Comparing BP Versions
You can compare any two versions of a BP design.
To compare versions:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select System Information, and then select BP Visualizer.
  3. Click a BP.
  4. In the BP Visualizer [BP Name] window, select the Compare Versions tab.
  5. In the Comparing section, select a version from the Version 1 list and the Version 2 list.
    Differences are listed in alphabetical order for the elements that have changed. System-generated changes are also included in the comparison.
    You can use the options in the Filter to display all modifications or to display only specific changes.
    • All: Displays all differences.
    • Modified: Displays the data that has been modified in the second version. Items that differ between the two versions are highlighted in yellow.
    • Added: Displays the data that has been added to the second version. Items that exist in the later version but not the earlier version are highlighted in green.
    • Deleted: Displays the data that has been removed from second version. Items that exist in the earlier version but not in the later version are highlighted in pink.
  6. To see detailed information about the modifications made to any part of the BP, expand the branches of the configuration.
  7. To return to the list of BPs, click Show BPs in the upper-left corner.
Last Published Tuesday, April 15, 2025
