able to deselect the Show checkbox for Workspaces.
Important Information
The Tasks, Notification, and Mails can be added or removed. Individual tiles cannot be added/removed.
The following explains the various informational blocks in the Workspaces tab:
The Workspaces tab is available only when geo-code server details are configured in the system.
- If there are no geo-location present in the sub-shells, the system displays a map without location markers.
- If there is a geo-location present in the sub-shells, the system displays a map with location markers.
When you hover over the location markers on the map, you can see the details for the location marker based on available information.
When you right-click on the location marker, you can open the shell (for that location) in a new tab.
The more menu option (the three horizontal dots icon next to My Dashboard) lets you access:
- Additional dashboards for the shell, if available.
- Edit Dashboard
To open the editing mode of the current dashboard.
- Details
To view the shell details, as overlay. The details include: Shell Name, Shell Number, and the following tabs:
- General
- Currency
- Options
- Links
- Calendar
- Integration
- Audit Log
To open the audit log, as overlay.
The Workspaces tab has the following toolbar options:
- View
For example, Buildings, Cities, Shells, Projects, Regions.
- Actions
- Get Activity Sheet Data
All Shells
Selected Shells
Filtered Shells
History
- Send Activity Sheet Data
All Shells
Selected Shells
Filtered Shells
History
- Search
- Find on page
- Expand All Groups
The columns in the Workspaces tab sub-shell log are not hard-coded. The fields defined in Shell Detail form are added as columns in the Sub-shell log.
- Name
- Shell Number
- Shell Name
- Description
- Status
- Administrator
- Location
- User-Defined Text
The right-hand pane displays the map that shows the regions.
Last Published Tuesday, April 15, 2025
