Examining Forms
You can use the Forms tab to view the forms that are part of the selected BP. For example, you might want to see if an Action or View form is part of the BP, and if so, what triggers it. You can drill down through the Forms of a BP and look at various fields and properties.
To examine the forms of a BP:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select System Information, and then select BP Visualizer.
  3. Click a BP.
  4. In the BP Visualizer [BP Name] window, select the Forms tab.
    A list of forms is displayed. You can open any of the forms and view more detailed information.
  5. To return to the list of BPs, click Show BPs in the upper-left corner.
Last Published Tuesday, April 15, 2025
