Activity Manager Permissions
You can use the following options to grant permission to Activity Sheet under the Activity Manager node.
Access Control
To update permissions for Activity Sheet at the company level:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Access Control.
  3. In the right pane, expand User Mode Access, expand Projects/Shells, expand Schedule Management, and select Activity Sheet.
To update permissions for Activity Sheet for a specific project/shell:
  1. Go to the shell tab and switch to Admin mode.
  2. In the left Navigator, select Access Control.
  3. In the right pane, expand User Mode Access, expand Schedule Management, and select Activity Sheet.
Grant any of the following available permissions:
For Rate Sheet:
  3. In the right pane, expand User Mode Access, expand Projects/Shells, and select Rate Sheet.
Permission Templates
For Activity Sheet:
  2. In the left Navigator, select Standards & Libraries, and then select Permission Templates.
  3. Open the template, click the Permissions tab, and assign permissions.
  4. Under Modules For section, expand User Mode Access, expand Projects/Shells, expand Activity Manager, and select Activity Sheet.
  5. Assign permissions. See the description of permissions under Access Control, above.
For Rate Sheet:
  4. Under Modules For section, expand User Mode Access, expand Projects/Shells, expand Activity Manager, and select Rate Sheet.
See Also
Activity Manager
Last Published Tuesday, April 15, 2025
